Posted: Wed Sep 28, 2011 6:16 am Post subject: AeroElectric-List: |
IIRC the Lancair is not metal-skinned....
The ground-plane should be electrically connected to the shield of the coax - which should also be electrically connected to the ground-side of the electrical system via the radio.
BGray(at)glasair.org Guest
Posted: Wed Sep 28, 2011 6:47 am Post subject: AeroElectric-List: |
Then why do some radio manufacturers require a ground plane of a minimum
diameter? If the ground plane was connected to the aircraft ground, size
would not matter. (no puns please)
Bruce
WWW.Glasair.org
Posted: Wed Sep 28, 2011 7:33 am Post subject: AeroElectric-List: |
The ground plane of minimum diameter provides for the reflection of the RF energy at the antenna - specifically for non metallic airframes. I think there is at least one Berkut out there that is set up this way.
In my case, I have my transponder antenna mounted inside my engine cowl pointing downward with an aluminum circle providing the ground plane. It is isolated from physical grounding by the mount and is electrically 'bonded' to the ground system.
Bob could probably explain the theory better - I took it in to practice and it works well for me.
grosseair(at)comcast.net Guest
Posted: Wed Sep 28, 2011 7:44 am Post subject: AeroElectric-List: |
I believe that the minimum size of the ground plane is related to the
wave length of the radio.
John Grosse
Bruce wrote:
Bruce
WWW.Glasair.org
Posted: Wed Sep 28, 2011 8:28 am Post subject: AeroElectric-List: |
Then why does my WX-500 require a 12 inch ground plane? It only receives
RF.
Bruce
WWW.Glasair.org
tiethoff
Posted: Wed Sep 28, 2011 9:23 am Post subject: AeroElectric-List: |
Try it without the groundplane and you will find out why you need the thing...
Met vriendelijke groet en
verzonden vanaf de bijna
illegale Samsung Galaxy S2,
Eric Tiethoff. Op 28 sep. 2011 18:36 schreef "Bruce" <BGray(at)glasair.org (BGray(at)glasair.org)> het volgende:> --> AeroElectric-List message posted by: "Bruce" <BGray(at)glasair.org (BGray(at)glasair.org)>
[quote] Then why does my WX-500 require a 12 inch ground plane? It only receives
RF.
Bruce
WWW.Glasair.org
Posted: Wed Sep 28, 2011 10:28 am Post subject: AeroElectric-List: |
Not the expert on the theory - but I think RF exhibits the same behaviour relative to the antenna regardless of being transmitted or received.
Posted: Wed Sep 28, 2011 8:28 pm Post subject: AeroElectric-List: |
At 09:13 AM 9/28/2011, you wrote:
<recapen(at)earthlink.net>
I think he was asking if the ground plane needed
some extra conductor from the metal over to
the electrical system ground.
There is no value in adding such wires from
an RF perspective. I've seen such bonding
conductors added for lightning strike issues
on composite aircraft.
Posted: Wed Sep 28, 2011 8:34 pm Post subject: AeroElectric-List: |
At 09:43 AM 9/28/2011, you wrote:
The ideal ground plane is an infinite number
of radial conductors having the same length
as the antenna itself. In other words, a 22"
comm antenna would ideally sit on a 44" diameter
disk.
The 2.6" transponder antenna sits on a 5.2" disk.
Since the ideal, 'tuned' disk is impractical
for most aircraft installations, the next best
thing is to have 4-8, 22" radials fan out from the
base of the comm antenna and conform to the inside
surface of the aircraft.
Aircraft power ground and antenna RF ground are
completely separate, unrelated systems. See chapter
on antennas and feedlines in the 'Connection.
