Jacquescj6
Joined: 20 Dec 2011 Posts: 23 Location: Swakopmund , Namibia
Posted: Tue Dec 20, 2011 10:42 pm Post subject: Cj6 wings |
Hi Guys
Has anybody had a problem with a cj6 wing thats a bit loos. I have one that the left wing moves a little bit at the joints not much but there are movement. Anybody know of a fix for this?
samira.h(at)shaw.ca Guest
Posted: Wed Dec 21, 2011 6:14 am Post subject: Cj6 wings |
Hi Jacques,
if you are still within the
designer's tolerances you
could ream the holes to the
next diameter and use over-sized
wing bolts (I think Doug Sapp
sells them).
cheers
Elmar
k7wx
Posted: Wed Dec 21, 2011 6:15 am Post subject: Cj6 wings |
Dear Jacques,
If the movement you describe is at the four wing attach points, wear in this area is likely the cause. Doug Sapp has a special set of the large and smaller wing attachment bolts that are slightly over-sized and made to address this problem. This has come up often enough that these bolts are the recommended fix.
Warren Hill
N464TW
On Dec 20, 2011, at 11:38 PM, Jacques Jacobs wrote:
[quote]Hi Guys
Posted: Wed Dec 21, 2011 8:49 am Post subject: Cj6 wings |
You need oversized wing bolts. Mic the ID of the fittings and drop me a email off line.
Best,
Doug Sapp
On Tue, Dec 20, 2011 at 10:38 PM, Jacques Jacobs <jacobscj6(at)yahoo.com (jacobscj6(at)yahoo.com)> wrote:
[quote] Hi Guys
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
et="_blank">http://www.matronics.com/Navigator?Yak-List
tp://forums.matronics.com
