Re-juvinate a NiCad Battery?
Goto page Previous  1, 2
PostPosted: Thu Mar 08, 2012 1:16 pm    Post subject: Re-juvinate a NiCad Battery? Reply with quote
At 10:27 AM 3/8/2012, you wrote:
Bob and others have mentioned trying the 3V/1Amp charge. What device
or battery do you use to provide the 3V - 1Amp charge?
There's nothing magic about either 3 volts or 1 amp. The task
is to see if you can burn away any whiskers that have grown
between the (+) and (-) plates to cause a short. I've used
a D-size, Ni-Cad which has a considerable short circuit delivery
characteristic. A computer grade, 200KuF electrolytic capacitor charged
up with one or two alkaline cells (1.5 to 3 volts) can be a potent
whisker blower. If you're successful in opening such faults,
it will happen in milliseconds.
raymondj(at)frontiernet.n
PostPosted: Thu Mar 08, 2012 1:31 pm    Post subject: Re-juvinate a NiCad Battery? Reply with quote
Noel mentioned he read an article indicating the 40-70% range as
optimal. I was hoping the same article might have told how to determine
the charge state so the recommendations could be applied.
I use throw away batteries if I have a choice, but some of my tools only
have rechargeable packs. Doing what I can to maximize their life.
Thanks again,
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
On 03/08/2012 02:36 PM, Robert L. Nuckolls, III wrote:
At 09:36 AM 3/8/2012, you wrote:
> Is it voltage that is measured. Does the manufacturer supply a voltage
> vs. % charge graph or table? Or is it derived experimentally?
> I understand that there are cost/benefit issues here, but my objective
> is to understand the process from a physics perspective for my own
> education.
Understand . . .
I don't think that open circuit terminal voltage
has a strong correlation to stored energy on the
metal cells. Least wise, I've not seen any charts
claiming to offer insight.
ainut(at)knology.net
PostPosted: Thu Mar 08, 2012 2:28 pm    Post subject: Re-juvinate a NiCad Battery? Reply with quote
Also, be advised that some of the dirt cheap batteries (and even some
full priced ones) are scams. They hold very little battery material and
last only a very short time. Think of the batteries that "are included"
with some of the cheap toys, for example. Some of those have made it
into the mainstream marketplace. Caveat Emptor.
David M.
<nuckolls.bob(at)aeroelectric.com>
At 07:09 PM 3/6/2012, you wrote:
> Question: How do you determine the percent charge on a battery pack.
> Is it by voltage or current or what. That's one of my pet peeves
> with rechargeables in everything. The batteries die from old age
> rather than from reaching the max number of cycles.
> Looking forward to hearing about this.
Okay, but you're probably not going to like it.
Some years ago I wrote an article about the economics
of using house branded AA cells in my airborne hardware.
http://aeroelectric.com/articles/AA_Bat_Test.pdf
The thrust of the article went to in-flight reliability
of my battery powered hand held GPS and Comm radios
coupled with risk mitigation. One night over west
TX I found it necessary to change the four AA cells
<<<snip>>>
PostPosted: Thu Mar 08, 2012 10:47 pm    Post subject: Re-juvinate a NiCad Battery? Reply with quote
some full priced ones) are scams. They hold very little battery
material and last only a very short time. Think of the batteries
that "are included" with some of the cheap toys, for example. Some
of those have made it into the mainstream marketplace. Caveat Emptor.
Yeah . . . you can find Ni-Cd and Ni-Mh AA cells rated
with over 2:1 differences in capacity. It would be
interesting to do the How Bad Can a Metal Battery Be?
experiment on some of these cells.
I've also noted that many so-called Ni-Cd "D" cells
are a bit . . . shall we say . . . light? They
are also rated in the 1500 to 2000 mAh range commensurate
with a "C" cell. I think these batteries would be
a disappointment too . . . a real Ni-Cad "D" is good
for about 4000 mAh.
The computer and DAS I used on the original battery
killer experiments bit the dust a couple of years ago.
I've got a new set of tools that I need to adapt to a
battery box that holds at least 8 cells for testing at
a time.
I'm debating whether to stay with the original testing
protocol for the AA alkaline cells that used a fixed
resistor. Certainly good enough for comparative
studies. I think I'd like to fit the test set with
software controlled loads . . . probably power fets.
This would let me run a wide range of discharge currents.
It would also allow modulation of the test current
during a discharge cycle to measure the cell's internal
resistance. Dynamic loads would also let me discharge
in a constant resistance, constant current or constant
power modes. I need to talk to my software guy and see
if he's up to making this hardware 'hum'. I'm not going
to have time to do it for awhile.
