Malcolmbru(at)aol.com Guest
Posted: Wed May 24, 2006 5:42 pm Post subject: water temp 582 |
I think my KF2 is ready to fly but the water temp is 185 on static run up
egt,s are good any body got a good way of checking the water temp gage /
sender? Like an inferred thermostat gun or something? how much radiator fluid
should be in the small bottle cold and hot?
akfotoman
Joined: 19 Apr 2006 Posts: 120 Location: Anchorage, Alaska
Posted: Wed May 24, 2006 6:00 pm Post subject: water temp 582 |
During break-in I found it hard to keep my water temp below 190F and it even
flies at 185F and when climbing 190F. I took out the thermostat, put in a
thermometer and checked the water temp,( engine off) and also checked the
thermostat opening temp by putting it in hot H20 with a thermometer to
monitor that also.
Some engines run hotter than others, and some gauges are not as accurate as
they claim to be.
RS
They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety." - Benjamin Franklin
_________________ Have cameras, will travel! |
Aerobatics(at)aol.com Guest
Posted: Wed May 24, 2006 6:31 pm Post subject: water temp 582 |
In a message dated 5/24/2006 9:01:27 P.M. Central Daylight Time,
foto(at)alaska.net writes:
monitor that also.
they claim to be.
RS
About a year ago I flew my KF to Rotax service center for a 150 hour carbon
looksie. I dont want to say who, but the did a REALLY nice job, but man it
all of a sudden ran "hot".
The short story is, the ratio of water to Glycol is VERY important. Water
is much better at taking away heat than the Glycol. When we drained and
properly measured the ratio 50/50, instant 180!
Something else to consider...
Dave
torgemor(at)online.no Guest
Posted: Thu May 25, 2006 12:58 pm Post subject: water temp 582 |
Hi Mal,
Check your water temp system by use of a boiling kettle, put the water
temp tip into the boiling water -then read 210 deg. F at your indicator
(remember to set the master switch to on as the water temp system need 12
VDC for working).
For further fault finding got to Westach:
http://www.westach.com/repair.htm
then roll down to: "WATER, OIL, AIR, and CARBURETOR TEMPERATURE" section.
good luck.
regards
Torgeir.
On Wed, 24 May 2006 21:41:41 EDT, <Malcolmbru(at)aol.com> wrote:
up
fluid
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Posted: Thu May 25, 2006 1:52 pm Post subject: water temp 582 |
Sorry Mal, a correction here - you should read 212 deg. F (100 deg C) -
equal to the temp of boiling water (at sea level of course. )
Torgeir.
On Thu, 25 May 2006 22:55:07 +0200, Torgeir Mortensen <torgemor(at)online.no>
wrote:
Hi Mal,
VDC for working).
good luck.
regards
Torgeir.
> up
> fluid
msm_9949(at)yahoo.com Guest
Posted: Thu May 25, 2006 2:32 pm Post subject: water temp 582 |
Mal -
Another consideration is that with a static test run, there's very little airflow passing through your radiator. Some have suggested that you hose down the radiator during static testing to keep temps down. If you didn't do something like that, you may well see that 185 reading drop to 170 or below when you're blowing 65 mph air thru the rad.
Torgeir Mortensen <torgemor(at)online.no> wrote:
Hi Mal,
VDC for working).
good luck.
regards
Torgeir.
On Wed, 24 May 2006 21:41:41 EDT, wrote:
up
fluid
Marco Menezes
Model 2 582 N99KX
Get on board. You're invited to try the new Yahoo! Mail Beta.
bmwebb(at)cox.net Guest
Posted: Thu May 25, 2006 3:05 pm Post subject: water temp 582 |
Oh, yeah. This works, by golly!
But man, you should have heard the ass-chewing when she came home and found
the dining room table and chairs in the lawn, and a Kitfox in the kitchen.
My butt's still sore...
