ggower_99(at)yahoo.com Guest
Posted: Sat May 27, 2006 12:56 pm Post subject: Riveting oneself into a corner. |
Hello Tommy,
I had a similar problem in another project... I solved it using a little nut that fits in the rivet nail, goes betwen the rivet and the hand rivet gun.
This way, you can bend a little the nail to get the rivet done. The rivet will not got the round finish, but will hold ok.
Make a test in some scrap material first.
Saludos
Gary Gower
Tommy Walker <twalker(at)cableone.net> wrote:
Like the proverbial painter, I've gotten myself into a corner and wondered if anyone has a solution short of drilling all the rivets out and starting over correctly.
If you look at the attached picture, you can see where my problem is. I can't get the two holes in the 7F12-4 Gusset riveted. The problem is caused by the 15 degree angle in the 7F5-2SP Side Channel. I should have set these two rivets in the Gusset and tubes before I set it in place, but I didn't There's not enough room for my manual or air powered rivet guns to set the rivet flush. I tried grinding off the side of the nose on the rivet gun, but still can't get the head to set flush.
Any ideas would be appreciated. I bought a cheap HF rivet gun with a swivel head thinking I might be able to wiggle around and get it to work.... Alas, all my wiggling has been for naught.
[Rolling Eyes]
Tommy Walker in Alabama
Tommy Walker
http://forums.matronics.com/viewtopic.php?p=36646#36646
http://forums.matronics.com//files/tightfit_107.jpg
Ring'em or ping'em. Make PC-to-phone calls as low as 1/min with Yahoo! Messenger with Voice.
Peter Barthold
