greerdans(at)AOL.COM Guest
Posted: Thu May 18, 2006 5:32 am Post subject: Wing Back Riveting |
Just finishing up working on the wing ribs. Looking ahead to the skins I wanted to ask if Back Riveting using the large handheld bucking bar had worked well for those that have tried it. Also, do you recommend using the 12 inch straight or double offset back rivet set.
George
40434 (Wings)
millstees(at)ameritech.ne Guest
Posted: Thu May 18, 2006 6:20 am Post subject: Wing Back Riveting |
George;
I just completed the wing skins, and I back riveted everything. It came out great. I did use the large handheld bucking bar, and it was easy. In many spots you will need the double offset back riveter. Just take your time, have a good assistant, and it will work great.
Steve Mills
40486 Naperville, Illinois
finishing wings
Rick S.
Posted: Thu May 18, 2006 6:21 am Post subject: Wing Back Riveting |
Worked great, used the large back rivet bucking bar and the 12" straight back rivet set. Only had to buck a few. If you can get some one to bend a offset into the 12" set even better. Otherwise you need to move the rib slightly off center to get right on the rivet.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
