craigr60(at)gmail.com Guest
Posted: Mon Sep 05, 2011 7:20 am Post subject: Wires to tail |
I am wiring the tail light and find that there are no holes for a grommet thru the bulkhead. Are we drill the bulkhead? or are there other thoughts... Thanks Craig
coop85(at)verizon.net Guest
Posted: Mon Sep 05, 2011 8:42 am Post subject: Wires to tail |
I drilled a hole for the wires and installed pastic grommets. Having just rewired the tail strobelight I would probably go with a very lightweight plastic conduit through the large lightening holes next time to make future changes much easier.
Marcus
Posted: Mon Sep 05, 2011 9:10 am Post subject: Wires to tail |
Thanks, I to think that lightweight conduit is the way to go. I'm using that in my wings also. Craig
On Mon, Sep 5, 2011 at 9:37 AM, Marcus Cooper <coop85(at)verizon.net (coop85(at)verizon.net)> wrote:
[quote]--> RV10-List message posted by: Marcus Cooper <coop85(at)verizon.net (coop85(at)verizon.net)>
Marcus
--> RV10-List message posted by: Craig Rufi <craigr60(at)gmail.com (craigr60(at)gmail.com)>
http://forums.matronics.com
le, List Admin.
rngurley
Joined: 21 Jan 2008 Posts: 18 Location: Indianapolis, IN
Posted: Mon Sep 05, 2011 9:26 am Post subject: Wires to tail |
Where did you drill the hole and how large?
Dick
On Sep 5, 2011, at 1:05 PM, Craig Rufi <craigr60(at)gmail.com (craigr60(at)gmail.com)> wrote:
[quote]Thanks, I to think that lightweight conduit is the way to go. I'm using that in my wings also. Craig
On Mon, Sep 5, 2011 at 9:37 AM, Marcus Cooper <[url=mailto:coop85(at)verizon.net]coop85(at)verizon.net (coop85(at)verizon.net)[/url]> wrote:
| Quote: | --> RV10-List message posted by: Marcus Cooper <[url=mailto:coop85(at)verizon.net]coop85(at)verizon.net (coop85(at)verizon.net)[/url]>
Marcus
--> RV10-List message posted by: Craig Rufi <[url=mailto:craigr60(at)gmail.com]craigr60(at)gmail.com (craigr60(at)gmail.com)[/url]>
le, List Admin.
Posted: Mon Sep 05, 2011 9:50 am Post subject: Wires to tail |
Along the bottom, offset to the side from the holes for the rudder cables. I think they were1/2" but not sure. Just large enough to run the wires for the lights. Again, I would recommend the very thin walled PVC pipe or similar down the lightening holes if I were to do it again. I used that in the wings and was glad I did.
Marcus
Dick
On Mon, Sep 5, 2011 at 9:37 AM, Marcus Cooper < (coop85(at)verizon.net)coop85(at)verizon.net (coop85(at)verizon.net)> wrote:
href="x-msg://269/3D%22http://www.matronics.com/Navigator?RV10-List%22">http://www.matronics.com/Navigator?RV10-List
href="x-msg://269/3D%22http://forums.matronics.com%22">http://forums.matronics.com
href="x-msg://269/3D%22http://www.matronics.com/contribution%22">http://www.matronics.com/contribution
rv10flyer
Posted: Mon Sep 05, 2011 2:29 pm Post subject: Re: Wires to tail |
I drilled approx 5/16" hole on lower lh side. Outside of vs mounting area so that it could be inst/removed w/o pulling wires. Sanded hole with 320 grit and installed heat shrink at pass thru for extra protection.
_________________ Wayne G. |
johngoodman
Posted: Tue Sep 06, 2011 4:37 am Post subject: Re: Wires to tail |
I drilled a hole through F1012B that passed through the very top of F1012E, just below F1056. I found a grommet that would hold the wire, and drilled accordingly. Also heat shrunk the wire to make sure, since it's pretty thick there.
