Martin Olliver
Posted: Mon Feb 13, 2012 2:17 am Post subject: Lightning Strike |
Hi All. Has anyone experienced a lightning strike in a Europa? If not what is the perceived result of such a strike? A few years ago in the south of England a plastic glider was struck and broke up in flight both occupants survived as parachutes were deployed. A luxury I am unable to have due to size issues (not saying I am fat just well built!) My concern with the Europa is the lack of bonding between components and conductors to ensure components don't explode apart, as happened with the glider.
If as I suspect we all take a risk with this issue has any one considered any possible remedial action to improve the situation?
Martin.
nigel henry
Posted: Mon Feb 13, 2012 2:44 am Post subject: Lightning Strike |
Dont fly ! As for well built Iv had lunch with you in Mcdonnalds ! and two of us in one europa I think might be a no no as not able to add fuel for w&b issues, so safety is bliss see you soon Nigel Ps will be down in the next few days put the coffee on ...... and no buns ! and yes will bring your gascolator top.
[quote] Subject: Lightning Strike
Date: Mon, 13 Feb 2012 02:17:46 -0800
--> Europa-List message posted by: "Martin Olliver" <martflynut(at)aol.com>
Martin.
http://forums.matronics.com/viewtopic.php?p=366176#366176
Posted: Mon Feb 13, 2012 2:47 am Post subject: Lightning Strike |
Martin, Paul McAlister had a lightning strike on his
Europa which produced only modest damage and left the
plane fliable, detailed at:
http://europa363.versadev.com/LightningStrike.html It
was clearly a much lower energy strike than the one that
blew up the glider. It apperas to havetravelled along thge
wires to his nav ligfhts and thus avoided the control
runs. When I was contemplating flying to Ausralia I did a
fair bit of research on the topic and found it exremely
difficult to get any authoritive advice other than the CAA
publication triggered by the glider incident (CAA
AIL/0014, 2001, ISBN 1 904862 19 5) which gives
recommendations for protecting gliders. It makes excellent
sense for Europas contemplating getting near to Cu Nims.
( And although I usually feel it best to stay very well
clear of such things, it is not possible to get to
Australia without risking doing so unwittingly). My plan
had been to run some aluminium mesh along the aileron and
flap close outs to link with the rear lift pins and the
bar across the fus behind tghe seats, with foil extensions
from the outer aluminium mesh around the wing tip. I also
planned to run a link from the engine frame to the tail
wheel spring.
Hope that helps, David Joyce, G-XSDJ
On Mon, 13 Feb 2012 02:17:46 -0800
glider.
Martin.
Un/Subscription,
Forums!
Admin.
trevpond(at)aol.com Guest
Posted: Mon Feb 13, 2012 2:49 am Post subject: Lightning Strike |
What do Cirrus do?
Trev
G-LINN
Martin.
Posted: Mon Feb 13, 2012 2:55 am Post subject: Lightning Strike |
Martin, Sorry that link to Paul's strike doesn't seem to
work, but perhaps he will come back with one that does!
David
On Mon, 13 Feb 2012 10:46:25 +0000
thge wires to his nav ligfhts and thus avoided the
control runs. When I was contemplating flying to Ausralia
I did a fair bit of research on the topic and found it
exremely difficult to get any authoritive advice other
than the CAA publication triggered by the glider incident
(CAA AIL/0014, 2001, ISBN 1 904862 19 5) which gives
excellent sense for Europas contemplating getting near to
Cu Nims.
extensions from the outer aluminium mesh around the wing
tip. I also planned to run a link from the engine frame
to the tail wheel spring.
>glider.
> Martin.
>Un/Subscription,
>Forums!
>Admin.
Un/Subscription,
Forums!
Admin.
Posted: Mon Feb 13, 2012 3:31 am Post subject: Lightning Strike |
Pete, It was a flight experience/trial lesson flight, with
P2 having his first glider flight (and his last, inspte of
being offered a free second one in view of his first being
curtailed!) There was no water ballast, but there was some
speculation that some water contamination (?condensation)
might have added to the force of the heat generated
expansionof the air in the wing, which effectively blew
the two surfaces apart. What was established is that the
energy in the bolt was exceptionally high, significantly
more, in fact, than airliners are built to withstand.
Regards, David Joyce
On Mon, 13 Feb 2012 06:16:04 -0500
Peter Zutrauen <peterz(at)zutrasoft.com> wrote:
Quote: | Hi Martin,
I was under the impression that the glider you referred
to broke up in
flight due to the water ballast in the wings?
Indeed in the archives you should find Paul Mcallister's
lightning strike
experience. Quite a read!
http://www.aeroelectric.com/articles/Anatomy_of_a_Lightning_Strike.pdf
Pete
A239
On Mon, Feb 13, 2012 at 5:17 AM, Martin Olliver
>Europa? If not what
>ago in the south of
>concern with the
>glider.
