cdnch701builder
Posted: Tue Nov 22, 2011 9:46 am Post subject: 1 Wire vs. 3Wwire alternators |
I need some help here with alternators! What is the difference between a 1 wire and a 3 wire
system?
Can a 1 wire setup be shut down with a switch as per over voltage protection... or does it have
to be a 3 wire?
Ron
_________________ cdnch701builder |
Posted: Tue Nov 22, 2011 11:30 am Post subject: 1 Wire vs. 3Wwire alternators |
system?
I'm not sure there's a uniform convention for
1 versus 2 versus 3 wire alternators. The
1-wire alternators I see for boats, RVs and
utility vehicles have regulators built in. They
have ONE b-lead that connects to the system and
they automatically shut down internally when
the alterantor is not turning.
Quote: | Can a 1 wire setup be shut down with a switch as per over voltage protection
No
Quote: | ... or does it have
to be a 3 wire?
It certainly needs to have more than one wire, the
second of which offers absolute control over field
excitation. Check out B&C or Plane Power. They've
provided for satisfaction of the legacy philosophy for
putting alternators on airplanes.
cdnch701builder
Posted: Thu Dec 01, 2011 1:19 pm Post subject: 1 Wire vs. 3Wwire alternators |
Thanks bob...
I have a 3 wire internally regulated alternator... that I would like to convert to external
regulator!
Is there any info online somewhere that provides instructions to do the conversion? I have
been searching and I cannot find!
Ron
:--)> <nuckolls.bob(at)aeroelectric.com>
:--)> At 11:43 AM 11/22/2011, you wrote:
:--)>:--)> I need some help here with alternators! What is the difference
:--)>:--)> between a 1 wire and a 3 wire
:--)>:--)> system?
:--)> I'm not sure there's a uniform convention for
:--)> 1 versus 2 versus 3 wire alternators. The
:--)> 1-wire alternators I see for boats, RVs and
:--)> utility vehicles have regulators built in. They
:--)> have ONE b-lead that connects to the system and
:--)> they automatically shut down internally when
:--)> the alterantor is not turning.
:--)>:--)> Can a 1 wire setup be shut down with a switch as per over voltage protection
:--)> No
:--)>:--)> ... or does it have
:--)>:--)> to be a 3 wire?
:--)> It certainly needs to have more than one wire, the
:--)> second of which offers absolute control over field
:--)> excitation. Check out B&C or Plane Power. They've
:--)> provided for satisfaction of the legacy philosophy for
:--)> putting alternators on airplanes.
:--)> Bob . . .
Posted: Thu Dec 01, 2011 6:22 pm Post subject: 1 Wire vs. 3Wwire alternators |
At 03:13 PM 12/1/2011, you wrote:
Quote: |
Thanks bob...
regulator!
It varies from one brand and model to the next. An
alternator repair shop could open it up and easily
identify the means by which the internal regulator
could be by-passed. I've seen some articles but don't
recall now where . . . Sorry.
Perhaps somebody here on the List will recall some
exemplar articles.
jonlaury
cdnch701builder
Joined: 28 Mar 2008 Posts: 1942 Location: Riley TWP Michigan
mrspudandcompany(at)veriz Guest
Posted: Fri Dec 02, 2011 9:42 am Post subject: 1 Wire vs. 3Wwire alternators |
Quote: | I have a 3 wire internally regulated alternator... that I would like
regulator!
Here is one from the EAA Website
http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp
Roger
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
3.62 KB |
Downloaded: |
613 Time(s) |
cdnch701builder
Posted: Fri Dec 02, 2011 10:04 am Post subject: 1 Wire vs. 3Wwire alternators |
Thanks Roger...
Ron
:--)>:--)> I have a 3 wire internally regulated alternator... that I would like to
:--)>:--)> convert to external regulator!
:--)> Here is one from the EAA Website
:--)> http://www.eaa.org/experimenter/articles/2009-09_howto_alternator.asp
:--)> Roger
cdnch701builder
Posted: Sat Dec 03, 2011 7:48 am Post subject: Re: 1 Wire vs. 3Wwire alternators |
cdnch701builder
Ron,
Are you using a Viking engine?
I am no alternator expert. But if your alternator has 3 wires, One of them could be used for enabling the alternator. The over-voltage protection should be in series with that wire. There could be an internal regulator failure mode that does not respond to removing power from that wire. The safest way is to remove the internal regulator and use an external one.
Many builders are reluctant to modify a perfectly good working alternator in order to achieve over-voltage protection. An over-voltage condition is unlikely but could be very expensive if it happens. Some modern avionics are able to operate with supply voltages in the range of 10 to30. They are less likely to be damaged. In case of an over-voltage condition, an alternator with an ampacity that matches the expected aircraft load will not generate as high of a voltage as an over-sized alternator will.
Joe
_________________ Joe Gores |
