joeing701(at)simnet.is Guest
Posted: Sun Jun 17, 2012 5:21 am Post subject: Rotax 912 ul engine problems |
Hello list members.
We really need your expert help regarding a Rotax 912 ul 80 hp engine
problem my friend has been dealing with for the past three years or
ever since he bought the plane.
My friend bought this Kitfox II aprox. 1990 model from USA and has
been trying to solve a rough running engine problem, and is about to
give up on the project.
Here is the symptoms:
Engine starts perfectly and runs on both mags with a drop within 100
rpm. When airborne the rough running starts around 3500-4500.
Everything shakes very violently and aircraft looses altitude. Most
often you can give it full power to continue flying, but when power is
reduced, the shaking starts again.
What has been done:
All fuel system has been checked, cleaned many times. Fuel pump
replaced, including electrical pump added. Carbs have been cleaned,
all jets replaced with new, new throttle cable. See here:
http://www.chiefaircraft.com/aircraft/fuel-systems-carbs/throttle-cables-rotax/ma-mct100d048.html
Everything has been adjusted and calibrated according to Rotax
manual. The mid range was suspected so we have tried to fine tune the
jet needle by adjusting the clip, but does not seem to change anything.
So we have almost ruled out fuel problems and are beginning to suspect
the ignition system. Most likely the trigger system because the mag
drop is within the normal drop, i.e. 90-100 rpm.
The running of the engine does not seem to change after it warms up,
so the coils do not seem to be the problem.
All wires have been checked and inspected.
The engine sat for some time in a unheated trailer, before my friend
bought the plane. He did clean the triggers of rust which had formed
on the metal part.
The triggers are really hard to reach on the Kitfox due to tight space
between the firewall and engine.
The engine will need to be removed to do any work on the charging and
trigger system.
Before we do that, I just wanted to ask you experts if you had any
other ideas?
Really appreciate any help.
Best regards,
Johann G.
Iceland.
klinefelter.kevin(at)gmai Guest
Posted: Sun Jun 17, 2012 8:10 am Post subject: Rotax 912 ul engine problems |
I believe it is very unlikely that the problem is ignition. Replace the spark plugs with the proper type and gap them properly. Do the pull test on all the plug caps. That should cover the most common ignition problems.
You mention a new throttle cable, and other carb parts. When we're the carbs last rebuilt? If its been several years I would start with having the carbs rebuilt properly.
It is helpful to know what work was done to the engine immediately before the problem started.
Kevin
On Jun 17, 2012, at 6:21 AM, Jóhann Jóhannsson <joeing701(at)simnet.is> wrote:
Hello list members.
We really need your expert help regarding a Rotax 912 ul 80 hp engine problem my friend has been dealing with for the past three years or ever since he bought the plane.
My friend bought this Kitfox II aprox. 1990 model from USA and has been trying to solve a rough running engine problem, and is about to give up on the project.
Engine starts perfectly and runs on both mags with a drop within 100 rpm. When airborne the rough running starts around 3500-4500. Everything shakes very violently and aircraft looses altitude. Most often you can give it full power to continue flying, but when power is reduced, the shaking starts again.
What has been done:
All fuel system has been checked, cleaned many times. Fuel pump replaced, including electrical pump added. Carbs have been cleaned, all jets replaced with new, new throttle cable. See here:
Everything has been adjusted and calibrated according to Rotax manual. The mid range was suspected so we have tried to fine tune the jet needle by adjusting the clip, but does not seem to change anything.
So we have almost ruled out fuel problems and are beginning to suspect the ignition system. Most likely the trigger system because the mag drop is within the normal drop, i.e. 90-100 rpm.
The running of the engine does not seem to change after it warms up, so the coils do not seem to be the problem.
The engine sat for some time in a unheated trailer, before my friend bought the plane. He did clean the triggers of rust which had formed on the metal part.
The triggers are really hard to reach on the Kitfox due to tight space between the firewall and engine.
The engine will need to be removed to do any work on the charging and trigger system.
Before we do that, I just wanted to ask you experts if you had any other ideas?
Best regards,
Johann G.
