Blue Sky
				 Posted: Mon Jan 16, 2012 11:12 am    Post subject: Pre oiling new rebuild |
				This is what I came up with(see photo) about $20 at the hardware store, clean, will hold a gallon, goes 40# plus on hand pump, hose attached. Should be useful for all kinds of engines that don't run often around my place.
  Lyle
       	  | Quote: | 	 		        Hi,
 I used an old gas cylinder (5 pounds ish!) with a schrader valve incorporated in the top of the cylinder and a hose connecting to the oil pressure outlet on the engine.  I used a small compressor to pressurise the cylinder pumping oil into all engine cavities.
 All worked well.
 Cheers
 Peter
   From: owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com) [mailto:owner-continental-list-server(at)matronics.com (owner-continental-list-server(at)matronics.com)] On Behalf Of Lyle Fast
 Sent: Thursday, 15 December 2011 10:43 AM
 To: continental-list(at)matronics.com (continental-list(at)matronics.com)
 Subject: RE: Pre oiling new rebuild
  What did you use as a pressure source? I am starting a C85 in January.
 Lyle
 Date: Wed, 14 Dec 2011 12:15:08 -0500
 Subject: Re: Continental-List: Pre oiling new rebuild
 From: flyadive(at)gmail.com (flyadive(at)gmail.com)
 J:
  I use the OIL COOLER threads.
  I want to do this but have not had the chance:  Remove one of the Oil Plugs on the front of the engine.  Pump the oil in at the Oil Cooler and SEE if the oil reaches the front of the engine.
  As for the type of oil:  20W-50 Multi grade. Are yo breaking in the engine?  If so Philips makes a recommended 20W-50 Non-AD oil.
  BUT!  Times they are a changing... Some Mfg. now recommend 20W-50 AD oil for break-in.    And that is the way I went. No Problem...  550+ Hrs since new.
  Barry
   On Wed, Dec 14, 2011 at 11:50 AM, Zimmermans <jezim(at)pro-ns.net (jezim(at)pro-ns.net)> wrote:
   I have a fresh rebuilt 0-200 that I want to pressure oil before the first startup.  Where is the best place to hook the pressure line in? The oil filter, oil pressure sender, oil temp sender or one of the plugs in the front of the case? Also, how about 30 weight break-in oil this time of the year in Minnesota?  20 degrees F.    Thanks          jezim(at)pro-ns.net (jezim(at)pro-ns.net)
 123456789012345678901234567890123
 /" target=_blank>www.buildersbooks.com | 	  6
  |  | - The Matronics Continental-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Continental-List |
  _________________ My passion for the landscape has lead me to the sky. |