Bradley
bnn(at)nethere.com Guest
Posted: Thu May 25, 2006 3:45 pm Post subject: water temp 582 |
At 03:32 PM 5/25/2006, you wrote:
| Quote: | Another consideration is that with a static test run, there's very little
I wondered about this. I recently ran for about 30 minutes on the ground
with all temperatures good except the water stabilized at 190. (582.) I
assumed it was OK, since it was a ground run, but Dave Stevenson seemed to
think 190 was too high, even for a full power ground run. What do you think?
Guy Buchanan
K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar.
rexjan(at)bigpond.com Guest
Posted: Thu May 25, 2006 4:27 pm Post subject: water temp 582 |
Hi ! Malcolm,
I think in normal weather static 185 deg is to =
be expected. You have no airflow over the radiator. Mine will do this =
and yet fly on about 175 deg. At the moment we are in winter here in =
Australia and last weekend it flew at only 145 deg so really it needed a =
bit warmer. I don't think you need to worry just because you see 185 deg =
static but keep in mind all the advice you get.
Rex.
dosmythe(at)cox.net Guest
Posted: Thu May 25, 2006 5:35 pm Post subject: water temp 582 |
I'll go along with Dave Stevenson. 180 is the max Rotax spec and should be
respected whether observed on the ground, in the air or, sitting on a test
bench. Temperature is Temperature.
Don Smythe
dave(at)cfisher.com Guest
Posted: Fri May 26, 2006 3:15 am Post subject: water temp 582 |
I have been to Rotax seminars and it has been discussed .
176 F is the Rotax spec as Maximum but the consensus was that 180 to 200 is
the caution area.
Over 200F is the danger zone. Once you boil over you will most likely see
some cylinder damage. Now where it boils over ? Well Water alone is 212 F
and with Antifreeze a bit higher.
Needless to say I hope everyone uses distilled water and dexcool only . If
not Kiss your RV shaft and seals good bye at some point.
I have a 582 and the rad is attached just about under the control stick.
Seems to work fine there and on 90F days I will see 190F on climbout but it
will cruise 160 to 180 F . I have seen foxes with the Rad too far forward
and get really bad cooling. I think the farther back the better and also a
new rad maybe a few inches wider and a bit thicker would help too I think.
Also temp gauges are not certified accurate so once gauge at 190 F might be
170 or 195 in reality.
Here is a link to a Rotax shop that does seminars.
http://www.rotaxservice.com/documents/2STref.pdf
Dave
algate(at)attglobal.net Guest
Posted: Fri May 26, 2006 4:33 am Post subject: water temp 582 |
When I ran my 582 in on the ground I experienced similar temps at WOT. I ran
a hose to the outside of the rad and applied additional cooling to keep
temps below 180 for the remainder of the run in period
Once it was in the air I still had initial problems with high temps but
solved this by lowering the rad 1" to get better airflow. I believe this is
a pretty common mod that most 582 owners have done.
My temps since then are 175 on Climb (sometimes 180 on extended climb in
summer) and 170 in cruise
Gary Algate
Mal -
Posted: Fri May 26, 2006 7:27 am Post subject: water temp 582 |
At 04:27 AM 5/26/2006, you wrote:
| Quote: | One thing I would like to add is on initial start up and Break - in you can
attach a garden hose in front of rad to allow for the extra cooling you may
need on ground.
Your Rotax breakin for new engines should be just over 1 hour in length and
with spurts up to 6500 RPM .
Dave,
Fortunately Bob Robertson already broke the engine in on the bench
some years ago. I'm just checking systems now. The water is a good idea,
though I'll have to dig around at the airport to get some.
My main question was whether 190 on the ground results in
something less in the air. Nobody's said anything definitive either way so
I'll just have to try it.
