Power Flow cutout
teamgrumman(at)yahoo.com
PostPosted: Sun Sep 18, 2011 7:06 pm    Post subject: Power Flow cutout Reply with quote
When I install a Power Flow Exhaust System, I cut out the exit ramp so the pipe can slip out through the opening. The template I use is actually one of the cutouts from a Jaguar cowling. I scanned it (yes, I out the fiberglass on the scanner flatbed) and now have a drawing. Unfortunately, when printed out, it's about 3/4 inches too short. The width is the same as the scan, it's just shorter. I haven't measured it, but, the width where the muffler slips in is about 1/4 inches bigger than the muffler. When installed, it provides about 1/2 inches clearance all around.
If you can use it, great. If not, no worries.
 Filesize:  25.11 KB
 Viewed:  781 Time(s)
