Bending ring terminals on superflex-battery cables...
mburbidg(at)gmail.com
PostPosted: Sun Jul 08, 2012 7:48 pm    Post subject: Bending ring terminals on superflex-battery cables... Reply with quote
Is it acceptable to put a 90 degree bend in the ring terminals on the superflex-battery cables from B&C so that the cable attaches to terminals without tension?
Michael-
bobnoffs
PostPosted: Mon Jul 09, 2012 3:33 am    Post subject: Bending ring terminals on superflex-battery cables... Reply with quote
i would bend it once but never again after that. lets see what the expperts say.
 bob noffs
On Sun, Jul 8, 2012 at 10:44 PM, Michael Burbidge <mburbidg(at)gmail.com (mburbidg(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: Michael Burbidge <mburbidg(at)gmail.com (mburbidg(at)gmail.com)>
Michael-
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
stuart(at)stuarthutchison
PostPosted: Mon Jul 09, 2012 4:15 am    Post subject: Bending ring terminals on superflex-battery cables... Reply with quote
If you're tempted to anneal, keep in mind that that cold-worked copper (such as spark plug seals) is annealed by quenching rather than slow cooling like most other metals. The heat required to anneal would need to be quenched to avoid damage to the insulation anyway !
Cheers, Stu
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of bob noffs
Sent: Monday, July 09, 2012 9:30 PM
Subject: Re: AeroElectric-List: Bending ring terminals on superflex-battery cables...
bob noffs
Michael[b]
