lcfitt(at)sbcglobal.net Guest
Posted: Sat Aug 04, 2012 10:19 am Post subject: Everybody ground loops? |
Paul,
I doubt the larger tires make much of a difference. I guess in theory,
since a larger tire has more mass and takes a bit more energy to spin up on
first touch, that it might be a little bit destabilizing if both tires don't
touch simultaneously. A point worth mentioning. The bungee landing gear on
the early Kitfoxes was typically toed in. This will destabilize the the
ground handling. This is a topic touched on from time to time over the
years. Kitfox, I don't recall if it was Denney or Skystar, published a
bulletin regarding toe in and gave a method to check it and then correct it
by tying down the airplane and muscling the gear into alignment. I did that
with my first Model IV and never experienced the squirrely ground handling
that is often referred to. I think that wheel alignment would be one of the
first things I would check. An easy way to get a rough estimate of
alignment is to put a piece of tape on the aft surface of both tires at axle
height and put a vertical line on the tapes. Measure accurately between the
tape marks and then push the airplane forward until the mark is on the
forward side at axle height and measure again. If the measurement is less
than the aft measurement, it is toed in. The wheels should track parallel
or slightly toed out.
Lowell
From: "Paul Folbrecht" <paul.folbrecht(at)veribox.net>
Sent: Saturday, August 04, 2012 7:58 AM
Subject: Re: Everybody ground loops?
akflyerbob wrote:
> I have 3K plus hrs in TD stuff and if it hadn't been for
> AKFLYER I whould have spudded my brand new KF l on
> my first flight.
> To say the least they are rudder unfriendly.
> Now that I can control it, it is a blast, and I am proud to
> own one. Well two, am working on a lll that was never finished.
> If you can fly, you will love the K F.
> Bob.
This is an old thread, but I have to ask you or someone to elaborate on
the "rudder-unfriendly" comment above.
And a new question: do large (tundra) tires make a TD more docile (less
likely to ground loop)?
(I did buy half of that Kitfox. Then I sold it because we had a baby born
over 3 months premature and I spent evenings at the hospital for 3
months+. (He's 3 now, doing good, and loves airplanes along with his
sister.) And now I am considering an Avid or Kitfox again. Still no TD
endors. but I did end up getting about 50 hours in a Challenger II so I
have light-plane experience. I plan to get the TD endors. in a Cub soon
and see how I like that first.)
http://forums.matronics.com/viewtopic.php?p=380037#380037
sdemeyer
Posted: Sat Aug 04, 2012 12:06 pm Post subject: Everybody ground loops? |
My Kitfox 4 always handled terrible on the ground. It was always a crap shoot on which way it was going to dart off to upon landing. Then I got rid of the bungee gear and installed bush gear. Huge difference!! You could almost fall asleep when landing, after I installed the gear. I think the rudder is just fine but the stock bungee gear sucks.
This is an old thread, but I have to ask you or someone to elaborate on the "rudder-unfriendly" comment above.
And a new question: do large (tundra) tires make a TD more docile (less likely to ground loop)?
(I did buy half of that Kitfox. Then I sold it because we had a baby born over 3 months premature and I spent evenings at the hospital for 3 months+. (He's 3 now, doing good, and loves airplanes along with his sister.) And now I am considering an Avid or Kitfox again. Still no TD endors. but I did end up getting about 50 hours in a Challenger II so I have light-plane experience. I plan to get the TD endors. in a Cub soon and see how I like that first.)
http://forums.matronics.com/viewtopic.php?p=380037#38003w.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronisp; -Matt Dralle, List Adm
7suds(at)Chartermi.net Guest
Posted: Sat Aug 04, 2012 5:52 pm Post subject: Everybody ground loops? |
I had a 4 with the bungee gear and it handled great on the ground, like Lowell mentioned, wheel alignment is an important part of the planes ground handling. I have a 5 now with grove gear and even with the grove I checked and aligned the wheels. Another element of good ground handling is to make sure the tail wheel control cables / springs are tight between the rudder and tail wheel and that the angle of the caster pin in the tail wheel is either straight up or bottom slightly aft, if it is canted forward it will cause the tail wheel to be at a high point when the wheel is straight and will be difficult to hold there because it always want to fall off the high point to the left or right.
Lloyd Cudnohufsky
Northern Michigan
KF 5 Outback
912UL IVO IFA
Status: Flying
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Scott DeMeyer
Sent: Saturday, August 04, 2012 3:06 PM
Subject: Re: Re: Everybody ground loops?
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234567
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Sun Aug 05, 2012 1:46 pm Post subject: Re: Everybody ground loops? |
I'll second the bush gear. After installing the Highwing LLC bush gear on my model IV it became a much easier taildragger to land.