Iceland.
fygdog(at)yahoo.com Guest
Posted: Sun Jun 17, 2012 8:34 am Post subject: Rotax 912 ul engine problems |
check that the vent tubes have not been relocated to an improper location
--- On Sun, 6/17/12, klinefelter.kevin(at)gmail.com <klinefelter.kevin(at)gmail.com> wrote:
From: klinefelter.kevin(at)gmail.com <klinefelter.kevin(at)gmail.com>
Subject: Re: Rotax 912 ul engine problems
To: "rotaxengines-list(at)matronics.com" <rotaxengines-list(at)matronics.com>
Date: Sunday, June 17, 2012, 10:09 AM
--> RotaxEngines-List message posted by: klinefelter.kevin(at)gmail.com (klinefelter.kevin(at)gmail.com)
Kevin
On Jun 17, 2012, at 6:21 AM, Jóhann Jóhannsson <joeing701(at)simnet.is (joeing701(at)simnet.is)> wrote:
| Quote: | --> RotaxEngines-List message posted by: =?ISO-8859-1?Q?J=F3hann_J=F3hannsson?= <joeing701(at)simnet.is (joeing701(at)simnet.is)>
Hello list members.
What has been done:
Best regards,
Johann G.
Iceland.
= Use the Matronics List Features --> http:========================http://www.matronics.com/contributio==============
| [quote][b]
Roger Lee
Posted: Sun Jun 17, 2012 9:35 am Post subject: Re: Rotax 912 ul engine problems |
This really sounds like one carb trying to control one side of the engine at let's say 4400 rpm and the other at 4800 rpm.
The other guys have good suggestions with the vent tubes being placed properly and new plugs gapped at .023 - .027. I hope the carbs have been totally rebuilt if not carbs that old need to be rebuilt for several reasons. The carbs need to be absolutely synced. It most likely isn't the ignition, but can't be ruled out just yet, but is improbable. The fuel systems back then didn't have re-circulation lines. You should have one especially if you have the new style fuel pump. Does it make any difference if he shuts down the electric pump? I wouldn't run it all the time, only when needed. An engine that old may have air leaks in a number of rubber part areas. I hope these have all been changed.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
Posted: Sun Jun 17, 2012 10:45 am Post subject: Rotax 912 ul engine problems |
Thank you all for your advice.
The plugs are new and gapped at .025. Vent tubes are the same and have
not been routed down in the airstream. Carbs have been synced with a
new vacuum meter. The electric fuel pump has only been used after the
new style pump was replaced. The electrical pump is only used to prime
the system before start up and during take-off. Everything and I mean
everything has been replaced in the carbs. New jets, rubber rings,
bowl gasket and everything cleaned. We even tried new carbs, but they
were for a Rotax 914 and they just overfilled because of too much fuel
pressure from the 912 fuel pump. We were told that the fuel pressure
for 914 is lower. When the engine started shaking, the fuel shut off
valve in the carbs could not do its job with the higher pressure which
caused the overfill situation.
The carb rubber socked has been replaced. All fuel lines are new. Do
not know where you could have fuel leak in other rubber parts.
Roger, where would that be other than the carbs and the rubber socket?
Johann G.
Iceland.
On 17.6.2012, at 17:35, Roger Lee wrote:
Roger Lee
Tucson, Az.
Light Sport Repairman - Maintenance Rated
Rotax Repair Center - Heavy Maint. Rated
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=375916#375916
Roger Lee
Posted: Sun Jun 17, 2012 11:20 am Post subject: Re: Rotax 912 ul engine problems |
Hi Johann,
The other places would have been the carb sockets, fuel hose and the "O" rings in the carb, but you have all these done. Are the needle clips in the #3 position? If you have a new style mechanical Rotax fuel pump you must have a re-circulation line. Over pressure could cause this problem. The 914 carbs should have worked except the #1-3 carb needle is in the #2 needle clip position. Have the engine mounts been replaced? This would cause a shake and affect the carbs. Have you done a differential compression test?
If I read your post right, the engine runs smooth up to 3500 and then it starts to shake up to 4500 and then as you go past that and up into higher rpms the shake quits?
If this is the case then I would want someone who really knows the Rotax carbs to take a look and check the needle and main jet sizes and alignment of all aligned parts. Something seems amiss here.
Tucson, Az.
Cell 520-349-7056 |
Posted: Sun Jun 17, 2012 12:14 pm Post subject: Rotax 912 ul engine problems |
The needle clips are in #3 position. The new pump has a over-pressure
line out which should be routed to the same place as the carb overfill
lines. The engine mounts have not been replaced since my friend bought
the plane, and most likely not by the previous owner. We will look at
that.
