FLIER(at)sbcglobal.net Guest
Posted: Thu May 25, 2006 11:31 am Post subject: Kitfox tanks and blended ethanol |
Hi All,
Wanted to do a quick poll and see if anyone has had
any problems with their tanks that they've attributed
to using ethanol blended fuel? Mine are Kreem coated
and have been fine for the last 10 yrs but I'm
nervous.
As of now all the stations in Houston are pretty much
10% ethanol. The last batch of fuel I purchased was
still MTBE based. I've been testing. Anyway, now
that burning some ethanol is a given (I don't want to
switch to avgas due to the 912 & lead as well as
price) I thought I'd check.
Ted
jimmieblackwell(at)sbcglo Guest
Posted: Thu May 25, 2006 1:31 pm Post subject: Kitfox tanks and blended ethanol |
Ted
Mine is 12 years old and always been flown either out of Houston or the Austin area. No problem so far, (knock on wood).
Jimmie
flier <FLIER(at)sbcglobal.net> wrote:
Hi All,
nervous.
Ted
flier(at)sbcglobal.net Guest
Posted: Thu May 25, 2006 5:35 pm Post subject: Kitfox tanks and blended ethanol |
Thanks Jimmie. I think it's mostly going to be owners out on the west coast
or up north as I believe ethanol has been more prevalent in those areas in
the past. I'm looking for comments from anyone that has actually had
ethanol blended gas in their tanks for a long time.
Ted
lcfitt(at)sbcglobal.net Guest
Posted: Fri May 26, 2006 6:22 am Post subject: Kitfox tanks and blended ethanol |
Ted, I haven't checked the ethanol level lately, but did during the 6%
period. My guess is that it is higher than that now. My feeling is that we
are under the control, fuel wise, of powers that we have no direct control
over. The thought of the lead in 100LL is not an option in my mind despite
the lead scavengers (TCP and the like). I have run 100LL from time to time
as we fly out of the area on our trips to the back country and I see the
buildup in the oil tank at oil changes of the lead residue and I can only
imagine what is in the grear box. I did change out to auto fuel lines as
these are formulated for the exact fuels we are using.
That said, I did have a tank begin leaking after about the 4th year of
flying. Interesting enough it was first noticed during one of the Idaho
trips after about 4 days of flying with 100LL - go figure. The first
indication was very small blisters on the top surface of the left wing. The
largest were about 1/4" in diameter and the others were mostly felt as you
ran your hand over the area. I ignored it for a couple of years then
resloshed that wing tank with Kreem - alcohol resistant. I went with the
Kreem because of the track record. I felt that with all the talk and the
numbers of users that the inherent problems could be controlled. I didn't
want the be the Kitfox beta tester for something new.
I made a fixture that exactly fit the wing tip cushioned with felt and
supported with a gimbaled joint. The inboard end of the wing was supported
by a hinged device that I could fold out of the way. Everything was on
casters for mobility. I did discover that strict attention to the Kreem
instructions is a very good idea. I won't go into details on that, but I
have been leak free for two years now, but keeping on the alert.
I can give more details for those needing the info. I hope none do as the
whole thing is no fun, and that is speaking mildly.
Lowell
Posted: Fri May 26, 2006 8:27 am Post subject: Kitfox tanks and blended ethanol |
Thanks Lowell. Good input. I'm concerned about
those fiberglass tanks. I know the gas I've used for
the past nearly 10 yrs has been alcohol free. I
really hate to start now but there's no alternative.
I guess we might be OK if we all ended up with tanks
that were Kreem sloshed properly. I have my doubts
tho. I'm just hoping we don't end up with a rash of
Kitfox tanks failing over the next couple of yrs as
the 10% ethanol blend starts getting used by everyone.
I've about decided that if I end up with leaks I'll
likely build aluminum tanks to fit inside the
fiberglass hulls and recover both wings.