_________________ Kitfox IV-1200
Indianapolis, IN |
Paul Folbrecht
Posted: Sun Aug 05, 2012 2:24 pm Post subject: Re: Everybody ground loops? |
Thank you for the replies. The plane I am looking it is a Avid Mk IV built just a few years ago (meticulously by a gentleman who happens to be one of the original EAA members, and has just recently quit flying).
However, it has the standard gear (not even the wide gear that's an option). The Grove gear is probably as great as everyone says but how on earth can it be north of $2K?
Good news for me is there is a local CFI who can do a tailwheel endors in that plane.
The builder did meticulously set the toe-in (to 0) and says it's a piece of cake to land - of course, he probably has 20K tailwheel landings.
This plane also has the extended wings - that's 35' span! (I can't find any specs but the owner says it still cruises at 90 mph! That seemed very high to me with that kind of wing area and a 582 but it does have an in-flight adjustable prop which may explain it.)
I remain a bit nervous, esp. because my purpose in buying an airplane is to fly with my wife & small children, and then give lots of rides to others (extended family, friends, Young Eagles). How about if I just stay on grass until I'm a real pro? Can we say no chance of looping then unless I decide to take phone call on short final?! Heck, we've got to be able to say that.
Despite that, I sure have an inkling to try this. One issue with tri-gear planes (esp. slower ULs like the Challenger) is that there not much - challenge. I did get bored with that Challenger pretty quickly.
Pat Reilly
Posted: Sun Aug 05, 2012 3:01 pm Post subject: Everybody ground loops? |
Paul, You can learn to land that airplane. Just keep the instructor till you feel comfortable. It isn't really hard to land a tailwheel Kitfox or Avid, especially with that wng. After I rebuilt my Mod 3 Kitfox I had a 20,000 hour pilot that had 1st flighted 10 Kitfoxes as my instructor. I had a couple of ground loops and we couldn't figure out why. The Maul tailwheel bushing was worn so bad the tailwheel would kick out at the slightest sign of side pressure. I replaced the oilite bushing and haven't come close to a ground loop in 2 years. The main difference in landing the tailwheel is be lined up travelling straight down the runway and stay with it for awhile before you answer that cell phone.
Pat Reilly
Mod 3 Rebuilt
Rockford, IL
On Sun, Aug 5, 2012 at 5:24 PM, Paul Folbrecht <paul.folbrecht(at)veribox.net (paul.folbrecht(at)veribox.net)> wrote:
| Quote: | --> Kitfox-List message posted by: "Paul Folbrecht" <paul.folbrecht(at)veribox.net (paul.folbrecht(at)veribox.net)>
http://forums.matronics.com/viewtopic.php?p=380118#380118
target="_blank">http://www.matronics.com/Navigator?Kitfox-List
le, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Pat Reilly
Posted: Sun Aug 05, 2012 3:05 pm Post subject: Everybody ground loops? |
Paul, PS I do have Lowell Fitts bush gear and believe it has saved me a few times. Not so much from ground loops but from damaging the plane after flaring too high, stalling and droping to the runway. I finally corrected that problem....most of the time.
Pat Reilly
Mod 3 582 Rebuilt
Rockford, IL
On Sun, Aug 5, 2012 at 4:46 PM, rawheels <rawheels(at)yahoo.com (rawheels(at)yahoo.com)> wrote:
| Quote: | --> Kitfox-List message posted by: "rawheels" <rawheels(at)yahoo.com (rawheels(at)yahoo.com)>
Ryan Wheeler
Kitfox IV-1200
Indianapolis, IN
http://forums.matronics.com/viewtopic.php?p=380114#380114
le, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Paul Folbrecht
Posted: Sun Aug 05, 2012 3:14 pm Post subject: Re: Everybody ground loops? |
I cannot find a link for the Lowell gear with Google - is there a web site?
(I would like to get the endorsement in the plane as-is, but long-term I will most likely replace the gear. To me it makes sense to spend a bit of money to avoid a future ground loop at all costs. I sure can't stay off pavement forever.)
Pat Reilly
Posted: Sun Aug 05, 2012 3:25 pm Post subject: Everybody ground loops? |
Paul, I believe Lowell's company and site is High Wing Limited. If you still can't find it, send me another message.