But you're quite right. What's marked on the label may
not be all it claims to be.
rparigoris
PostPosted: Fri Mar 09, 2012 4:26 am    Post subject: Re-juvinate a NiCad Battery? Reply with quote
Hi Group
A few notes on NiMh batteries:
I've done quite a bit of testing on AA and AAA NiMh batteries lately and one theme that seems to ring true is by knowing the weight you can pretty much predict what sort of cell you have. I was running an average 50mA, 5 paralleled LED load (only 1 resistor) on three series AA batteries. It didn't matter if it was LSD or Non LSD, what ever the weight is of a Home Depot AA Energizer LSD cell, if you have about that weight you will get about 2100mAs of capacity. From Home Depot they are about 3$ each but if you shop hard on E-Bay you can get them for ~ 2$ each delivered. I purchased a half dozen different cells from E-Bay ranging from $.59 to $.79 each. Some have very beautiful packaging, but they all have written on them 3,000mA. After several C/10 for ~15 hour cycles they range in capacity from 600mAsa to ~900mAs with the 600s being lighter in weight than the 900s. Essentially the 600s are AAA "good stuff' squeezed into a AA wrapper. I also set up a fast discharge test and for the most part the lighter the cell the less ability it had to hold up to a high amp draw. That said I did test some Elite batteries that are Non-LSD cells that have the ability to dump amps at a much higher rate than the Energizers. They claim they can take a 15 to 25 amp draw: http://www.cheapbatterypacks.com/product/122/Elite-2000-AA.aspx and it seems like the best AA NiMhs I've tested thus far as far as their ability to dump. I haven't flown a model with them, but suspect they will be pretty good at short bursts of 15 to 20 amps, pretty amazing. When you abuse cells beyond belief you want to see them stay above 1V for most of the cycle. They don't like to be fast peak charged though, best stay at 1C or 1.5C and you better have very low resistance connections and wires charging anything over ~ .75C (C being the Capacity of the battery). The capacity on the Elites is just ~ 2,000 mAs at my 50 mA draw where the Energizers are ~ 2100 mAs. BTW it's not a very good idea to take series NiMhs much below 1V. If the cells get out of balance and you have one that gets very discharged, the other cells are not going to do it any good for it's long life at all. With my 50mA load, there is very little capacity loft at 1V. If you test cells after you cycle them a few times, if you know the temperature and are using a 50mA load, then you can pretty easily tell if they are more or less than 75% charged. At room temp if you are seeing over 1.4 volts, you can be pretty sure you have over 90% capacity. If your over 1.35 volts then you are probably over 75%. Again this is with a 50mA load. Much below the 1.35 volt area it begins to get tricky. Different cells can be slightly higher or lower. There is a very long voltage hold out between ~ 1.2 and 1.35 volts so using voltage to figure out how much capacity is left will not be very accurate. Knowing if you are over 75% however is very useful! I forget the voltage, but once you see the voltage drop to ~ 1.15 volts, there isn't much capacity left.
I set up a fast discharger to get cells quickly down to 1V with a 3 ohm resistor. I began with 3 paralleled 3 ohm, got to 1V, removed one 3 ohm resistor, got to 1V removed a second resistor, then got to 1V using only the one 3 ohm resistor and let it get to 1V. Now i have a known state of discharge. Using Bobs one LM1117 with a fixed resistor, three in parallel off a 12 volt battery, I can charge 6 AA cells in about 45 minutes on a timed charge. I cheat a little, I have 3 series for about the first half of the charge, then go down to 2, then complete with one. This is a low cost fast charger for third world countries. If they have the time a better way is to C/10 for 14 to 16 hours. With my fast charger I have it down where I get them 90 to 95% charged with very little chance of venting. Once a NiMh cell peaks, if you continue with a constant current charge the cells begin to warm up. With my pseudo 3 stage charge they barely get Luke warm at the end of the charge! BTW 1/2" PVC tube works great as a AA holder. I did drill holes making it a piece of swiss cheese for cooling when fast charging, but you could probably get away with only two 1/4" holes per cell in case they vented.