Last time we ran the engine, the rpm was a little higher when the
shaking started, i.e. above 4500 rpm. It seem to vary a little in this
higher range. Not alway in the mid range. If anyone is the expert in
Rotax carbs in Iceland, it would be us. We have probably worked on the
the most
All the needle and jet sizes are according to the Rotax manual for the
80 hp Rotax 912 ul engine. All new.
Thank you again for all the advice. We will check the engine mounts.
Best regards,
Johann G.
Iceland.
On 17.6.2012, at 19:20, Roger Lee wrote:
Hi Johann,
Roger Lee
Tucson, Az.
Cell 520-349-7056
http://forums.matronics.com/viewtopic.php?p=375924#375924
What colour are the plugs?
\Bob Harrison \G-PTAG
KeysFox
Posted: Sun Jun 17, 2012 12:18 pm Post subject: Rotax 912 ul engine problems |
A big thanks to Roger for sharing his training, experience and time.
Lockwood Aviation (Sebring, Florida) has had a Rotax technician available
by phone (863-655-6229) between 9 and 10 am and 2-3 pm east coast US time
daily.
If a solution does not materialize, they may be able to help. Be prepared
to hold as your call is taken in sequence with other callers.
BJ
Kitfox IV 912
Roger Lee
Tucson, Az.
Cell 520-349-7056
_________________ B Jones
N154K
443-480-1023 |
Posted: Sun Jun 17, 2012 1:51 pm Post subject: Rotax 912 ul engine problems |
Just confirmed from my friend that the compression was checked when he
bought the plane and the total hours were 150 hours. Good and even
compression. Engine mounts are as new. Spark plug color is light brown
on all plugs.
We will borrow carbs from a friends plane this week and do a total
swap. That would eliminate all fuel problems. I will keep you posted
after that.
Thank you all for your advice and a special thanks to Roger.
Johann G.
Iceland.
On 17.6.2012, at 20:17, bjones(at)dmv.com wrote:
available
time
daily.
prepared
BJ
Kitfox IV 912
> engine
> been
> isn't the
> fuel
> one
> all the
> number
> Roger Lee
> Tucson, Az.
> Cell 520-349-7056
Vic Peters
Joined: 30 Oct 2009 Posts: 54 Location: Millinocket, Maine
Posted: Sun Jun 17, 2012 4:19 pm Post subject: Rotax 912 ul engine problems |
Sync and re sync the carbs
_________________ Vic
912ul Xtra
Maine
Too old to cut the mustard but not the cheese. |
Posted: Sun Jun 17, 2012 4:43 pm Post subject: Rotax 912 ul engine problems |
Thank you Vic.
That has been done after every adjustment of the cables and many more. Everything is in very good sync all through. We are still trying to find out if there is any binding in the carb throttle valve. We will change out the carbs this week and find out then.
Johann G.
Iceland.
On 18.6.2012, at 00:18, vic wrote:
| Quote: | Sync and re sync the carbs
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
fgoggio(at)yahoo.com Guest
Posted: Sun Jun 17, 2012 5:16 pm Post subject: Rotax 912 ul engine problems |
Johan.i had. A problem like you are having on a older model 912 the carbs. Were rebuilt three times by rotax repairman. Carbs sycted.over and over.findly put new carbs on.still had problems.replaced. ignition modeals.still had.problems.all started lile yours.findly found the problem to be in the redrive system.needed to be re built.problems wemt away.mine started in flgjt at 4500 rpm.drove the rotax man crazy.swore it could not be the redrive
But was..spmething else to think about.good luck
Frank goggio. Wilmington. Nc
Sent from my Verizon Wireless 4G LTE DROID
-----Original message-----
[quote]From: "Jóhann Jóhannsson" <joeing701(at)simnet.is>
Sent: Sun, Jun 17, 2012 20:42:47 EDT
Subject: Re: RotaxEngines-List: Rotax 912 ul engine problems
Thank you Vic.
Johann G.
Iceland.
[quote]Sync and re sync the carbs
Posted: Sun Jun 17, 2012 6:42 pm Post subject: Rotax 912 ul engine problems |
Hello Frank.
Thank you very much for that information. This is something we will definitely look into. What kind of gear box did you have? The standard 2,27 or with the slipper clutch?
Best regards,
Johann G.
Iceland.
