tomhanaway
Posted: Wed Jul 04, 2012 3:09 am Post subject: avipak strobes not firing during flight |
Just did my first night flight after completing phase 1.
I have an Avipak box firing wing and tail strobes. If it's just on battery power on the ground, all strobes work fine.
Once flying, the strobes stopped firing. If I switched them off and on, I could see the wing tips flashing for one or two sequences, then nothing.
When I returned to ground and shut down engine, the strobes were working fine again.
My guess is it's somehow connected to alternator output, which would increase at cruise power. However, no issues with any other electronics.
Any suggestions appreciated.
__________________
Tom Hanaway
Boynton Beach, FL
RV-10/N518TP
Phase I completed 6/12/2012
Posted: Thu Jul 05, 2012 5:36 am Post subject: avipak strobes not firing during flight |
Tom,
Alternator output potential increases with higher power settings (ie. cruise power), but the power itself does not necessarily increase if everything is working correctly. I usually see the highest output shortly after start for a couple of minutes for obvious reasons, but in cruise it is just putting out what the system is using if everything is working correctly. In some planes I get a whine when I first start and while taxiing because the battery needs to be charged back up, but that usually goes away before takeoff. It could have something to do with the engine running, but nothing specific comes to mind. I'd try talking to Avipak and also make sure that all wiring connections are good. It could be that vibration is causing a connection to fail.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
C: 352-427-0285
F: 815-377-3694
On Jul 4, 2012, at 7:09 AM, tomhanaway wrote:
__________________
Tom Hanaway
Boynton Beach, FL
RV-10/N518TP
http://forums.matronics.com/viewtopic.php?p=377229#377229
rene(at)felker.com Guest
Posted: Thu Jul 05, 2012 5:55 am Post subject: avipak strobes not firing during flight |
Bus voltage will be higher with the alternator on. Try testing with the
engine running, but alternator field off.
What is the bus voltage when you are at full power?
Rene' Felker
N423CF
801-721-6080
tomhanaway
Posted: Thu Jul 05, 2012 1:43 pm Post subject: Re: avipak strobes not firing during flight |
Latest detective work
Thought I'd test my capacitor theory. Turned battery on, engine off, switched strobes on. Fired perfectly for about 4 minutes and then stopped. Turned switch off, waited thirty seconds, turned on again and they flashed about 3 times.
Left switch and battery on and tested voltage at the Avipak box. It was getting 12VDC and not firing.
So, black box is faulty. Unfortunately, the Avipak brand is out of business and Nova does not support them,
Whelen power pack ordered.
rv10flyer(at)verizon.net Guest
Posted: Thu Jul 05, 2012 1:54 pm Post subject: avipak strobes not firing during flight |
did you call strobes n more? they have a Avipak version strobe system.
tomhanaway
Posted: Thu Jul 05, 2012 4:09 pm Post subject: Re: avipak strobes not firing during flight |
Pascal,
I looked at the strobesnmore website but the flashers operated at more flashes per minute than I wanted. I feel more comfortable with Whelen's aircraft specific strobe power.
Interestingly, Whelen mentions that power supplies that have not been used for a long period of time (the guide references earlier year models), may lose polarity in the capacitor. Thus, when subjected to full 12VDC power, they quickly overheat. This sounds like what was happening to mine. It's certainly sat for a long time not being used.
The fix is to run 75% power to the unit for 10 or 15 minutes to reconfigure the capacitor. I may try this. I suspect a standard 9v battery may not have enough power but I can't think of any other 9v source.
Tom
Posted: Thu Jul 05, 2012 4:23 pm Post subject: avipak strobes not firing during flight |
Good to hear!
I wonder if a battery charger would work? When I was doing my panel hookup I
used a computer power supply that was "surplus" to me and I also used a RC
battery charger. Both were enough to power the strobes and LED position
lights. Easy hookup with alligator clips.
The 9v battery did work for my LED's but they weren't enough for the strobe
power supply. May be worth a try however.
Best of success with this!
Pascal
john.maccallum(at)bigpond Guest
Posted: Fri Jul 06, 2012 12:09 am Post subject: avipak strobes not firing during flight |
Don't hook a battery charger up to the Aircraft's Busses unless there is a
battery as well!
The lack of regulation and the ripple on the battery charger's output will
do bad things to the Avionics!
A computer power supply should be ok but I would still leave a battery in
parallel just as insurance.
Cheers
John MacCallum
Builder #41016
VH-DUU
psychobob96(at)gmail.com Guest
Posted: Sat Jul 07, 2012 12:53 am Post subject: avipak strobes not firing during flight |
Possibly try several 9 V batteries connected in parallel?
Jason. On Jul 6, 2012 4:55 AM, "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)> wrote:[quote] --> RV10-List message posted by: "Pascal" <rv10flyer(at)verizon.net (rv10flyer(at)verizon.net)>
Good to hear!
I wonder if a battery charger would work? When I was doing my panel hookup I used a computer power supply that was "surplus" to me and I also used a RC battery charger. Both were enough to power the strobes and LED position lights. Easy hookup with alligator clips.
The 9v battery did work for my LED's but they weren't enough for the strobe power supply. May be worth a try however.
Pascal
Bob Turner
Posted: Sat Jul 07, 2012 9:04 am Post subject: Re: avipak strobes not firing during flight |
My whelan power supply pulls 7 amps. That takes a pretty sizeable battery.
_________________ Bob Turner
RV-10 QB |
