Posted: Mon Sep 19, 2011 4:13 am Post subject: Need some measurements |
Fighting an exhaust system fit up problem.
Need two measurements:
<![if !supportLists]>- <![endif]>On the standard Van’s cowl, the width of the bottom cowl air exhaust opening
<![if !supportLists]>- <![endif]>On the standard Vetterman’s exhaust system, the distance between the outside edge of the two heat muffs. In other words, looking for the width of the exhaust system in the lower portion of the cowl.
Carl
rv10flyer
Posted: Tue Sep 20, 2011 3:39 am Post subject: Re: Need some measurements |
Give me a few days and I will provide you with some.
_________________ Wayne G. |
