		Jimz
				 Posted: Wed Dec 14, 2011 8:52 am    Post subject: Pre oiling new rebuild |
				I have a fresh rebuilt 0-200 that I want to pressure oil  before the first startup.  Where is the best place to hook the pressure  line in? The oil filter, oil pressure sender, oil temp sender or one  of the plugs in the front of the case? Also, how about 30 weight break-in oil  this time of the year in Minnesota?  20 degrees F.     Thanks          jezim(at)pro-ns.net (jezim(at)pro-ns.net)
  |  | - The Matronics Continental-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		BARRY CHECK 6
				 Posted: Wed Dec 14, 2011 9:17 am    Post subject: Pre oiling new rebuild |
				J:
 I use the OIL COOLER threads.
 I want to do this but have not had the chance:  Remove one of the Oil Plugs on the front of the engine.  Pump the oil in at the Oil Cooler and SEE if the oil reaches the front of the engine.
 As for the type of oil:  20W-50 Multi grade. Are yo breaking in the engine?  If so Philips makes a recommended 20W-50 Non-AD oil.
 BUT!  Times they are a changing... Some Mfg. now recommend 20W-50 AD oil for break-in.    And that is the way I went. No Problem...  550+ Hrs since new.
 Barry
 On Wed, Dec 14, 2011 at 11:50 AM, Zimmermans <jezim(at)pro-ns.net (jezim(at)pro-ns.net)> wrote:
  [quote]       I have a fresh rebuilt 0-200 that I want to pressure oil  before the first startup.  Where is the best place to hook the pressure  line in? The oil filter, oil pressure sender, oil temp sender or one  of the plugs in the front of the case? Also, how about 30 weight break-in oil  this time of the year in Minnesota?  20 degrees F.     Thanks          jezim(at)pro-ns.net (jezim(at)pro-ns.net)
		vk3eka(at)bigpond.net.au Guest
				 Posted: Wed Dec 14, 2011 11:12 am    Post subject: Pre oiling new rebuild |
				Hi,
 I used the oil pressure sender line. 30 weight sounds good to me but it is a little warmer in Australia
 Cheers
 Peter
 Wonthaggi Australia
 From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Zimmermans
 Sent: Thursday, 15 December 2011 3:50 AM
 To: continental-list(at)matronics.com
 Subject: Pre oiling new rebuild
 01234567890123456789012
		oldernut
  Joined: 28 Jan 2011 Posts: 46 Location: Hendersonville NC
				 Posted: Wed Dec 14, 2011 1:50 pm    Post subject: Pre oiling new rebuild |
				That's amazing. I was just about to ask the same question about my A-65.
       Dave
		Blue Sky
				 Posted: Wed Dec 14, 2011 3:45 pm    Post subject: Pre oiling new rebuild |
				What did you use as a pressure source? I am starting a C85 in January.
  Lyle
   Date: Wed, 14 Dec 2011 12:15:08 -0500
 Subject: Re: Pre oiling new rebuild
 J:
  Barry
 _blank>www.aeroelectric.com
 /" target=_blank>www.buildersbooks.com
 =_blank>www.homebuilthelp.com
 =_blank>http://www.matronics.com/contribution
 List" target=_blank>http://www.matronics.com/Navigator?Continental-List
 ttp://forums.matronics.com
  _________________ My passion for the landscape has lead me to the sky. |
				 Posted: Wed Dec 14, 2011 11:17 pm    Post subject: Pre oiling new rebuild |
				Hi,
 I used an old gas cylinder (5 pounds ish!) with a schrader valve incorporated in the top of the cylinder and a hose connecting to the oil pressure outlet on the engine.  I used a small compressor to pressurise the cylinder pumping oil into all engine cavities.
 All worked well.
 Cheers
 Peter
 From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Lyle Fast
 Sent: Thursday, 15 December 2011 10:43 AM
 Subject: RE: Pre oiling new rebuild
 Lyle
 J:
 Barry
  	  | Quote: | 	 		  |    _blank>www.aeroelectric.com/" target=_blank>www.buildersbooks.com=_blank>www.homebuilthelp.com=_blank>http://www.matronics.com/contributionList" target=_blank>http://www.matronics.com/Navigator?Continental-Listttp://forums.matronics.com=_blank>http://www.matronics.com/contribution  | 	  0
 1234567890123456789 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  0 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  1 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  2 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  3 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  4 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  5 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  6 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  7 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  8 	  | Quote: | 	 		  | _blank>www.aeroelectric.com | 	  9 	  | Quote: | 	 		  | /" target=_blank>www.buildersbooks.com | 	  0 	  | Quote: | 	 		  | /" target=_blank>www.buildersbooks.com | 	  1 	  | Quote: | 	 		  | /" target=_blank>www.buildersbooks.com | 	  2 	  | Quote: | 	 		  | /" target=_blank>www.buildersbooks.com | 	  3
		BARRY CHECK 6
				 Posted: Thu Dec 15, 2011 6:33 am    Post subject: Pre oiling new rebuild |
				Peter:
 Did you remove the remove the front oil plug to see if the oil made it all the way up front?
