rickofudall
Posted: Thu Aug 11, 2011 1:26 pm Post subject: Stop nuts one terminal studs? |
Dan, If your metric contactor studs are 6mm X 1.0, the 21042-4 will go right on. I use them on Rotax vibration dampers to mount the radiator on my plane and they work just fine.
FWIW,
Rick Girard
On Thu, Aug 11, 2011 at 12:56 PM, messydeer <messydeer(at)yahoo.com (messydeer(at)yahoo.com)> wrote:
Quote: | --> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com (messydeer(at)yahoo.com)>
Hi!
I have a 3/16 to 1/4" studs on my battery, battery contactor, starter contactor and ground posts. Some came with simple jam-type nuts with a split ring washer. What type of nuts and washers should I use FWF? I've got MS21042-3 and -4 that would work for some. Others are metric and wold need a separate lock washer of sorts.
Thanks!
Dan
http://forums.matronics.com/viewtopic.php?p=349196#349196
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Mon Aug 22, 2011 6:01 am Post subject: Re: Stop nuts one terminal studs? |
Quote: | Dan, If your metric contactor studs are 6mm X 1.0, the 21042-4 will go right on. |
Thanks, Rick!
I do have some metric studs, come to think of it. Think it's the battery contactor, not sure about the starter. Battery itself, too, I think.
Another thought is how much torque to put on these. I suppose I otta look that info up from the contatctor specs. If the studs are embedded in plastic, seems the 50-70 in-lbs could damage it.
And sorry about the late response. Since your post wasn't a reply to mine, I didn't get an email.
Dan
Posted: Mon Aug 22, 2011 7:36 am Post subject: Stop nuts one terminal studs? |
These are generally hard copper or brass studs.
I don't think you're going to find anyone offering
recommended torque values. Us internal tooth lockwashwers
under the nuts and snug 'em up.
dsleepy47
Posted: Mon Aug 22, 2011 8:24 am Post subject: Stop nuts one terminal studs? |
> Date: Mon, 22 Aug 2011 10:32:23 -0500
Quote: | To: aeroelectric-list(at)matronics.com
Subject: Re: Re: Stop nuts one terminal studs?
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
I don't know about other manufacturers but these : http://www.trombetta.com/dc-contactor-products.cfm?id=51 have the torque values on the label. You can open the drawing and zoom in on the label.
Deems
_________________ dsleepy47
N1491R |
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Tue Aug 23, 2011 6:12 am Post subject: Re: Stop nuts one terminal studs? |
As a licensed A&P mechanic, I shudder to think of what the repercussions would be if I were to advocate the mixing of AN standard and metric hardware and something went wrong. Please listen carefully to Bob and use an internal star lockwasher under the metric nut. It is a RARE day indeed when Bob will steer you wrong.
The more educated and experienced of us must teach our students the correct way – not what we can get away with. They will learn that all too easily on their own. Hopefully, no one will be killed in the process.
_________________ Jerry King |
messydeer
Posted: Tue Aug 23, 2011 7:46 am Post subject: Re: Stop nuts one terminal studs? |
Thanks for the feedback, guys.
I was able to find the info for Odyssey battery, M6 40 in-lbs, and the EV200 battery contactor, M8 x 1.25 80-100 in-lbs. I'll use internal star washers and torque to these values.
I couldn't find any info on the Jabiru starter contactor. The posts are the color of a shiny penny and about 5/16" diameter. Threads look coarse, but didn't fit a 5/16-18 bolt. The stackup order on each post from the bottom up is internal star washer, nut, another internal star washer and another nut. The bottom nuts were already torqued pretty tight.
I've done one starter contactor terminal, placing the ring over lower nut and tightening the top nut with star washer. Used a wrench to hold the lower nut while I tightened the upper one. Not sure how much torque there was on it, but the first go wasn't tight enough. During tightening, the cable lug rotated, so I pushed the cable back into place, which caused the top nut to loosen. After tightening a bit more, the top and bottom nuts rotate on the post as a unit when I push on the cable, but it takes a lot more force than before. I'm essentially using the cable as a lever, like a wrench, since the nuts and lug rotate as a unit. I'd be happy to call this good.
_________________ Dan |
BobsV35B(at)aol.com Guest
Posted: Tue Aug 23, 2011 9:45 am Post subject: Stop nuts one terminal studs? |
Good Afternoon Dan,
I am confident you will do this, but may I mention that it is excellent practice to place an Adel clamp in a strategic location which will make the wire not work as a wrench?
Happy Skies,
Old Bob
In a message dated 8/23/2011 10:51:08 A.M. Central Daylight Time, messydeer(at)yahoo.com writes:
Quote: | --> AeroElectric-List message posted by: "messydeer" <messydeer(at)yahoo.com>
Dan