>any one considered
> Martin.
paul.the.aviator(at)gmail Guest
Posted: Mon Feb 13, 2012 4:20 am Post subject: Lightning Strike |
Hi Martin,
I documented a lightning strike at http://www.europa.net.nz/363/index.html. Its under the drop down on the left hand side.
Paul
On Mon, Feb 13, 2012 at 4:17 AM, Martin Olliver <martflynut(at)aol.com (martflynut(at)aol.com)> wrote:
[quote] --> Europa-List message posted by: "Martin Olliver" <martflynut(at)aol.com (martflynut(at)aol.com)>
Martin.
Posted: Mon Feb 13, 2012 5:02 am Post subject: Lightning Strike |
Pete & Martin
It was the control runs I think, but probably also moisture in the core of the composite skins, I remember reading that the wings exploded like confetti.
Graham
Sent: Monday, 13 February 2012, 11:16
Subject: Re: Lightning Strike
Hi Martin,
I was under the impression that the glider you referred to broke up in flight due to the water ballast in the wings?
Indeed in the archives you should find Paul Mcallister's lightning strike experience. Quite a read!
Pete
A239
On Mon, Feb 13, 2012 at 5:17 AM, Martin Olliver <martflynut(at)aol.com (martflynut(at)aol.com)> wrote:
Martin.
target="_blank">http://www.matronics.com/Navigator?Europa-List
le, List Admin.
href="http://www.matronics.com/Navigator?Europa-List">http://www.matroniclow" target="_blank" href="http://forums.matronics.com">http://forums.m= --> [b]
kheindl(at)msn.com Guest
Posted: Mon Feb 13, 2012 6:22 am Post subject: Lightning Strike |
I have had a minor strike some years ago. Judging by the trail of 'damage' it appears to have entered by the tailpipe and exited via the radiator. But it was minor and no repair was necessary.Manufacturers like Cirrus and Diamond have integrated aluminum or copper mesh into the wing skins.
Karl
Subject: RE: Lightning Strike
Date: Mon, 13 Feb 2012 10:44:08 +0000
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Tahoma;} Dont fly ! As for well built Iv had lunch with you in Mcdonnalds ! and two of us in one europa I think might be a no no as not able to add fuel for w&b issues, so safety is bliss see you soon Nigel Ps will be down in the next few days put the coffee on ...... and no buns ! and yes will bring your gascolator top.
Martin.
| [/b]
raimo.toivio(at)rwm.fi Guest
Posted: Mon Feb 13, 2012 6:53 am Post subject: Lightning Strike |
Martin,
I had a case 8.th of June 2008. It went in via a
fin top mounted strobo (it melted and remainders
are in my "museum" now). Never found an outcoming
hole. It broke also an electric trim and we had to
land when trimmed for a cruise speed. It visited
also a radio but no radio damages. I felt it via
power lever and co-pilot got some electric
experience via his headsets.
That occurred when we flew between two black CBs,
distance was about 10 nm /each. I cannot verify
was it a strike or so called St. Elmo´s fire. Not
very fun anyway.
What I did later to improve the situation? Nothing
but try to stay more clear about CBs.
Raimo
OH-XRT
FINLAND
-----Alkuperäinen viesti-----
Sent: Monday, February 13, 2012 12:17 PM
the glider.
Martin.
browse
Un/Subscription,
FAQ,
Forums!
List Admin.
Martin Olliver
Posted: Tue Feb 14, 2012 2:21 am Post subject: Re: Lightning Strike |
Thank you all for your input.
Martin.
Last edited by Martin Olliver on Tue Feb 14, 2012 2:50 am; edited 1 time in total |
nigel_graham(at)m-tecque. Guest
Posted: Tue Feb 14, 2012 2:32 am Post subject: Lightning Strike |
Just remember to take a pee before you take off BODY { font-family:Arial, Helvetica, sans-serif;font-size:12px; }
On Tue 14/02/12 10:21 , "Martin Olliver" martflynut(at)aol.com sent:
Thank you all for your input. The good news here is that those of you who have had a lightning strike, seem to have only suffered minor or no damage at all. The situation with the glider seems to be different because of the moisture in the wings. I think we can all fly with cautious optimism on this one.
Martin.
[url=parse.php?redirect=http%3A%2F%2Fforums.matronics.com%2Fviewtopic.php%3Fp%3D366258%23366258]http://forums.matronics.com/viewtopic.php?p=366258#366258[/url]
Navigator%3FEuropa-List" target=_blank>http://www.matronics.com/Navigator?Europa-List
" target=_blank>http://forums.matronics.com
contribution" target=_blank>http://www.matronics.com/contribution
frans(at)privatepilots.nl Guest
Posted: Tue Feb 14, 2012 2:39 am Post subject: Lightning Strike |
On 02/13/2012 11:17 AM, Martin Olliver wrote:
Quote: | Hi All. Has anyone experienced a lightning strike in a Europa? If not
The result is impossible to predict. Lightning stikes comes in all sizes
and shapes. You can get a little protection against very light strikes
(for of course a weight penalty), but since you don't know what is going
to strike you there is just one effective measure: stay away from
anything that looks like a TS.
