gotime242
Joined: 09 Jul 2010 Posts: 52 Location: West Palm Beach, FL
Posted: Sun Jul 24, 2011 6:19 am Post subject: What mic cover/muff do you use? |
Hello all,
I wear a normal david clark headset in my FSII with a very low windscreen, i basically have the wind coming directly at my head. I can communicate somewhat by having the volume way up (listen to static the whole time) and placing my hand over the mic when needing to talk.
What is everyone doing, or what product are people using for their microphones? I was looking around at different mic muff options but just wanted to see what people have found works best.
Thanks!
-Dylan
HShack(at)aol.com Guest
Posted: Sun Jul 24, 2011 10:09 am Post subject: What mic cover/muff do you use? |
You could extend your windshield up to the wing. [biggest improvement I have made to the FS II except maybe VG's]. Get a noise cancelling headset [the absolute best for a FS II is the Victor {ANR}. All this from memory but they are actually made & warranteed by Lightspeed. Look up "aircraft headsets" on eBay. You will find them on the first page for under $300. I think it comes with a foam mic muff.
If I REALLY want to get my message through, I will cover the mic with my hand & maybe even cut engine rpm's some.
Howard Shackleford
FS II
SC
In a message dated 7/24/2011 10:22:03 A.M. Eastern Daylight Time, dylanshine(at)gmail.com writes:
| Quote: | What is everyone doing, or what product are people using for their microphones? I was looking around at different mic muff options but just wanted to see what people have found works best.
russkinne(at)mac.com Guest
Posted: Sun Jul 24, 2011 10:37 am Post subject: What mic cover/muff do you use? |
Dylan
Any time a mic is used in the wind, a wind-sock will improve xmission greatly. Just a tubular sleeve of foam-plastic, 1/4 or 1/2" thick, will do fine. You can just cut one out with scissors and tape it together. Look at the TV reporters --= they all use them.
Russ
On Jul 24, 2011, at 10:19 AM, gotime242 wrote:
Hello all,
Thanks!
-Dylan
http://forums.matronics.com/viewtopic.php?p=347546#347546
lhaggerty(at)tampabay.rr. Guest
Posted: Sun Jul 24, 2011 4:16 pm Post subject: What mic cover/muff do you use? |
Try Oregon Aero military upgrade kits for microphones Mic Muffs. Pete
Dana
Posted: Mon Jul 25, 2011 4:37 am Post subject: What mic cover/muff do you use? |
I use a Comtronics helmet with built in headset. The mike has a foam cover. No windshield on my Ultrastar. I can hear fine, and people report they can hear me fine.
-Dana
gotime242 <dylanshine(at)gmail.com> wrote:[quote] t Email [quote][b]
gotime242
Posted: Mon Jul 25, 2011 12:20 pm Post subject: Re: What mic cover/muff do you use? |
Thanks for the replies all.
I currently have a foam cover on there now, but i think ill try that Oregon aero cover sock...i mean heck it looks almost like i could make one to try and see if it will work first.
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Tue Jul 26, 2011 6:31 am Post subject: What mic cover/muff do you use? |
At 04:34 AM 7/26/11 -0700, you wrote:
David,
I have been using a throat microphone with a, currently, old hand held
Yaesu "Aviator Pro VXA-100". It works very well, but requires some
electronic kit building, and trial and error. Not fun. Part of my problem
is the Yaesu used a non standard setup for keying the microphone, etc. If
you would like to see one persons effort to solve this problem, see:
http://jackbhart.com/firefly/firefly110.html
Note: most of my engine electrical noise disappeared when I moved the engine
magneto kill switch back on or near the engine. This indicates that this
wire should be kept as short as possible and/or shielded to ground.
Jack B. Hart FF004
Winchester, IN
