firestarii(at)hotmail.com Guest
Posted: Sun May 28, 2006 3:25 am Post subject: Subaru EA81, Dave Johnson redrive conversion, mount for Mode |
I recently sold my Model III project to an owner who already had a
powerplant, so the Subaru conversion approximately 75% complete is up for
sale. This should really jumpstart anyone out there who plans to install a
Subaru conversion and can't ante up the big dollars for a complete factory
built unit.
I purchased this project as part of a Kitfox airframe that was 85%
completed. Due to job changes I was not able to complete either the airplane
or the engine. Here are the details on the engine:
Custom built, high-output EA-81 Subaru engine with Dave Johnson re-drive and
engine mount. Includes Holley single-barrel carb, some cooling system parts,
complete Stewart-Warner gauges, EGT, water temp, ammeter, others, spare oil
filter, alternator. Detailed digital pics available. Extra parts, a spare
core Subaru engine, builders manuals, documentation.
This is a loaded package for the builder who wants to fly behind an engine
assembled with great workmanship. Engine project requires some parts for
completion--estimate 75% finished.
Features:
1980 vintage engine with 40K original miles, stripped down and built back up
with cylinders bored .030 oversize, new factory pistons, performance rings,
all-new engine bearings. Crankshaft machined and polished, then balanced.
Brand new high volume oil pump for constant 60 psi cold/50 psi hot. High
performance grind camshaft, brand new cam followers. Finished engine should
develop 110 hp. Requires radiator and exhaust. Dave Johnson redrive and
powder-coated engine mount. 1.94 : 1 reduction ratio. Designed to give 2800
rpm at the prop at full throttle. SAE #1 prop hub from machined aluminum.
Contact me off-list for a full list of parts included and photos of
everything. Thanks!
The engine is listed on www.barnstormers.com with a few pictures, so check
it out. I have lots of other pictures available.
smokey_bear_40220(at)yaho Guest
Posted: Sun May 28, 2006 7:57 am Post subject: Subaru EA81, Dave Johnson redrive conversion, mount for Mode |
Hi Bruce,
Can I ask you where I can find one of those high
volume oil pumps for my Soob? My pressure is about 10
psi lower than I would like.
Kurt S.
wingsdown(at)comcast.net Guest
Posted: Sun May 28, 2006 12:33 pm Post subject: Subaru EA81, Dave Johnson redrive conversion, mount for Mode |
Kurt,
What pressure are you seeing and at what temp? Are you using a
semi-synthetic. I had great results with Castrol 20-50 Semi synthetic.
Rick
Posted: Sun May 28, 2006 10:03 pm Post subject: Subaru EA81, Dave Johnson redrive conversion, mount for Mode |
Rick,
I am using non-synthetic Castrol 20W50. OK temps on
the last flight of around 190-195, but 40-50 psi.
More around 40. I usually see a good 50. This last
few months the pressure has dropped and been variable,
but no leaks?
I bought some aviation 100 weight (from Sams Club in
FL) to try out. Have you used this?
If it gets hotter than this flight I can not pull to
idle and keep the pressure above 30 psi. That is what
I worry most about, idle pressure for landing. I have
seen it go to 20 on rollout, so I keep the rpm up.
I know there is very little force on the bearings at
idle, but I want to keep that front bearing out of
trouble.
I wish it had roller bearings on the crank.
Kurt S.
--- wingsdown <wingsdown(at)comcast.net> wrote:
Kurt,
you using a
Rick
Posted: Mon May 29, 2006 6:53 am Post subject: Subaru EA81, Dave Johnson redrive conversion, mount for Mode |
I believe the semi-synthetic will be more stable. Done quite a bit of
research over the years, no degree but much reading and question asking.
Actually a high quality multi will be more stable at higher temps than
it single weight cousin. Synthetic are always better at higher temps
with one exception. When the reach the critical temp of around 360F the
fail catastrophically not gradually. Cant remember the actual temp.
Don't use the aviation oil. It is not designed for the tight tolerances
in the modern engines. And according to one of the leading aviation oil
rep whose name and company I will leave out, informed me automotive oils
far exceed aviations oil in additive packages due to their ash less
requirement. I think the Castro GTX semi 20-50 will solve your problem
and give you better protection all the way around. If you run automotive
fuel the by all means go to a full synthetic.
Now the issue of why things have changed. It could be serious or just
coincidental to maybe something you haven't noticed.
Worse case bearings have worn and tolerances have opened up a bit. Not
unheard of or necessarily that bad. Oil pump bypass spring weak and not
holding pressure as it shold. Easy replacement or fix. Might try
shimming the spring a bit. This will have the effect of raising pressure
on both ends od the scale cols and hot since the spring is not
progresive. If you look in the manual you will see a diagram, I think.
Or could just be the oil has become diluted for what ever reason and
just needs a change. I think you temps are good for a lot of reasons.
Also agree the pressur e should stay above 30 to keep bearings alive. If
you oil cooler capacity is large enough you should be able to do a
standard pattern approach and be cool enough for a safe final power back
landing and taxi.
Your right 20PSI is too low even for taxi and bearings can be damaged. I
think the 20-50 semi will help , some. Think I would look into a higher
capacity cooler or better heat exchange area/ configuration.
Roller bearing are another bag altogether. Great for super high reving
engines but are very susceptible to damage from detonation. Let us know
what you do and the results.
Rick
