csdjbtexas(at)live.com Guest
Posted: Fri Oct 21, 2011 3:41 am Post subject: Rehab RV - Engine mount and Nose gear |
I am trying to restore a damaged RV8A. Nose gear leg is stuck in the engine mount, and I am thinking about heat application while it is in the hydraulic press.
From my quick research online, the steel strength should not be affected so long as it is not heated beyond 40% of the melting point, or about 1000 deg F. If I keep an IR thermometer on it during the attempt, and keep the temp below 800, I figure I am probably ok. But for the purpose of heat expansion, maybe about 500 would be enough.
Any metalurists on the list? Funny things happen during that cooling down period.
C Dominey
csdjbtexas(at)live.com (csdjbtexas(at)live.com)
denis.walsh(at)comcast.ne Guest
Posted: Fri Oct 21, 2011 4:07 am Post subject: Rehab RV - Engine mount and Nose gear |
I am not a metalologist and haven't played one.
But I have talked to Harmon Lange, the builder of those legs. Go to his web site or call him on the phone. he has all the answers, and can sell you a new leg or straighten your old one, if feasible.
http://www.langair.com/
On Oct 21, 2011, at 5:38 , cliff dominey wrote:
| Quote: | I am trying to restore a damaged RV8A. Nose gear leg is stuck in the engine mount, and I am thinking about heat application while it is in the hydraulic press.
C Dominey
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
chaskuss(at)yahoo.com Guest
Posted: Fri Oct 21, 2011 5:20 am Post subject: Rehab RV - Engine mount and Nose gear |
Cliff
The gear legs are heat treated. Re-heating will destroy that. Best to order new parts.
--- On Fri, 10/21/11, cliff dominey <csdjbtexas(at)live.com> wrote:
Subject: Rehab RV - Engine mount and Nose gear
To: rv-list(at)matronics.com
Date: Friday, October 21, 2011, 7:38 AM
C Dominey
[url=/mc/compose?to=csdjbtexas(at)live.com]csdjbtexas(at)live.com[/url]
| [quote][b]
d-burton(at)comcast.net Guest
Posted: Fri Oct 21, 2011 6:41 am Post subject: Rehab RV - Engine mount and Nose gear |
This is a much more complex problem then just the melting point of steel. The atoms in steels have been specifically arranged during manufacturing to produce the desired mechanical properties. There are many complex structures in the steel at an atomic level. You can influence these properties by applying both heat or cold. The sinking of the Titanic is an example of this. The atomic structure of the steel (and its strength) was altered by the cold water temperatures causing the rivets to fail at a fraction of their room temperature strength. This was an unknown property at the time. While this property is transitory and changes with temperature, the altering of the atomic structure of the material by heat, impact or deformation is permanent until altered by the application of these inputs again.
Where this can bite you badly is by inadvertently heating a localized area of a larger piece. The entire part doesn't get very hot, but some small part of it does. The large part can act as a heat sink causing rapid cooling of the small area that has been heated. This is exactly like quenching a knife blade to make it hard enough to allow it to hold an edge. This hard and brittle localized area in an larger area of softer material will cause stresses to concentrate there and cause cracking.
This was identified as a huge problem with untrained people welding hitches onto vehicles which subsequently failed at weld/frame junction (not the weld itself) that it was outlawed. You may have noticed that aftermarket hitches are all bolted on now. Only a certified welder is allowed to weld a hitch on and most insurance companies are not OK with allowing even them to do this.
You can probably carefully warm the engine mount enough to help loosen the gear leg without danger. You probably shouldn't apply heat to the leg.
Striking the parts can help to loosen the bond between them. You must be careful to use a soft non-ferrous hammer or drift so you don't damage the parts.
The bond that is preventing you from separating the two parts is frequently caused by corrosion products, so using a penetrating oil can be useful. Use one safe for steel. Use a lot, over a long period of time. It make take quite a while for the oil to wick through the entire joint.
I am suspicious that in your case the engine mount has been deformed by the impact that caused the damage to the aircraft and this is preventing the gear leg from being removed. The impact to the engine mount may have done other damage to it and having the mount inspected might be wise.
I'm sure you are like me and want to do this yourself. I suspect that if you get this problem to the engine mount manufacturer they can solve it for you. It might involve removing a section of the mount and replacing it. They can do this without damaging the gear leg. Finding out at this point that the mount is bent or cracked would be preferable to having problems later...
Good luck,
David
(Former material scientist and accident investigator)
Posted: Fri Oct 21, 2011 10:32 am Post subject: Rehab RV - Engine mount and Nose gear |
On 10/21/2011 06:38 AM, cliff dominey wrote: | Quote: | I am trying to restore a damaged RV8A. Nose gear leg is stuck in the engine mount, and I am thinking about heat application while it is in the hydraulic press.
C Dominey
| If it's rust that's causing your problem, try googling 'acetone and automatic transmission fluid'.
(It works for me; I now keep a pump-oil can handy when working on old equipment.)
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Fri Oct 21, 2011 11:35 am Post subject: Rehab RV - Engine mount and Nose gear |
Since you have the mount off try using your rivet gun with a flush set to tap on the end of the gear leg. It doesn’t have to be real strong – about the same as for AN3 rivets. It works like magic to install and remove the close tolerance spar bolts where brute force fails. It’s a good idea to prep it with penetrating oil like Kroil. It’s excellent but hard to find.
Greg Young
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Charlie England
Sent: Friday, October 21, 2011 12:54 PM
Subject: Re: Rehab RV - Engine mount and Nose gear
C Dominey
(It works for me; I now keep a pump-oil can handy when working on old equipment.)[quote] [b]
Posted: Fri Oct 21, 2011 12:00 pm Post subject: Rehab RV - Engine mount and Nose gear |
Get Kroil from Kano Labs. Google 'kroil' for a special deal. And don't blow it off for price. The stuff is worth it.
Linn
On 10/21/2011 3:20 PM, Greg Young wrote: [quote] <![endif]--> <![endif]-->
Greg Young
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Charlie England
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
C Dominey
(It works for me; I now keep a pump-oil can handy when working on old equipment.) [b]
Linn
Greg Young
C Dominey
Kellym
Posted: Fri Oct 21, 2011 7:17 pm Post subject: Rehab RV - Engine mount and Nose gear |
The previously mentioned acetone with ATF works better in penetrating
and freeing parts than any commercial product, almost by a factor of 2.
On 10/21/2011 12:20 PM, Greg Young wrote:
but hard to find.
Greg Young
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *Charlie England
*Sent:* Friday, October 21, 2011 12:54 PM
*To:* rv-list(at)matronics.com
*Subject:* Re: Rehab RV - Engine mount and Nose gear
down period.
C Dominey
csdjbtexas(at)live.com <mailto:csdjbtexas(at)live.com>
equipment.)
KCHD |
