Kelly McMullen
Posted: Sat Jun 02, 2012 9:02 pm Post subject: Another plans omission? |
I have looked through the plans from the point where the door halves are glassed together(Chap 45-50), trying to find when you are supposed to put in the rivets that were left out to be able to cleco the door halves in place during bonding. I have not found one mention. Obviously they also were not prepared anywhere in the plans for flush rivets, so it seems that countersinking is the only choice at this point. While I don't expect the later chapters to discuss deburring etc, I also don't expect to have them leaving more than a dozen rivet holes empty on each side of the completed fuselage.
Kelly
Still fighting to get out of door fiberglass hell
A&P/IA, EAA Tech Counselor
KCHD |
Bob Turner
Posted: Sat Jun 02, 2012 9:20 pm Post subject: Re: Another plans omission? |
Fill the holes with flox.
_________________ Bob Turner
RV-10 QB |
john(at)trollingers.com Guest
Posted: Sun Jun 03, 2012 3:34 am Post subject: Another plans omission? |
Kelly,
Are you talking about the rivets around the bottom of the door frame
that were left open to cleco the door in place? I do not know if I
did it on purpose or not, but all those were dimpled on my fuselage,
they do have beefy aluminum behind them if I recall so countersinking
should not be a problem.
John
On Sun, Jun 3, 2012 at 1:01 AM, Kelly McMullen <apilot2(at)gmail.com> wrote:
| Quote: | I have looked through the plans from the point where the door halves are
fuselage.
Kelly
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Sun Jun 03, 2012 4:10 am Post subject: Re: Another plans omission? |
I don't recall whether our QB fuse were dimpled, I am 90% sure they were. Section 29-15 clearly shows dimpling those holes, and 29-17 clearly shows leaving out the rivets.
_________________ Bill
WA0SYV
Aviation Partners, LLC |
philperry9
Posted: Sun Jun 03, 2012 9:17 am Post subject: Another plans omission? |
IIRC, the plans said not to simple those holes when the skins were being dimpled. I'm just countersinking mine.
Phil
On Jun 3, 2012, at 9:50 AM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Ah ha, another wonderful omission by the "new" QB facility. They were not dimpled on my QB built in summer of 2009, nor were the longerons behind them countersunk. Which still leaves the apparent fact that they never call for you to actually place rivets in the holes.
Kelly
40866
On Sun, Jun 3, 2012 at 5:10 AM, bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
