Michel
Posted: Mon May 29, 2006 1:34 am Post subject: SV: Kitfox tanks and blended ethanol |
| Quote: | From: Don Smythe [dosmythe(at)cox.net]
West System Epoxy is similar to maple syrup.
Pretty much so! Indeed, Don, although the taste is slightly different!
I know it would be difficult because, if it wasn't ... everybody would already do it. I am certainly not a genius and will not pretend I know things better than others. I simply thought that the idea was worth investigating.
I know that, in a relatively cold environment, say 15 degrees C, with the correct mixture, epoxy will take a few hours to turn jelly, then hard. Say, one could get a long bead of epoxy at the bottom of the tank. Then turn it 45 degrees for say, 20 minutes, and so on. I think that, even maple syrup would get a chance to flow by gravity.
Of course, it would require careful testing. My hope was that, you guys, were doing the testing, then give me the correct recipie so that I can do the same in the correct way. ... (just kidding!)
Cheers,
Michel