I built a pedal powered generator to charge up the 12volt battery that can use any bicycle, Home Depot 5 gallon buckets and a permanent magnet air conditioner blower motor for a car. I also top off my Odyssey PC545 aeroplane battery with it. The Odyssey is pretty amazing as far as it's ability to not self discharge. If anyone is not totally bored here's some videos:
http://communitysolutionsinitiative.org/2011/09/24/light-cycle-videos/
If anyone wants to make a pedal powered generator, here's step by step instructions:
http://www.europaowners.org/main.php?g2_itemId=89553
Pepboys PM102X permanent magnet motor costs $19.99 the last time I bought one. Some have tried PM102 either with nothing or a different letter at the end, and they may be reverse wound. They work OK you just need to reverse the wires. Using a Schottky diode prevents the motor from running off the battery and only loses a few percent to heat. I was using Rat Shack diodes until the Schottkys came in and they lose more to heat.
One more thing, I love AstroFlight Whatt Meter (Whatt is correct): http://www.astroflight.com/index.php?main_page=index&cPath=2
You can keep them alive with 4 NiMh or Alkaline batteries and measure down to and datalog even 1 cell. Expensive though.
I fooled with these at half the price and as long as you can wait half of forever (they only build when they have enough orders):
http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=10080
They are a pretty good value. They happen to have in stock at the moment! Probably not quite as accurate as the Astroflight though.
Ron P. [quote][b]
PostPosted: Fri Mar 09, 2012 6:40 am    Post subject: Re-juvinate a NiCad Battery? Reply with quote
At 06:24 AM 3/9/2012, you wrote:
Hi Group
<snip>
Ron P.
I'll add weight measurements to the gathered data on any future testing I do with the metal batteries. It probably wouldn't have been a useful data point with the AA alkaline cells . . . at the time I ran the first tests, there was little difference of significance in performance over the spectrum of products evaluated. I expect to see more differences in the metal world and weight may well be an important predictor. I do recall picking up a D cell that seemed too light and then observed that it was rated more like the family of C cells. At least they were honest about it.
Great data sir! I'm archiving this piece in my "battery performance" folder. When I update the AA battery article, I'd like to collaborate with you to add your findings to the knowledge base.
Bob . . . [quote][b]
PostPosted: Fri Mar 09, 2012 7:00 am    Post subject: Re-juvinate a NiCad Battery? Reply with quote
Along these battery lines, why can't we recharge these new lithium
AA's? That would cut battery buying to about a tenth...
David M.
> and last only a very short time. Think of the batteries that "are
> included" with some of the cheap toys, for example. Some of those
for about 4000 mAh.
a time.
Tell the truth. Be honest. Be responsible to and for yourself.
We want our freedoms back. Strike the illegal legislations called: 1) obamacare, 2) "Patriot (HA!) Act", and 3) 'presidential orders' that affect anyone besides gubmnt worker bees.
Hate crime laws? Really? Thought police? Orwell would be proud.
Every gram of cocaine you buy from elsewhere contributes to an innocent being murdered in Central and South America. Grow your own or Stop taking it.
PostPosted: Fri Mar 09, 2012 7:43 am    Post subject: Re-juvinate a NiCad Battery? Reply with quote
At 08:31 AM 3/9/2012, you wrote:
--> AeroElectric-List message posted by: David <ainut(at)knology.net>
Along these battery lines, why can't we recharge these new lithium AA's? That would cut battery buying to about a tenth...
David M.
For reasons similar to those that keep you from recharging say a Pink Bunny cell or a legacy carbon zinc cell. For a electro-chemistry system to be driven in reverse takes special attention to it's makeup. There ARE alkaline cells designed to be recharged. I've never used any but I've been curious about them. I may add them to the roster of test subjects.
The short answer is that the designers of a given cell make adjustments to optimize the cell's performance characteristics in perhaps one or two features. Making a cell optimally rechargeable probably gives up some other performance feature.
klehman(at)albedo.net
PostPosted: Fri Mar 09, 2012 11:00 am    Post subject: Re-juvinate a NiCad Battery? Reply with quote
FWIW I've found rechargeable alkaline to be fine for low current devices
such as remote controls. However after a couple of charges they are poor
to non functional in anything that requires a bit of current such as a
camera or anything with a motor in it. This experience is from perhaps
20 AA cells over several years.
Ken
> David M.
subjects.
PostPosted: Sun Mar 11, 2012 12:14 pm    Post subject: Re-juvinate a NiCad Battery? Reply with quote
devices such as remote controls. However after a couple of charges
they are poor to non functional in anything that requires a bit of
current such as a camera or anything with a motor in it. This
experience is from perhaps 20 AA cells over several years.
Good data Ken. I'll get some numerical data
on these too when I repeate the experiment.
Page 2 of 2
