raymondj(at)frontiernet.n Guest
Posted: Sun Apr 08, 2012 5:05 pm Post subject: Conduit in wings. |
Greetings,
I'm planning on completing my aircraft with a minimum electrical system
and providing a way to install wingtip lights later. Any experiences
anyone has with using different types of conduit in wings would be
appreciated.
Thanks in advance,
Raymond Julian
Kettle River, MN
"And you know that I could have me a million more friends,
and all I'd have to lose is my point of view." - John Prine
Posted: Sun Apr 08, 2012 5:29 pm Post subject: Conduit in wings. |
On 04/08/2012 08:03 PM, rayj wrote:
Greetings,
system and providing a way to install wingtip lights later. Any
experiences anyone has with using different types of conduit in wings
would be appreciated.
Thanks in advance,
Raymond Julian
Kettle River, MN
Van supplies simple plastic snap-bushings for the wire passage holes
that you drill in the ribs. If simple bushings is good enough for Van....
Charlie
LynnCole(at)foxvalley.net Guest
Posted: Sun Apr 08, 2012 5:44 pm Post subject: Conduit in wings. |
Hi Ray,I used 5/8-inch OD HDPE tubing from McMaster-Carr (www.mcmaster.com) through the lightening holes in the leading-edge ribs of my Murphy Rebel Elite. I supported the conduit at every other rib with Adel clamps. I haven't installed the wings yet, nor have I pulled any wires, so I can't give you much info on how well it works.
Lynn Cole
Murphy Elite #709
LynnCole(at)foxvalley.net (LynnCole(at)foxvalley.net)
On Apr 8, 2012, at 8:03 PM, rayj wrote:
[quote]--> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>
Greetings,
I'm planning on completing my aircraft with a minimum electrical system and providing a way to install wingtip lights later. Any experiences anyone has with using different types of conduit in wings would be appreciated.
Thanks in advance,
Raymond Julian
Kettle River, MN
- The AeroElectric-List Email Forum -
--> http://www.matronics.com/Navigator?AeroElectric-List
- MATRONICS WEB FORUMS -
--> http://forums.matronics.com
- List Contribution Web Site -
Thank you for your generous support!
-Matt Dralle, List Admin.
--> http://www.matronics.com/contribution
jfolkerts1(at)gmail.com Guest
Posted: Sun Apr 08, 2012 5:58 pm Post subject: Conduit in wings. |
Ray,
On my Murphy Super Rebel, I used some ½ PEX tubing I had. It weighed roughly the same as the alternatives, and I like the smooth walls for pulling wires vs. the flexible conduit. It also had a higher temperature spec than the flexible conduit. I attached it to the ribs with aircraft grade zip ties. To keep the ribs from cutting into the tubing, I purchased some door edge guard material from a local auto shop. It came in 36” strips and I cut it up so the tubing and the back of the zip tie were pulled against the edge guard vs. a sharp rib edge. I anchored the tubing to the root rib with a PVC Pex coupling that I cut in half. That gave me a flange on the outside and the pex ribs on the inside. I used proseal to mate it and a clamp, then removed the clamp when the proseal dried.
Jerry Folkerts
SR 2500 #093
www.mykitlog.com/jfolkerts
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Lynn Cole
Sent: Sunday, April 08, 2012 8:43 PM
Subject: Re: Conduit in wings.
Hi Ray,
Lynn Cole
Murphy Elite #709
Greetings,
Thanks in advance,
Raymond Julian
Kettle River, MN
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
ulflyer(at)verizon.net Guest
Posted: Sun Apr 08, 2012 7:36 pm Post subject: Conduit in wings. |
EMT (thin wall) conduit is still heavy - a little here a little there adds up. Ya, Plex isn't bad - light. One I used on another UL type aircraft is drip irrigation tubing. Another factor is what burns and what doesn't, might be a factor to consider for fire spread.
jerryb
At 08:57 PM 4/8/2012, you wrote:
[quote]Ray,
Jerry Folkerts
SR 2500 #093
From: owner-aeroelectric-list-server(at)matronics.com [ mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of Lynn Cole
Hi Ray,
Lynn Cole
Murphy Elite #709
--> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net) >
Greetings,
Thanks in advance,
Raymond Julian
Kettle River, MN
Posted: Sun Apr 08, 2012 7:52 pm Post subject: Conduit in wings. |
Thanks to all who wrote. Fire is a concern with some of the plastic
conduit mentioned. I'm concerned about just pulling wire and leaving it
loose to rub on wing ribs, even with grommets. I'm thinking some very
thin wall al, if I can find it. If I could find some fire resistant
composite tubing, I'd look at it but I think it might be too expensive.
Thanks again.
Raymond Julian
Kettle River, MN
On 04/08/2012 10:34 PM, jerb wrote:
| Quote: | EMT (thin wall) conduit is still heavy - a little here a little there
jerryb
> Ray,
> Jerry Folkerts
> SR 2500 #093
> www.mykitlog.com/jfolkerts <http://www.mykitlog.com/jfolkerts>
> *From:* owner-aeroelectric-list-server(at)matronics.com
> [mailto:owner-aeroelectric-list-server(at)matronics.com] *On Behalf Of
> *Lynn Cole
> *Sent:* Sunday, April 08, 2012 8:43 PM
> *To:* aeroelectric-list(at)matronics.com
> *Subject:* Re: Conduit in wings.
> Hi Ray,
> <http://www.mcmaster.com>) through the lightening holes in the
> it works.
> Lynn Cole
> Murphy Elite #709
> LynnCole(at)foxvalley.net <mailto:LynnCole(at)foxvalley.net>
> <raymondj(at)frontiernet.net <mailto:raymondj(at)frontiernet.net> >
> Greetings,
> Thanks in advance,
> Raymond Julian
> Kettle River, MN
> http://forums.matronics.com <http://forums.matronics.com/>
JohnInReno
Posted: Mon Apr 09, 2012 4:50 am Post subject: Conduit in wings. |
I used 1/2 inch CPVC pipe and plastic pipe hangers. CPVC is lighter
than regular PVC and it used for the hot water lines in motor homes.
john
On 4/8/2012 6:03 PM, rayj wrote:
Greetings,
Thanks in advance,
Raymond Julian
Kettle River, MN
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
klehman(at)albedo.net Guest
Posted: Mon Apr 09, 2012 5:12 am Post subject: Conduit in wings. |
I've been told by a plastic manufacturer that cpvc is about the worst
plastic out there for toxic smoke if it ever does burn. The translucent
poly pipe used for things like ice maker water supply lines might be a
better choice and more flexible if that matters. Several sizes
available. I do favor non conductive conduit rather than metal. It helps
to leave a string in the conduit if you plan to pull extra wires through
later. The previously mentioned plastic snap in grommets are handy for
running conduit through metal ribs.
Ken
On 09/04/2012 8:48 AM, John Morgensen wrote:
<john(at)morgensen.com>
I used 1/2 inch CPVC pipe and plastic pipe hangers. CPVC is lighter than
john
> Greetings,
> Thanks in advance,
> Raymond Julian
> Kettle River, MN
