Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sat Jul 30, 2011 7:09 am Post subject: avionics settings |
Anyone out there happen to know the settings for the Grand Rapids HX EFIS to get the altitude encoder talking to the Garmin GTX 330? Everyone except me seems to be at OshKosh.
Eric Kallio
rleffler
Posted: Sat Jul 30, 2011 9:16 am Post subject: avionics settings |
Sorry Eric, but I'm at OSH too, but I do have that at home. There is a schematic on my kitlog site, but that jpg is probably not readable.
_________________ Bob Leffler
N410BL - Phase I
Eric_Kallio
Posted: Sat Jul 30, 2011 12:39 pm Post subject: Re: avionics settings |
I finally have my xpndr and pitot static check on Monday so to fulfill the requirements for IFR cert, I need mode C. Right now the components aren't talking and I can work it out in flight by cycling through the options if I have to. Thanks.
Eric
Bob Turner
Posted: Mon Aug 01, 2011 9:21 am Post subject: Re: avionics settings |
You don't have to do it in flight since the 330 will display the correct pressure altitude (labeled FL ___) when it's talking to the HX.
I have the 327 and it is hooked up thru a serial line. I think you have the option of a serial line, or the ARINC line? I can get you my serial setting next time I'm at the hangar if that helps.
Bob
_________________ Bob Turner
RV-10 QB |
Eric_Kallio
Posted: Mon Aug 01, 2011 9:51 am Post subject: Re: avionics settings |
Got some resolution from another builder in the area. The 330 has to be set to receive" Icarus ALT" on the settings screen and the garmin trimble encoder settings off of the EFIS encoder. I had the 330 set differently. Made that change and it looks to be working.
Eric
Bob Turner
Posted: Mon Aug 01, 2011 5:47 pm Post subject: Re: avionics settings |
Sounds like you've got it working.
As I promised, here are the HX settings I use for sending altitude to a Garmin 327 (not 330), over a serial line:
HX serial port 6 speed: 9600
HX serial port 6 out: Fuel/Air Data (Z Format)
(of course, any serial port can be used).
RV-10 QB |
