		GLJSOJ1
  Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
				 Posted: Mon Feb 27, 2012 3:09 pm    Post subject: O 200 CASE SEAL |
				I have assembled my O 200 and was told by. Aircraft Specialty to use "Hylomar AEROGRADE" and silk thread to put the case together.  I now have several friends questioning if this is acceptable to use.  I called Penn Yan  Aero who has never heard of this. Anybody have any experience with this or should I rebuild the engine before I start to fly it?
  |  | - The Matronics Continental-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ 601XL N676L  FLYING PHASE I
CHESAPEAKE VA |
		ftyoder(at)yoderbuilt.com Guest
				 Posted: Mon Feb 27, 2012 3:33 pm    Post subject: O 200 CASE SEAL |
				I believe that is what Cont. recommends and that is the system I used in  the early 90's.  Hylomar works well on the valve covers also.
  [quote]   ---
		BARRY CHECK 6
				 Posted: Mon Feb 27, 2012 3:48 pm    Post subject: O 200 CASE SEAL |
				Glenn:
 That is SCARY!  Penn Yan does not know about that process...  That is what happens when you replace OLD FARTS with Young Whipper-Snappers.  The Knowledge goes out the door.
 Hylomar AEROGRADE is just one of the High Temp RTV's being used.  This is NOT the High Temp you get at Home Depot.
  This is a sealant/adhesive that can handle the Full Range of Temps, The vibration and The OIL.
 As for the silk thread... Well, that is old and not that good a process.  The thread moves - kinks and causes leaks.
  It is left out with the new sealant.
 Also check out HINKLE Adhesives/Sealants.
 Give a call to Continental or Lycomming, they have approved the process years ago.
 Barry
 On Mon, Feb 27, 2012 at 6:08 PM, GLENN JOHNSON <gljno10(at)hotmail.com (gljno10(at)hotmail.com)> wrote:
 [quote]    I have assembled my O 200 and was told by. Aircraft Specialty to use "Hylomar AEROGRADE" and silk thread to put the case together.  I now have several friends questioning if this is acceptable to use.  I called Penn Yan  Aero who has never heard of this. Anybody have any experience with this or should I rebuild the engine before I start to fly it?
		GLJSOJ1
				 Posted: Tue Feb 28, 2012 3:18 pm    Post subject: Re: O 200 CASE SEAL |
				Called TCM today and the whole truth is follow SIL99-2B which calls for loctite 515 as well as permatex #3 with the silk thread.  I was told that what happens is the case will not hold the torque on the bolts causing the case to eventually loosen up and we know what happens then.  He also said good luck getting it apart!
 Thanks for all who posted as it lead me to follow my instinct and call the manufacturer
CHESAPEAKE VA |
		BARRY CHECK 6
				 Posted: Tue Feb 28, 2012 3:46 pm    Post subject: O 200 CASE SEAL |
				I'm sorry, I do not recall; is this engine going on an experimental or a GA aircraft?I'm sure you know where I'm going...
 My next suggestion would be to call Lycoming or another engine shop and ask what they use?  My O-320 Lycoming was assembled at an engine shop with ONLY a RVT sealant/adhesive.  This was done back in 2000 and I have not seen any leaks.
  The FAA does NOT care what sealant you use.  And if they did the must have approved a few different sealants for all the different engine manufactures out there. Next point - Since YOU are are the engine shop YOU are the one certifying the engine and you are the one standing behind the warranty. Do what YOU feel works best.  As long as it is an approved sealant who cares which one!  Only You!
 Barry
 On Tue, Feb 28, 2012 at 6:18 PM, GLJSOJ1 <gljno10(at)hotmail.com (gljno10(at)hotmail.com)> wrote:
 [quote] --> Continental-List message posted by: "GLJSOJ1" <gljno10(at)hotmail.com (gljno10(at)hotmail.com)>
  CHESAPEAKE VA
  http://forums.matronics.com/viewtopic.php?p=367485#367485
  List" target="_blank">http://www.matronics.com/Navigator?Continental-List
  le, List Admin.