On 18.6.2012, at 01:16, fgoggio(at)yahoo.com (fgoggio(at)yahoo.com) wrote:
[quote]Johan.i had. A problem like you are having on a older model 912 the carbs. Were rebuilt three times by rotax repairman. Carbs sycted.over and over.findly put new carbs on.still had problems.replaced. ignition modeals.still had.problems.all started lile yours.findly found the problem to be in the redrive system.needed to be re built.problems wemt away.mine started in flgjt at 4500 rpm.drove the rotax man crazy.swore it could not be the redrive
| Quote: | From: "Jóhann Jóhannsson" <joeing701(at)simnet.is (joeing701(at)simnet.is)>
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Thank you Vic.
Johann G.
Iceland.
| l>
Posted: Mon Jun 18, 2012 2:05 am Post subject: Rotax 912 ul engine problems |
We have tbe regular gear box.2,27.tbe way we found it we took the prop of and ran the engine.if you this be sure to do this at low rpm. Frank
Sent: Sun, Jun 17, 2012 22:41:47 EDT
Hello Frank.
Best regards,
Johann G.
Iceland.
On 18.6.2012, at 01:16, fgoggio(at)yahoo.com wrote:
| Quote: | Johan.i had. A problem like you are having on a older model 912 the
the redrive
Thank you Vic.
Johann G.
Iceland.
On 18.6.2012, at 00
Thom Riddle
Posted: Mon Jun 18, 2012 3:16 am Post subject: Re: Rotax 912 ul engine problems |
One thing I have found to cause rough running is poor connection between the spark plug wires and spark plug connector/cap. I've run across this several times. Make sure all are screwed in all the way clock-wise. After the first time I encountered this, I always check them on each condition inspection and mark the intersection with torque-seal or equivalent so they can be visually checked in the future.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Dick Maddux
Posted: Mon Jun 18, 2012 3:46 am Post subject: Rotax 912 ul engine problems |
Johann,
As Frank mentioned ,we too had a similar problem in a Paradise P-1. It would be rough in mid range.It was silky smooth so long as full power was applied (as in climbout) but upon power reduction the roughness would start and the airplane would vibrate like hell ! At one point during troubleshooting, I even shut the engine down and glided the airplane thru various speeds to see if it was airframe related ...it wasn't.
It drove us nuts trying to find it. We changed props,tightened mounts,checked/synced carbs,etc,etc. Finally we sent the gearbox off to Lockwood for a re shim/rebuild as a last resort and that did it ! The engine did not have that much time and I would have sworn that was not the problem but it fixed it !
My Kitfox had a similar problem but I was able to fix it by replacing the throttle cables as one of them was apparently slightly sticking at mid range throwing the carbs out of balance. Check the "swivel" nuts on the carbs for sticking also.
That is my two cents.
Good luck !!
Dick Maddux
Milton,Fl
sdemeyer
Posted: Mon Jun 18, 2012 5:16 am Post subject: Rotax 912 ul engine problems |
Same exact problem here. Rebuilt carbs several times and changed many ignition components and nothing worked. After months of troubleshooting I gave up and flew the plane to a Rotax dealer. He rebuilt the gearbox and the problem went away. I had about 500 hours on the gearbox, 80HP Rotax.
Roger Lee
Posted: Mon Jun 18, 2012 11:59 am Post subject: Re: Rotax 912 ul engine problems |
Hi All,
Gearbox's can certainly cause engine roughness, but I personally find the owners with Vernier type throttle cables to have more issues than others. The thicker wire to these type cables causes them to slightly stick in the sheath and when you operate the throttle one carb won't go back to exactly the same place. This makes one side of the engine try to run at let's say 5000 rpm while the other side tries to run at 5300 rpm. This opposing action makes things rough and not good for the long term health of the engine. This can make the carb sync procedure an headache too.
Tucson, Az.
Cell 520-349-7056 |
Posted: Mon Jun 18, 2012 12:46 pm Post subject: Rotax 912 ul engine problems |
| Quote: | The thicker wire to these type cables causes them to slightly stick in the
the same place.
Are you referring to vernier throttles where the cables spit at the
throttle. McFarLane makes this one:
http://www.mcfarlane-aviation.com/Details.aspx?Article=199
I don't see how what you are describing could happen with a conventional
vernier throttle where there is only a single cable that connects to an
external splitter.
-- Craig
