Horizontal Stabilizer bolts loose at annual
Goto page 1, 2  Next
AirMike
PostPosted: Tue Sep 06, 2011 6:23 pm    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
I was quite shocked today to find out that the HS bolts (4) on the front of the HS were out of proper torque. This discovered during my annual condition inspection. I would not say that they were loose, but they definitely needed tightening. No apparent fretting. Tightened about one full turn with the torque wrench - wow........
See you OSH '18
Q/B - sold.
pitts_pilot(at)bellsouth.
PostPosted: Tue Sep 06, 2011 6:35 pm    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
If you used torque seal you know (1) that you had tightened the bolts at
final assembly and (2) the bolts loosened after being tightened. I'm
using yellow torque seal to make sure that I don't miss any fasteners.
I fill the screwdriver slots on screws that I don't plan on taking out
for access .... like at annual time.
Linn
See you OSH '11
Q/B - flying 1 yr+
http://forums.matronics.com/viewtopic.php?p=351613#351613
AirMike
PostPosted: Tue Sep 06, 2011 7:59 pm    Post subject: horizontal Stabilizer bolts loose at annual Reply with quote
My alert was the fractured torque seal. Torque seal is a MUST do on all critical airframe and engine nuts.
See you OSH '18
Q/B - sold.
rv10flyer
PostPosted: Wed Sep 07, 2011 5:33 am    Post subject: Re: Horizontal Stabilizer bolts loose at annual Reply with quote
We lose some clamping force with all of that primer. There are many flight critical connectons on this plane that should have drilled heads or shanks for safety wire or cotter pins.
Wayne G.
PostPosted: Wed Sep 07, 2011 7:47 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Good for ya!!! Any idea why they loosened??
Linn
See you OSH '11
Q/B - flying 1 yr+
http://forums.matronics.com/viewtopic.php?p=351625#351625
AirMike
PostPosted: Thu Sep 08, 2011 7:13 am    Post subject: Horizontal Stabilizer bolts loose at annual cause suspected Reply with quote
I suspect that:
1. Vibration loosened the nuts. Or
2. Vans has you install the bolts - top down with the nuts on the underside.
Thinking about it now, this might be wrong. I obviously torqued the assembly from the top. Not the best way to do it. You do not get an accurate torque value. If I were building again -bolts bottom-up. That way you can torque the nuts precisely.
3. Some combination of inaccurate torque and vibration.
See you OSH '18
Q/B - sold.
Tim Olson
PostPosted: Thu Sep 08, 2011 7:44 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Big mistake. If you do that, and the nuts loosen, it'll fall
right out. That's why all bolts are IN, DOWN, AFT on their
direction.
Tim Olson - RV-10 N104CD
On 9/8/2011 10:13 AM, AirMike wrote:
I suspect that:
See you OSH '11
Q/B - flying 1 yr+
http://forums.matronics.com/viewtopic.php?p=351733#351733
jdriggs49(at)msn.com
PostPosted: Thu Sep 08, 2011 7:57 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Soooo,
What is the theory about substituting castle nuts and locking pins? Any good reason not to do so on these critical areas????
Date: Thu, 8 Sep 2011 10:40:25 -0500
Subject: Re: Re: Horizontal Stabilizer bolts loose at annual
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
direction.
> --> RV10-List message posted by: "AirMike"<Mikeabel(at)Pacbell.net>
> I suspect that:
> See you OSH '11
> Q/B - flying 1 yr+
&g================
Tim Olson
PostPosted: Thu Sep 08, 2011 8:13 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
I don't see why that would be a bad idea at all.
On 9/8/2011 10:53 AM, Danny Riggs wrote:
Soooo,
> From: Tim(at)myrv10.com
> To: rv10-list(at)matronics.com
> direction.
> do not archive
> > I suspect that:
underside.
> > See you OSH '11
> > Q/B - flying 1 yr+
> > Read this topic online here:
&g================
jchang10
I just know on those 4 particular AN3 bolts for the HS, access is an issue. It is hard enough with regular lock nuts.
AirMike, i think fewer bounces on landing would help keeps nuts and bolts from loosening. Just kidding! Very Happy Very Happy
On 9/8/2011 8:53 AM, Danny Riggs wrote: [quote] Soooo,
#40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011
PostPosted: Thu Sep 08, 2011 8:14 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
The problem with castle nuts is most of the time they can't meet the torque spec. Either too high or too low, but seldom right on.
This is the first time I've heard of 'loose' fasteners, and I really appreciate Mike stepping up and letting us know. He does have a point on torquing the head of the bolt rather than the nut. Not the best solution, but should have been close enough. As more -10s go through conditional inspections and the bolts get looked at we'll know if this is an anomaly or not.
Just my two pennies.
Linn
On 9/8/2011 11:53 AM, Danny Riggs wrote: [quote] Soooo,
> From: Tim(at)myrv10.com (Tim(at)myrv10.com)
> To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> (Tim(at)myrv10.com)
> direction.
> do not archive
> > --> RV10-List message posted by: "AirMike"<Mikeabel(at)Pacbell.net> (Mikeabel(at)Pacbell.net)
> > I suspect that:
> > See you OSH '11
> > Q/B - flying 1 yr+
&g================
jeff(at)westcottpress.com
PostPosted: Thu Sep 08, 2011 8:21 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Hi Tim,
You've got "do not archive" on this one. I think it should be archived
in big bold print.
Jeff Carpenter
40304
direction.
> I suspect that:
> underside.
> See you OSH '11
> Q/B - flying 1 yr+
philperry9(at)gmail.com
PostPosted: Thu Sep 08, 2011 8:28 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
I was thinking about a hybrid approach. Drilled bolts, locked torque nuts, but a cotter key through the bolt just to keep the nut from being able to back off......
