BobbyPaulk(at)comcast.net Guest
Posted: Thu May 03, 2012 11:35 am Post subject: O-470 |
A friend has an O-470-M on a Bearhawk and it has a oil consumption rate of a quart per hour. It was worse than this before he honed the cylinders and installed new rings. He also lapped the valves while it was down. He has 35 hrs. on the new rings and still on mineral oil. Can anyone tell me what may be wrong or what we can do to slow down the oil consumption.
| | - The Matronics Continental-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Continental-List |
BARRY CHECK 6
Posted: Thu May 03, 2012 12:06 pm Post subject: O-470 |
Bobby:
Without seeing the engine and the cylinder bore I can only guess...
I'm guessing three (3) things;
1 - That the Cross-Hatch pattern in the cylinders are honed away.
2 - That he used the wrong Rings... Chrome Cylinders get steel rings. Steel cylinders get chrome rings.
3 - Rings put in up-side down.
You can visually inspect with a bore scope for the hatch pattern.
Trying to figure out what rings were uses can only be done by reading the paperwork for the order placed. And hopping that the correct rings were supplied.
And if the rings were installed up-side down - - - Pull the cylinder off.
Barry
On Thu, May 3, 2012 at 3:35 PM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
[quote] A friend has an O-470-M on a Bearhawk and it has a oil consumption rate of a quart per hour. It was worse than this before he honed the cylinders and installed new rings. He also lapped the valves while it was down. He has 35 hrs. on the new rings and still on mineral oil. Can anyone tell me what may be wrong or what we can do to slow down the oil consumption.
st" target="_blank">http://www.matronics.com/Navigator?Continental-List
tp://forums.matronics.com
MONTY(at)bpaengines.com Guest
Posted: Thu May 03, 2012 12:54 pm Post subject: O-470 |
If the top compression ring is upside down it won't go together. This ring is 1/2 keystone ( tapered on one edge ). Bottom ring wide edge faces up. Part numbers also go up. However, I have seen rings marked wrong.
If chrome cylinders FLYaDIVE is correct. Never-Chrome on Chrome. IF they are chrome they will not have a cross hatch.
If they are chrome they will either be fractured chrome ( channel chrome ) or " Cermi-Chrome ". They could also be Nickel-silicon ( Cermi-Nil ). The same statement about ring face material applies.
I would have a real good look at the pistons, particularly the ring grooves. Rings have to seal there also. Cylinders can also get out of round in the ring travel and also " washboard ". Caused from too much heat and is usually the result of poor baffling.
Monty Barrett
Barrett Precision Engines, Inc.
Posted: Fri May 04, 2012 5:15 am Post subject: O-470 |
Guys
Thanks for all the input. If we find out what is causing it I will post.
Bobby
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
