l_luv2_fly(at)yahoo.com Guest
Posted: Sun Nov 27, 2011 1:21 pm Post subject: Source for Wire wrap PCB stakes |
Hi All,
Way back a while, wire wrapping was all the rage and I used to be able to buy a PCB wire wrap pin. I am looking for these again and the nearest thing I can find is ED5002-ND from Digikey. Apart from the fact that these are .33cents each, they at not what I am looking for. The ED5002-ND appears to be a wire wrap socket. All I am looking for is a simple stake that is soldered to the board as a wire wrap post.
If anyone could direct me to a source I'd appreciate it.
Thanks, Paul
mikerv6a(at)ao-cs.com Guest
Posted: Sun Nov 27, 2011 7:39 pm Post subject: Source for Wire wrap PCB stakes |
You can find several sizes of wire wrap pins from Keystone
Electronics in part numbers 5070 through 5083. Another option
is purchase of wire wrap DIP IC sockets, then cut pins off
the sockets to obtain single pins.
Thanks, Paul
kuffel(at)cyberport.net Guest
Posted: Mon Nov 28, 2011 9:22 am Post subject: Source for Wire wrap PCB stakes |
Paul,
<< PCB wire wrap pin. I am looking for these again and the nearest thing I can find is ED5002-ND from Digikey. Apart from the fact that these are .33cents each >>
Mouser sells the Vector wire wrap pins. 574-T68/C is 100 bifurcated posts for $10.71 or 574-T46-4-9/C straight posts for $10.45.
Tom Kuffel
Posted: Mon Nov 28, 2011 10:10 am Post subject: Source for Wire wrap PCB stakes |
Tom,
Thank you, this is exactly what I was looking for. Although I had searched Digikey & Mouser I was obviously not using the correct name.
Thanks again, Paul
Sent: Monday, November 28, 2011 11:18 AM
Subject: Re: Source for Wire wrap PCB stakes
Paul,
Tom Kuffel
