michael(at)wellenzohn.net Guest
Posted: Wed May 17, 2006 7:46 am Post subject: Rudderedge (ProSeal on Primer or on bare metal) |
Hello,
when you primed your rudder skins did you tape the edge so that the ProSeal
would stick to the bare metal or not. (I use DuPont 820R Primer).
Best Regards
Michael
Michael Wellenzohn
#40511 (VS)
Zuerich,Switzerland
www.wellenzohn.net
Posted: Wed May 17, 2006 7:49 am Post subject: Rudderedge (ProSeal on Primer or on bare metal) |
Hello,
Best Regards
Michael
Michael Wellenzohn
#40511 (VS)
Zuerich,Switzerland
www.wellenzohn.net
jesse(at)itecusa.org Guest
Posted: Wed May 17, 2006 8:42 am Post subject: Rudderedge (ProSeal on Primer or on bare metal) |
Yes, you scuff it well and then tape it so the paint doesn't get there.
This is true for everywhere you are going to put proseal.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
rick.conti(at)boeing.com Guest
Posted: Wed May 17, 2006 10:25 am Post subject: Rudderedge (ProSeal on Primer or on bare metal) |
No, and I used AKZO primer from Aircraft Spruce. No problem with
adhesion.
I also bought a 6' piece of steel 2" angle. I drilled holes the length
space the same as the rudder. After applying the ProSeal I cleoed the
rudder to the steel angle to ensure a true straight edge. Worked great.
Thank You
Rick Conti
office: 703 - 414 - 6141
blackberry: 571 - 215 - 6134