Ted
--- Original Message ---
Subject: Re: Kitfox tanks and blended
ethanol
<lcfitt(at)sbcglobal.net>
| Quote: | period. My guess is that it is higher than that
| Quote: | are under the control, fuel wise, of powers that we
| Quote: | over. The thought of the lead in 100LL is not an
| Quote: | the lead scavengers (TCP and the like). I have run
| Quote: | as we fly out of the area on our trips to the back
| Quote: | buildup in the oil tank at oil changes of the lead
| Quote: | imagine what is in the grear box. I did change out
| Quote: | these are formulated for the exact fuels we are
using.
| Quote: | flying. Interesting enough it was first noticed
| Quote: | trips after about 4 days of flying with 100LL - go
figure. The first
| Quote: | indication was very small blisters on the top
| Quote: | largest were about 1/4" in diameter and the others
| Quote: | ran your hand over the area. I ignored it for a
| Quote: | resloshed that wing tank with Kreem - alcohol
| Quote: | Kreem because of the track record. I felt that with
| Quote: | numbers of users that the inherent problems could be
| Quote: | want the be the Kitfox beta tester for something new.
| Quote: | supported with a gimbaled joint. The inboard end of
| Quote: | by a hinged device that I could fold out of the
| Quote: | casters for mobility. I did discover that strict
| Quote: | instructions is a very good idea. I won't go into
| Quote: | have been leak free for two years now, but keeping
on the alert.
| Quote: | whole thing is no fun, and that is speaking mildly.
Lowell
Michel
Posted: Fri May 26, 2006 10:56 am Post subject: Kitfox tanks and blended ethanol |
On May 26, 2006, at 7:23 PM, flier wrote:
| Quote: | I've about decided that if I end up with leaks I'll
Maybe a silly question but ... couldn't the tanks be made ethanol
resistant by coating the inside with epoxy?
Just wondering. Incidentally, there are still no Ethanol in the
Norwegian MOGAS but by the end of the year, there might be as much as
5%, as a governmental and environmental decision.
Cheers,
Michel
dosmythe(at)cox.net Guest
Posted: Fri May 26, 2006 11:47 am Post subject: Kitfox tanks and blended ethanol |
| Quote: | Maybe a silly question but ... couldn't the tanks be made ethanol
Cheers,
Michel
Michel,
I did just that on my tanks. Cut them open and coated the interiors
with West Systems Epoxy (after removing the cracking Kreeme). However, my
opinion is that nothing you put inside the tanks as a coating would protect
the fiberglass itself against a harmful fuel. Even a pinhole that you
missed will allow the fuel to reach the fiberglass. That would be like
building a fuel tank out of Styrofoam and coating it with something to
prevent the gasoline from eating the Styrofoam. I doubt a Styrofoam tank
would last a day.
dave(at)cfisher.com Guest
Posted: Fri May 26, 2006 12:04 pm Post subject: Kitfox tanks and blended ethanol |
Don,
I cannot find link but there is a product that is compatible with ethanol .
I think it was called red- something.
besides most gas stations have fiberglass tanks and contain ethanol fuel.
I have no idea if our fuel in Canada has ethanol yet or what percentage but
so far , so good .
I have heard of some tank's lining turning to gel and clogging up fuel
filters.
Dave
PS styrofoam gets eaten by gas. I have made tanks out of it as a plug
and disolved the styrofoam with gas.
Michel
Posted: Fri May 26, 2006 1:11 pm Post subject: Kitfox tanks and blended ethanol |
On May 26, 2006, at 9:46 PM, Don Smythe wrote:
| Quote: | I did just that on my tanks. Cut them open and coated the interiors
Well, Don and Dave, what I did was to call Shell Norway (because I use
a Shell station to fill my cans of MOGAS) and asked them about ethanol
in Norway. A person answered that there was still none but that it
would come shortly, as part of a request from the European Union
directives.
I mentioned then my worry for our fiberglass tanks. To which that
person was interested because - as you say, Dave - many petrol station
tanks are made of fiberglass but ... coated with epoxy.
But I agree with Don that a coating should be done thoroughly if it is
supposed to work. Did you clean your tanks with acetone before coating
them, Don?