If you embed copper mesh in your wings it will make your wings much
heavier, and of course if the strike is heavy enough the mesh will melt
anyway and take the wing with it. Any strike generates heat, and as we
all know our Europa's can not tolerate much heat, not much what we can
do about it except for using aluminium instead of glass fiber.
As much as the size and direction of lightning strikes vary, so do the
results. The best in terms of survivability are vertical strikes. They
don't search for your airplane, you just have to fly through a strike in
progress. Alas, they are the least occuring stikes in airplanes. Much
more occuring are spanwise and lenghtwise strikes. Your airplane offers
an electric charge a comfortable path to find its opponent. Also, your
exhaust fumes leave a trail of extra conductive air, due to the carbon
and extra moisture in it. Any charge following that trail will find your
airplane. Spanwise strikes bring the risk of welding the aileron
controls, and of course the heat expands the air in the wings and the
wings may just blow apart. Lenghtwise strikes will likely travel via the
rudder cables. Apart from taking the ruddder out when the tiny cables
melt, they might melt through the fuel tank which is just an inch away.
Heat and fuel don't go along very well. And of course the rudder cables
end at the rudder pedals, so I hope you don't have wet feet when it happens.
The avionics and electric systems are the least of your concerns, but
anything might fail, if not everything. It is likely you can't talk to
anyone anymore, have no navigation anymore, and have to land your
crippled airplane trimmed for cruise speed and possibly without rudder
or aileron control without assistance. If you survived the initial
strike at all of course.
I remember the story of someone who got hit by lightning. They found his
airplane with all the controls welded. Some research revealed that the
poor pilot had flown for at least 10 minutes after all the controls
where welded inmovable before he crashed...
So, I will avoid thunderstorms at all costs.
In my airplane I installed a stormscope. If it indicates anything
threatening closer than 100nm, I will just land and fly another day.
Frans
Posted: Tue Feb 14, 2012 2:41 am Post subject: Lightning Strike |
On 02/14/2012 11:21 AM, Martin Olliver wrote:
Quote: | Thank you all for your input. The good news here is that those of you
cautious optimism on this one. Martin.
I think you can not. These people had just tremendous luck. The wings of
an Europa will explode if the strike is anything more than "extremely
light".
Frans
Speedbird
Posted: Tue Feb 14, 2012 2:43 am Post subject: Lightning Strike |
If you don't have farradays, stay well clear of CB's and where to suspect discharging!
I have flown at least 5000 hours in King Airs with multiple hits and it never fells secure or "god enoug" around thunder and lightning...
I have seen composite parts hit by lightning and it has always destroyed parts beyond repair!
Don't fly near it...
My 2 cents of recommendations
Cheers!
Ivan
KajakCenter Halland
Org nr; 5805034625
P: +46 703 621310
P: +46 704 694444
M: midwing(at)telia.com
W: www.kajakcenter-halland.se
14 feb 2012 kl. 11:21 skrev "Martin Olliver" <martflynut(at)aol.com>:
Martin.
Martin Olliver
Posted: Tue Feb 14, 2012 2:53 am Post subject: Re: Lightning Strike |
Not looking good then.
Martin
Speedbird
Posted: Tue Feb 14, 2012 2:55 am Post subject: Lightning Strike |
Frans,
That is the best approach!
I do fully agree.
Don't fly in or near clouds especially those convective ones...
There is no such thing as a "mild" TS...
Blue Skies!
Ivan
Frmr FC at SOS Flygambulans AB
KajakCenter Halland
Org nr; 5805034625
P: +46 703 621310
P: +46 704 694444
14 feb 2012 kl. 11:37 skrev Frans Veldman <frans(at)privatepilots.nl>:
Frans
Posted: Tue Feb 14, 2012 3:01 am Post subject: Lightning Strike |
Martin, I would like to think you are right but I doubt
you are! I think that any Europa (at least the XS, which
is constructed in very much the same way as the K21 glass
fibre glider) is just as likely to have dampness in the
wings. On top of that, if you look at the AAIB report (
www.aaib.gov.uk/cms_resources.cfm?file=/dft_avsafety_pdf_500699.pdf
) there is no mention of water as far as I can see - it
appears to be just a shock wave associated with the very
high energy electrical discharge. For me the point at
issue is the size of the lightning bolt. As well as
blowing up the wings the current fused or destroyed most
of the aileron control mechanisms so that it would have
been unflyable even with the wings intact. It seems that
the 3 reported Europa strikes have all been low energy
ones, and I have no optimism about an unmodified Europa
surviving a medium or large strike. Regards, David Joyce,
G-XSDJ
On Tue, 14 Feb 2012 02:21:36 -0800
Martin.
Un/Subscription,
Forums!
Admin.
