barrynorman(at)comcast.ne Guest
Posted: Mon Jan 16, 2012 4:55 pm Post subject: Fuel pressure sending unit |
I notice on occasion the EIS will warn fuel pressure is outside normal parameters on the high side. For example it will read momentarily 8.8 psi and then go back to normal. My suspicion is the EIS fuel pressure sensor is going bad since the mechanical fuel pump should never supply pressures that high. Has anyone else ever had this problem? The engine sounds like it is running perfect and I don't notice a change in fuel flow either.
Barry
| - The Matronics Pulsar-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
331bp
Posted: Mon Jan 16, 2012 6:39 pm Post subject: Fuel pressure sending unit |
I had that same problem and traced it to a bad ground. On mine it would only happen when I had several things turned on. Check to see if it changes depending on the electrical load. If so, check the ground between the engine and the point where the eis grounds.
Bill Coleman
PulsarXP N331BP
-- Sent from my HP TouchPad
On Jan 16, 2012 8:06 PM, barrynorman(at)comcast.net <barrynorman(at)comcast.net> wrote:
Barry
nc-baehrdi(at)netcologne. Guest
Posted: Tue Jan 17, 2012 12:15 am Post subject: Fuel pressure sending unit |
The permanent vibrations can harm the fuelpressuresenders mechanics.I attached mine with a soft rubbermount.
Dieter Bähr
Pulsar XP D-EKDT
Am 17.01.2012 03:38, schrieb pulsar331(at)sbcglobal.net: ([email]pulsar331(at)sbcglobal.net:[/email]) [quote]I had that same problem and traced it to a bad ground. On mine it would only happen when I had several things turned on. Check to see if it changes depending on the electrical load. If so, check the ground between the engine and the point where the eis grounds.
Bill Coleman
PulsarXP N331BP
On Jan 16, 2012 8:06 PM, barrynorman(at)comcast.net (barrynorman(at)comcast.net) <barrynorman(at)comcast.net> (barrynorman(at)comcast.net) wrote:
Barry
