bcondrey
Posted: Tue May 15, 2012 4:17 am Post subject: W & B programs |
I asked that specific question of Vans several years ago and answer was that the fwd & aft limits don't change as weight increases to gross.
Bob
On May 15, 2012, at 7:06 AM, "Eric_Kallio" <scout019(at)msn.com> wrote:
I am using Vans limits, was just trying to enter the data into an app that would create a graphical box of the c.g. envelope. Van's published limits to not seem to change as the weight of the aircraft varies. I was just looking to see if anyone had other data that tapers the envelope as weight increased as many airplanes do, or if the c.g. limits were the same throughout the entire weight range of the aircraft.
Eric
http://forums.matronics.com/viewtopic.php?p=373085#373085
jpiper623(at)gmail.com Guest
Posted: Tue May 15, 2012 6:04 am Post subject: W & B programs |
Bob, I don'tknow what you are looking for but I use a program called FlightScale. It is an app on the i-pad. You can set up a graphical envelope and that just add the weights of passangers and baggage and it will automatically adjust or cg limits inside the envelope. I hope this helps. John Z
On Tue, May 15, 2012 at 8:16 AM, Bob <condreyb(at)gmail.com (condreyb(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: Bob <condreyb(at)gmail.com (condreyb(at)gmail.com)>
Bob
On May 15, 2012, at 7:06 AM, "Eric_Kallio" <scout019(at)msn.com (scout019(at)msn.com)> wrote:
> --> RV10-List message posted by: "Eric_Kallio" <scout019(at)msn.com (scout019(at)msn.com)>
> Eric
le, List Admin.
robin(at)PaintTheWeb.com Guest
Posted: Tue May 15, 2012 10:34 am Post subject: W & B programs |
FlightScale looks good (I have not tried it) but Advanced Flight Systems has a free app that also looks nice (not sure about graphical interface) but it is preloaded for many different aircraft including the RX-10. Yes I know, it actually says RX-10.
App name: Weight Balance - Advanced Flight Systems Inc.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Zazulka
Sent: Tuesday, May 15, 2012 7:03 AM
Subject: Re: Re: W & B programs
John Z
Bob
> Eric
le, List Admin.
==============[/b][/quote] V10-List Email Forum -[/b][/quote] >[/b][/quote] :p>[/b][/quote] /o:p>[/b][/quote] tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b][/quote] ==============[/b][/quote] bsp; - MATRONICS WEB FORUMS -[/b][/quote] :p>[/b][/quote] tp://forums.matronics.com[/b][/quote] ==============[/b][/quote] bsp; - List Contribution Web Site -[/b][/quote] e> bsp; -Matt Dralle, List Admin.[/b][/quote] bution">http://www.matronics.com/contribution[/b][/quote] ==============[/b] [b]
rv10flyer(at)verizon.net Guest
Posted: Tue May 15, 2012 10:51 am Post subject: W & B programs |
only reports weights for gross weight issues, not W&B as I recall from my usage a while back.
Pascal
Sent: Tuesday, May 15, 2012 11:33 AM
Subject: RE: Re: W & B programs
Robin
John Z
Bob
| Quote: | --> RV10-List message posted by: "Eric_Kallio" <scout019(at)msn.com (scout019(at)msn.com)>
Eric
le, List Admin.
==============[/b]V10-List Email Forum -[/b]>[/b]:p>[/b]/o:p>[/b]tor?RV10-List">http://www.matronics.com/Navigator?RV10-List[/b]==============[/b]bsp; - MATRONICS WEB FORUMS -[/b]:p>[/b]0tp://forums.matronics.com[/b]1==============[/b]2bsp; - List Contribution Web Site -[/b]3e> bsp; -Matt Dralle, List Admin.[/b]4bution">http://www.matronics.com/contribution[/b]5==============[/b]67
8
