fdombroski
Posted: Wed Oct 26, 2011 1:05 pm Post subject: Sealing Baggage Rear Bulkhead |
I am getting a significant draft in the back seat from the channels on the bulkhead at the aft end of the baggage compartment. What has been used to seal the gaps created by the corrugated grooves?
Frank
_________________ Frank Dombroski
Multiple Offender RV-8, 7A, 10 x 2
RV-10 2.0 N46VT 2015
KSMQ Somerset Airport NJ |
rene(at)felker.com Guest
Posted: Wed Oct 26, 2011 3:09 pm Post subject: Sealing Baggage Rear Bulkhead |
I have an interior from Abbey at Flightline. Part of the kit is a cover
that goes over the bulkhead and extends to the cabin wall. It limits the
amount of air that gets through.
Rene' Felker
N423CF
801-721-6080
Posted: Wed Oct 26, 2011 4:10 pm Post subject: Sealing Baggage Rear Bulkhead |
Do you have your door seals on yet? If not, that will probably make the difference.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Oct 26, 2011, at 5:05 PM, "fdombroski" <f.dombroski(at)yahoo.com> wrote:
Frank
Frank Dombroski
RV-10 N10FD Flying
RV-8 N84FD Finished and sold :-{
http://forums.matronics.com/viewtopic.php?p=356049#356049
Albert Gardner
Posted: Wed Oct 26, 2011 4:45 pm Post subject: Sealing Baggage Rear Bulkhead |
I filled them with RTV, left it a little proud, covered the edge of the bulkhead with clear tape so that the RTV would not stick to the frame, and then installed the bulkhead and let the RTV cure.
Albert Gardner
Yuma, AZ
N991RV
Jesse Saint <jesse(at)saintaviation.com> wrote:
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
> Thanks
> Frank
> Frank Dombroski
> RV-10 N10FD Flying
_________________ RV-9A N872RV
RV-10 N991RV |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Oct 26, 2011 4:54 pm Post subject: Re: Sealing Baggage Rear Bulkhead |
I have the 4 vents that are built from the plans plus the 4 vents in the overhead console. I have the mcmastercarr seal that seals up all around the doors. Sometimes I wonder where all the air is going or if it is pressurizing the cabin:). It might be nice to have those open so there is somewhere for the air to go. Built in outflow valves. Maybe I'm crazy. I guess in the winter it would be nice to close them up. The tail has all the holes but I sealed up most in the forward fuselage.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
gengrumpy(at)aol.com Guest
Posted: Wed Oct 26, 2011 6:09 pm Post subject: Sealing Baggage Rear Bulkhead |
I used a sheet of 1/2 inch foam rubber treated with fire retardant and glued it to the back of the 2 removable bulkhead pieces.
Solved the problem for me.
Got my foam from Flightline Interiors.
grumpy
N184JM
On Oct 26, 2011, at 4:05 PM, fdombroski wrote:
Frank
Frank Dombroski
RV-10 N10FD Flying
fdombroski
Posted: Wed Oct 26, 2011 6:42 pm Post subject: Re: Sealing Baggage Rear Bulkhead |
The doors are sealed. I have the 4 fuse vents, plus 4 overhead vents. I have plenty of airflow in the summer. At altitude, and during the winter the cold air from the tail cone is flowing aggressively past the rear baggage bulkhead. This is the corrugated structure.
Looks like 1/2 inch foam is the probable solution.
Frank
rv10flyer
Posted: Fri Oct 28, 2011 5:05 am Post subject: Re: Sealing Baggage Rear Bulkhead |
I sealed off aileron pushrod openings, wing spar openings, still need to do baggage bulkhead and elevator pushrod at rear spar.
_________________ Wayne G. |