Cheers,
Michel
Posted: Fri May 26, 2006 1:49 pm Post subject: Kitfox tanks and blended ethanol |
| Quote: | supposed to work. Did you clean your tanks with acetone before coating
them, Don?
Cheers,
Michel
Michel,
When I had the tanks cut open I cleaned with acetone and MEK using paint
brushes and tooth brushes for all the cracks and corners then went over all
surfaces with rough sand paper. I applied the West Epoxy with a small brush
in the seams/corners and a plastic spreader for all the flat surfaces. I
did not want the epoxy to build up too thick so it would crack.
Don Smythe
pwmac(at)sisna.com Guest
Posted: Fri May 26, 2006 3:03 pm Post subject: Kitfox tanks and blended ethanol |
And Skystar used the exact same resin that is used in your local gas
station. It is compatible with ethanol. Trouble is: 1) They didn't
start using the new resin until late in the M4 or M5 production run.
2) pinholes could still be present. This product is called something
like ~Aflac~, but I have no idea how it is spelled. If someone does
not give us the correct name for this resin then I will have to do a
lot of digging. Like Don I found a coating but its not West, I used a
Randolf coating that is suppose to be compatible. But the plane is
still not finished so I have no report if it is true.
BTW, Using a resin to coat the tank is a big deal. Just ask Don about
all the trouble he went to. The epoxy resin is much harder to use
than a sloshing liquid.
The best solution if you have a leak is to do the research and re
slosh coat the tanks with the best stuff you can find. BTW, My early
tanks were coated with The old Kreme and when I pressurized them for
a leak test there were pinhole leaks on the top surface.
Interestingly the pinholes were where the grey epoxy paint had been scratched.
I think we are all in trouble when the standard auto fuel becomes E85
because the engine will have low performance even if your fuel system
does not ge corroded and fail..
Regards, Paul
At 02:04 PM 5/26/2006, you wrote:
Don,
so far , so good .
filters.
Dave
Posted: Fri May 26, 2006 4:28 pm Post subject: Kitfox tanks and blended ethanol |
I have done a little research on alcohol / fuel resistent resins for a
project I have been working on for the past several years and (please verify
this info before using it to modify anything in your fuel sustems) this is
what I "think" I have found.
First there are many formulations for epoxy resins. Some are more chemical
resistant than others. The info I have seems to indicate that the "hard"
resins are more chemical resistant vs. the "structural resins that are
"softer" and more fracture resistant. Lancair for example will paint a fuel
resistant coating on the internal surfaces of all fuel bays before closing
the wing. In fact they recommend covering onto the mating surfaces
(capstrips) about 1/8inch so that the Hysol will overlay the fuel coating
that much and the squeeze out will give that much more protection. Of
course the wing spars, ribs and capstrips are formed of a structural epoxy -
glass or carbon fiber composite.
In my application, I have found that the best result is achieved by covering
with the hard epoxy followed by two layers of an alcohol resistant tank
sealer. Most tank sealers are formulated for auto fuels and designed for
metal tanks.
Lowell
Posted: Fri May 26, 2006 6:00 pm Post subject: Kitfox tanks and blended ethanol |
All very good discussions. That's what I wanted to get started to see if
anyone comes up with other creative ideas. All us auto gas types will have
the problem eventually. Just those in the US immediately!
I've even toyed with simply draining my tanks after every flight. Spending
a few hundred bucks to set up a pump system to keep from spending the money
to redo the tanks and covering. I personally am more concerned about the
tanks than the rest of the fuel system as the rest of the system (lines,
etc) is pretty easily replaced as compared to those darn tanks. The 912
carbs should not be a problem.
Keep the ideas coming! :^)
Ted
jdmcbean(at)cableone.net Guest
Posted: Fri May 26, 2006 9:23 pm Post subject: Kitfox tanks and blended ethanol |
Paul,
It is ATLAC.. I have looked into it some.. very short self life and very
difficult to come by.. also needs to be purchased in large quantities..
Fly Safe !!
