rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Thu Sep 22, 2011 6:10 am Post subject: Engine mounting |
Are the engine mount attach points on the firewall the same for the I through IV model aircraft, or did the attach points change as the fuselage got wider? Meaning, can you buy a mount that was made for a model I or model III and put it on a model IV?
_________________ Kitfox IV-1200
Indianapolis, IN |
rawheels
Posted: Fri Sep 23, 2011 9:17 am Post subject: Re: Engine mounting |
For the record, here is what I got from the factory:
The mounts on the early models that were manufactured by the factory, Were from a template the builder would have to send back…No fixture during that era .. So each engine mount could vary slightly.. This mainly applies to the M1…
Most of the 2’s & 3’s should interchange.
But there is no good way to know 100% without taking mount & mount point measurements. |
Indianapolis, IN |
Ken Potter
Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
Posted: Tue Nov 29, 2011 2:49 pm Post subject: Re: Engine mounting |
I repowered my Model II from Rotax to HKS using a Green Skys mount. The mount they sent fit the plane perfectly sight unseen.... leading me to believe that at serial # 482 the factory jigging was correct and planes in model II III range were similar
KP
_________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