 Barry
 On Thu, Dec 15, 2011 at 2:14 AM, Peter W Johnson <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)> wrote:
 Hi,
 All worked well.
 Cheers
 Peter
 From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of Lyle Fast
 To: continental-list(at)matronics.com (continental-list(at)matronics.com)
 Lyle
 From: flyadive(at)gmail.com (flyadive(at)gmail.com)
 J:
 Barry
 123 45 678901 23 456 7890
 1 23
		Blue Sky
				 Posted: Thu Dec 15, 2011 7:49 am    Post subject: Pre oiling new rebuild |
				That sounds about right, I'll see if I can find a clean one.
  What are people thinking about ground run ups during break in? This engine has not run since rebuild and won't fly till next summer. I would like to prove it runs, tune it and do some static runs with the new prop out side my shop in cool/cold conditions. I can monitor CHT and have been thinking about auxiliary cooling air for these runs. I understand low rpm running is not good but what about static runs at close to 70% rpm/power?
  Lyle
 Date: Thu, 15 Dec 2011 18:14:20 +1100
    .ExternalClass .ecxshape {;}    .ExternalClass p.ecxMsoNormal, .ExternalClass li.ecxMsoNormal, .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:"Times New Roman","serif";} .ExternalClass a:link, .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:"Times New Roman","serif";} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:"Courier New";} .ExternalClass span.ecxHTMLPreformattedChar {font-family:Consolas;} .ExternalClass span.ecxEmailStyle20 {font-family:"Calibri","sans-serif";color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page WordSection1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxWordSection1 {page:WordSection1;}
 Hi,
 All worked well.
 Cheers
 Peter
 Lyle
 J:
 Barry
  	  | Quote: | 	 		  | /" target=_blank>www.buildersbooks.com | 	  4
		BARRY CHECK 6
				 Posted: Thu Dec 15, 2011 8:34 am    Post subject: Pre oiling new rebuild |
				Lyle:
 Ground Run-Up are NOT recommended.
 Engine shops have CLUBS (Small Diameter Props usually made of wood to keep them light) for ground run-ups.
 A standard prop will not reach the required RPM and the engine will not reach break-in temperatures.
 You also will not cool the engine properly.
 More damage will be done ground running than flying for 300 hours. <-- Rule of thumb.
 I have installed and broken in about 6 engines - I NEVER ran the engine on the ground for more time than to adjust idle, mixture and movement of cables.
  GO FLY!
 Barry
 On Thu, Dec 15, 2011 at 10:47 AM, Lyle Fast <lylefast(at)hotmail.com (lylefast(at)hotmail.com)> wrote:
   	  | Quote: | 	 		      That sounds about right, I'll see if I can find a clean one.
   Lyle
   From: vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)
 Hi,
 All worked well.
 Cheers
 Peter
 Lyle
 Subject: Re: Continental-List: Pre oiling new rebuild
 J:
 Barry
 1234 5678901 23 4567 890123 45678 9012 3
		Blue Sky
				 Posted: Thu Dec 15, 2011 8:55 pm    Post subject: Pre oiling new rebuild |
				Barry,
    Nice clear answer, nothing wishy washy about that!
  Thanks, Lyle
   Date: Thu, 15 Dec 2011 11:31:23 -0500
 Lyle:
  GO FLY!
  Barry
  [quote]  That sounds about right, I'll see if I can find a clean one.
 Lyle
   Hi,
  All worked well.
  Cheers
  Peter
 Lyle
 J:
   Barry
 123456789012345678901234567890123
				 Posted: Thu Dec 15, 2011 10:17 pm    Post subject: Pre oiling new rebuild |
				Barry,
 No, I just pumped oil into the pressure gauge hole and all worked perfectly after.
 Cheers
 Peter
 From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of FLYaDIVE
 Sent: Friday, 16 December 2011 1:31 AM
 Peter:
 Barry
 Hi,
 All worked well.
 Cheers
 Peter
 Lyle
 J:
 Barry
 3456789
 01
 2345678901
 234567890123456789012345678901234
		BARRY CHECK 6
				 Posted: Fri Dec 16, 2011 5:21 am    Post subject: Pre oiling new rebuild |
				Hey Peter are you VK3EKA?
 I'm WB2ZDH
 OK, on the pre-oil.  As I said, I never tried it but I think it would be a great way to verify that the oil is getting all around.
 Another TRICK.  Install an oil temp probe in the 1/8" NPT thread in the front of the case.  You will get REAL temp reading that really mean something.  They will be of the FRONT bearing.  I have heard of 25 Deg F differences between the front and rear of the case.
 Barry
 On Fri, Dec 16, 2011 at 1:14 AM, Peter W Johnson <vk3eka(at)bigpond.net.au (vk3eka(at)bigpond.net.au)> wrote:
 Barry,
 Cheers
 Peter
 From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of FLYaDIVE
 Peter:
 Barry
 Hi,
 All worked well.
 Cheers
 Peter
 Lyle
 J:
 Barry
 345 67 89
 01
 2345 67 89 01
 2345 678901 23 456 789012 34 567 89012 34
   5