John & Debra McBean
www.sportplanellc.com
"The Sky is not the Limit... It's a Playground"
Posted: Sat May 27, 2006 5:38 am Post subject: Kitfox tanks and blended ethanol |
I did forget to mention in my post that the vinyl ester resins are quite
fuel resistant. They do require activation which gives a limited shelf life
and will of course need a hardner when used in a lay-up.
In fact I did a Google search to check the spelling and found a RC site
discussing this resin for alcohol based RC fuels with good recommendations.
Lowell
Posted: Sat May 27, 2006 8:55 am Post subject: Kitfox tanks and blended ethanol |
Thanks, John
At 11:18 PM 5/26/2006, you wrote:
Paul,
life and very
Fly Safe !!
John & Debra McBean
Michel
Posted: Sun May 28, 2006 9:53 am Post subject: Kitfox tanks and blended ethanol |
On May 26, 2006, at 11:47 PM, Don Smythe wrote:
| Quote: | When I had the tanks cut open <SNIP>
Wow, you really did a thorough job, Don!
On May 27, 2006, at 12:49 AM, PWilson wrote:
| Quote: | The epoxy resin is much harder to use
Are you sure, Paul? Isn't it possible to "slosh" the tanks with West
System epoxy? If you use very little catalyser and turn the tank in all
direction long enough? My experience with West System is that, if it
gets time to do it, it will really flow everywhere, only leaving a very
thin layer of resin.
West System is a special type of epoxy, primarily designed for building
yachts in wood veneer bounded in epoxy. The very low viscosity of the
epoxy makes it to impregnate the wood and creates an extremely solid
bound.
I don't know but I think one could slosh West System epoxy. What do you
think?
Cheers,
Michel
bnn(at)nethere.com Guest
Posted: Sun May 28, 2006 11:40 am Post subject: Kitfox tanks and blended ethanol |
At 10:49 AM 5/28/2006, you wrote:
| Quote: | Are you sure, Paul? Isn't it possible to "slosh" the tanks with West
I think you're very optimistic, Michel. First of all, you can't
vary the catalyst with epoxy, but you can slightly thin some epoxies with
acetone. Saying West epoxy has low viscosity is strictly a relative term.
Yes it has lower viscosity than other epoxies but it's definitely not going
to be wicking into any pin-holes. The best you could hope for is that it
would successfully bridge the pin-holes with a thick enough layer of epoxy
to seal the tank. Unfortunately my experience with pin-holes on the outside
of overly dry laminates is that for some reason, (high surface tension
probably,) epoxy doesn't like to bridge pin-holes, rather it exacerbates
them. If you really wanted to fill pin-holes, you'd slosh with thin
cyanoacrylate. That stuff wicks like crazy. (We use it to do emergency
repairs of dinged laminates. It wicks right in and seals the damage,
preventing water ingress.) Unfortunately I don't know if it's fuel
resistant, and the fumes would probably kill you!.
On another note, the fiberglass tank industry does coat the inside
of their tanks with something. I'll try to find out what.
Guy Buchanan
K-IV 1200 / 582 / 99.9% done, thanks mostly to Bob Ducar.
Posted: Sun May 28, 2006 12:27 pm Post subject: Kitfox tanks and blended ethanol |
Guy,
Would that stuff slosh before it hardens? I thought
even the slow stuff gets stiff fast. At least the
stuff in hobby shops.
My sloshed tanks are doing fine for now, but I expect
to have to "maintain" them sooner or later.
Kurt S.
--- Guy Buchanan <bnn(at)nethere.com> wrote:
| Quote: | .....If you really wanted to fill pin-holes, you'd
slosh with thin cyanoacrylate.
Posted: Sun May 28, 2006 12:43 pm Post subject: Kitfox tanks and blended ethanol |
I never tried it. I just believe that Don's process is what would be
necessary. I believe it would be worthwhile to try it. My experience
with the West system was pretty viscous final product. I am not very
experienced with epoxy and thought one had to use the recommended
ratios when mixing.
Paul
At 11:49 AM 5/28/2006, you wrote:
bound.
think?
Cheers,
Michel
