arplnplt(at)gmail.com Guest
Posted: Fri May 11, 2012 6:55 am Post subject: Flo Scan K factor |
For those who have a G900X panel, have you adjusted the K factor value for more accurate fuel flow readings? How did you calculate it? Using the K factor that came with my Flo Scan sensor (mounted after the fuel servo, before the spider) , I am showing fuel burn a bit greater than actual. Maybe 2 gallons more in 60 gallons used. This is conservative, but I would like as accurate as possible readings.
Also, has anyone measured the amount of fuel in the lines running from the wing root to the spider on the engine?
Thanks.
Dave Leikam
N89DA
speckter(at)comcast.net Guest
Posted: Fri May 11, 2012 4:08 pm Post subject: Flo Scan K factor |
I have been tweeking mine. I am off 1.5 gal/tank full. I keep a log of several fill ups and calculate the average difference between what the garmin shows and what I actually buy. Then I change my K factor by that amount.
I am thinking that there is some leaking out of the vent if I store the plane before I fly it. That gives me different results from time to time.
Gary Specketer
To: "RV-10 matronics" <rv10-list(at)matronics.com>
Sent: Friday, May 11, 2012 9:55:01 AM
Subject: Flo Scan K factor
--> RV10-List message posted by: David Leikam <arplnplt(at)gmail.com>
Thanks.
Dave Leikam