Guy Buchanan
At 05:34 AM 5/26/2006, you wrote:
| Quote: | When I ran my 582 in on the ground I experienced similar temps at WOT. I ran
Thanks Gary,
I've got the Skystar radiator cowl which I've reworked so all the
inlet flow goes through the radiator. The interesting thing is that my
round cowl has an exhaust protrusion which appears to block about half the
radiator inlet! My only hope is that 1) the radiator cowl has more inlet
than necessary; and 2) that I'll have excessive flow through the engine
cowl which will feed into the radiator. Unfortunately this latter will be
heated somewhat which won't be helping my cooling at all. Dropping the
radiator cowl necessitates major rework. I could also cut away the engine
cowl exhaust protrusion, but that would also look messy. Hopefully it
doesn't make first flight more exciting than necessary!
Guy Buchanan
Posted: Fri May 26, 2006 9:55 am Post subject: water temp 582 |
| Quote: | My main question was whether 190 on the ground results in
The level flying temps should be less than the ground runup temps. However,
during climbout on a hot day you may see temps over 180. During those times
I used to reduce power and step climb to keep things below 180. I do not
allow my temps to go above 180 under any circumstances. That's just my
rule. Normal cruise on the average should be around 165 or so.
Don Smythe
Posted: Fri May 26, 2006 9:57 am Post subject: water temp 582 |
I'll go out on a limb, Guy. I'll bet a beer that your 190 becomes 170 at 65 mph. Takers? But before you try it in the air, do a run-up as suggested with water from a hose directed over the rad. If it's still 190, bet's off.
need on ground.
Dave,
Guy Buchanan
Marco Menezes
Model 2 582 N99KX
Posted: Fri May 26, 2006 10:12 am Post subject: water temp 582 |
| Quote: | >solved this by lowering the rad 1" to get better airflow. I believe this
>is a pretty common mod that most 582 owners have done.>>
I had the problem and tried lowering the rad 1", 2" and then way forward.
The way forward worked the best for me (ahead of the cowl exhaust).
| Quote: | > inlet flow goes through the radiator. The interesting thing is that my
> the >>
That bothered me too. I ended up cutting off that bottom protrusion and
fiberglassing the bottom of the round cowl to be straight across. I then
added two reverse scoops on either side of the cowl to provide cowl exhaust.
Next, I fabricated a cowl for the radiator that extends the full width of
the aircraft bottom and all the way back to the aft carry thru tube. The
front inlet almost blends in with the bottom of the round cowl. All air
coming off the bottom nose of the aircraft is funneled into the rad cowl.
The new rad cowl has two independent cockpit controlled flaps on the back of
the rad. With two controls vice one, I can control the water temps under
just about any circumstance.
I spent a lot of time trying different things to keep my temps below
180. WaterWetter, no thermostat, moving radiator all over the place,
different antifreeze ratios, etc, etc. This mod seems to have done the
trick and also gives me the ability to keep temps "high" during cold weather
decents. This is valuable for go arounds when the water cools off too much.
Don Smythe
| Quote: | radiator inlet! My only hope is that 1) the radiator cowl has more inlet
Guy Buchanan
Posted: Fri May 26, 2006 10:30 am Post subject: water temp 582 |
Yes - I agree Marco.
Also I think i mentioned in last post that the further back the rad the
better the cooling. Some Avids have the rad back by the Wing Attach struts
and seem to run super cool.
Mine sits right below the control sticks in Kitfox IV and no heating issues
at all.
Dave
smokey_bear_40220(at)yaho Guest
Posted: Fri May 26, 2006 12:38 pm Post subject: water temp 582 |
Hi Don,
If you have the time, could you sum up the results
from each of your changes? How much improvement did
you get from changing the ratios, adding waterwetter,
moving the radiator, adding the scoop, etc? You might
prevent some tail-chasing for me and others.
Also, did your scoop change your performance any?
Speed or climb?
Kurt S. S-5
--- Don Smythe <dosmythe(at)cox.net> wrote:
| Quote: | That bothered me too. I ended up cutting off that
round cowl. All air
keep my temps below
all over the place,
Don Smythe