Phil
On Sep 8, 2011, at 11:09 AM, Linn Walters <pitts_pilot(at)bellsouth.net (pitts_pilot(at)bellsouth.net)> wrote:
[quote] The problem with castle nuts is most of the time they can't meet the torque spec. Either too high or too low, but seldom right on.
Linn
Soooo,
> From: [url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)[/url]
> To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
> --> RV10-List message posted by: Tim Olson <[url=mailto:Tim(at)myrv10.com]Tim(at)myrv10.com (Tim(at)myrv10.com)>[/url]
> direction.
> do not archive
> > --> RV10-List message posted by: "AirMike"<[url=mailto:Mikeabel(at)Pacbell.net]Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>[/url]
> > I suspect that:
> > See you OSH '11
> > Q/B - flying 1 yr+
&g================
dlm34077(at)q.com
PostPosted: Thu Sep 08, 2011 9:03 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Install HiLocs
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Phil Perry
Sent: Thursday, September 08, 2011 9:24 AM
Phil
Linn
Soooo,
> From: (Tim(at)myrv10.com)Tim(at)myrv10.com (Tim(at)myrv10.com)
> To: (rv10-list(at)matronics.com)rv10-list(at)matronics.com (rv10-list(at)matronics.com)
> --> RV10-List message posted by: Tim Olson < (Tim(at)myrv10.com)Tim(at)myrv10.com (Tim(at)myrv10.com)>
> direction.
> do not archive
> > --> RV10-List message posted by: "AirMike"< (Mikeabel(at)Pacbell.net)Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
> > I suspect that:
> > See you OSH '11
> > Q/B - flying 1 yr+
> > [/url][url=http://forums.matronics.com/viewtopic.php?p=351733#351733]http://forums.matronics.com/viewtopic.php?p=351733#351733
&g================
bruce1hwjohnson(at)yahoo.
PostPosted: Thu Sep 08, 2011 9:13 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Speaking of annuals, dose anybody have a list generated for a step by step procedure? And of course mine is due as to why I am inquiring.
Sent: Thursday, September 8, 2011 9:09 AM
Subject: Re: RV10-List: Re: Horizontal Stabilizer bolts loose at annual
Linn
direction.
> I suspect that:
> See you OSH '11
> Q/B - flying 1 yr+
&g================
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
pietflyr(at)bellsouth.net
PostPosted: Thu Sep 08, 2011 11:21 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
One thing Van’s does that I just don’t agree with is their use of locknuts on rotating assemblies (like aileron hinges). AC 43.13 most definitely requires castle nuts and cotter pins in such locations. Locknuts can and will loosen if rotated enough.
Jack Philliips
#40610
Raleigh, NC
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Thursday, September 08, 2011 11:53 AM
Subject: RE: Re: Horizontal Stabilizer bolts loose at annual
Soooo,
> direction.
> do not archive
> > I suspect that:
> > See you OSH '11
> > Q/B - flying 1 yr+
&g================
carl.froehlich(at)verizon
PostPosted: Thu Sep 08, 2011 11:53 am    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
The bolt and nut captures the hinge bearing.  The hinge bearing rotates.  There is no relative motion between the bolt/nut and the bearing ball.
Using a castle nut would yield the bolt becoming the bearing as you would most likely not have it tight enough to capture the bearing ball.  Not recommended.
Carl
Sent from my phone.  Please read pass the typos.
-----Original message-----
[quote]From: Jack Phillips <pietflyr(at)bellsouth.net>
To:
Sent:
Thu, Sep 8, 2011 19:16:02 GMT+00:00
Subject:
RE: RV10-List: Re: Horizontal Stabilizer bolts loose at annual
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]-->
Jack Philliips
#40610
Raleigh, NC
Subject: RE: RV10-List: Re: Horizontal Stabilizer bolts loose at annual
Soooo,
> direction.
> do not archive
> > I suspect that:
> > See you OSH '11
> > Q/B - flying 1 yr+
&g================
Kelly McMullen
PostPosted: Thu Sep 08, 2011 3:48 pm    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
The latest product is castle nuts that are also self locking.
Available from usual sources. On the road, so don't have the MS number
handy. They are specifically for use on all control hinges and other
places like push pull tube bellcranks.
On Thu, Sep 8, 2011 at 12:16 PM, Jack Phillips <pietflyr(at)bellsouth.net> wrote:
Jack Philliips
#40610
Raleigh, NC
Soooo,
> direction.
> do not archive
> > I suspect that:
> > underside.
> > See you OSH '11
> > Q/B - flying 1 yr+
&g================
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
jcumins(at)jcis.net
PostPosted: Thu Sep 08, 2011 4:05 pm    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Man that’s a great idea. I will have to do that. Just because the castle
nut is used it will no cause the bolt to be the pivot point as long as the
nut is properly torched and confirmed tight.
John Cumins
President
707-425-7100
707-425-7576 Fax
kearney
PostPosted: Thu Sep 08, 2011 4:30 pm    Post subject: Horizontal Stabilizer bolts loose at annual Reply with quote
Hi Kelley
I have been reading this thread with interest. On the recommendation of an AME (Cdn A&P) I have replaced a few of the critical nylocs with self locking castles.
Cheers
Les
> Jack Philliips
> #40610
> Raleigh, NC
> ________________________________
> Soooo,
>> direction.
>> do not archive
>>> I suspect that:
>>> underside.
>>> See you OSH '11
>>> Q/B - flying 1 yr+
> &g================
Goto page 1, 2  Next
Page 1 of 2