Pat Reilly
On Sun, Aug 5, 2012 at 6:14 PM, Paul Folbrecht <paul.folbrecht(at)veribox.net (paul.folbrecht(at)veribox.net)> wrote:
http://forums.matronics.com/viewtopic.php?p=380123#380123
le, List Admin.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
rawheels
Posted: Sun Aug 05, 2012 3:36 pm Post subject: Re: Everybody ground loops? |
| Paul Folbrecht wrote: | | I cannot find a link for the Lowell gear with Google - is there a web site? |
http://www.highwingllc.com/
Indianapolis, IN |
kl7jw(at)jwhart.us Guest
Posted: Sun Aug 05, 2012 4:27 pm Post subject: Everybody ground loops? |
Paul,
That Kitfox is about as easy as it gets to land a tailwheel airplane. I've
been flying tailwheel airplanes off and on since I first soloed in a J-3 Cub
in 1962, and I presently own a Kitfox IV. The important thing to make sure
that the landing gear is aligned properly, then don't quit flying a
tailwheel aircraft until it is at a dead stop. Keep the stick back on
landing rollout, and at the first indication that the aircraft may want to
take off one way or the other during rollout, KEEP THE STICK BACK and apply
rudder in opposite direction that the airplane is trying to turn. I've been
a flight instructor since 1967 and have never had a mishap from landing,
even with students, in tailwheel aircraft.
John Hart
KF IV EA-82 Engine
sdemeyer
Posted: Sun Aug 05, 2012 4:55 pm Post subject: Everybody ground loops? |
Paul, here is the link: http://www.highwingllc.com/
From: Paul Folbrecht <paul.folbrecht(at)veribox.net>
Sent: Sunday, August 5, 2012 4:14 PM
Subject: Kitfox-List: Re: Everybody ground loops?
http://forums.matronics.com/view= Archive Search & Download, 7-Day = --> http://www.matronics.com/Navigator?Kitfox-List
_= - List Contribution Web Site &nbs
Michel
Posted: Mon Aug 06, 2012 1:53 am Post subject: Re: Everybody ground loops? |
Paul, I have about 550 hours on my model 3 and the only time I did a ground loop was when I broke the tailwheel spring on a hard landing. I also went twice with the left wing on the ground in very strong side wind. Both were on asphalt runways. I think the Kitfox really loves grass. My airplane looks at me and says: "Thanks, mate!" each time I land on grass!
Cheers,
Michel
Kitfox 3 Jabiru 2200
kirkhull(at)kc.rr.com Guest
Posted: Mon Aug 06, 2012 4:08 am Post subject: Everybody ground loops? |
I cannot think of any tail wheel aircraft that is easier to land on
pavement. Grass is the way to go. If you talk to the locals you might be
surprised at how many airports have a grass strip available even if it is
not listed on the map. Many small airports (in the Midwest at least) will
have a grass runway right next to the paved runway. A great example is
Roosterville airport in liberty MO. It has 20 ft of grass on either side of
the paved runway.(see pic).
http://www.sportflight.net/display_pictures_large.php?most_viewed=yes&id=IMG
Kirk Hull
Classic 4
Editor
SportFlight.Net
mikeperkins
Posted: Mon Aug 06, 2012 5:45 am Post subject: Re: Everybody ground loops? |
Regarding 90 mph cruise in a long-wing (35 ft) - - - I flew for 12 years not knowing that my original Denny Aerocraft ASI read 76 at 70. On the other end, it read 31 at 35. I figured it must have been calibrated in Dennys per Hour. My replacement helicopter-type ASI reads in actual mph.
_________________ Mike Perkins
Havana, Illinois
Model I, 532, B gearbox, GSC prop |
msm_9949(at)yahoo.com Guest
Posted: Mon Aug 06, 2012 6:34 am Post subject: Everybody ground loops? |
While I was getting comfortable landing my Model 2, I'd customarily land on the grass between the runway and taxiway at my home airport (watch the signage!). Nobody seemed to care. I learned to fly taildraggers in a Piper PA-11 on grass. It is a much more forgiving surface.
Marco Menezes N99KX
KF 2 582-90 C-Box 3:1 w/clutch
Hersey, MI
Sent: Monday, August 6, 2012 8:08 AM
Subject: RE: Re: Everybody ground loops?
--> Kitfox-List message posted by: "kirk hull" <kirkhull(at)kc.rr.com (kirkhull(at)kc.rr.com)>
Kirk Hull
Classic 4
Editor
SportFlight.Net
Lynn Matteson
Posted: Mon Aug 06, 2012 10:42 am Post subject: Everybody ground loops? |
Interesting that you should mention Roosterville, Kirk....I was going
to fly in there last year to attend the Nascar race at Kansas, but
the report was for high winds, so I drove out there instead. Coupled
with the high winds being reported, and my research into the layout
of the runway...20 feet wide, with a dog-leg....I decided against
making the trip by Kitfox. After getting to Kansas and hooking up
with my racing buddy, we drove to the airport to see what it looked
like....it really wasn't as scary as it sounded, but the "cliff" at
the north end might have been interesting if a guy landed long. : )
By the way, was that your Kitfox that I saw parked there?
p.s. Another contributing factor in not flying there was the
identifier for Roosterville.......0N0.....which I read as : Oh,
NO! Which I took as a sign from God that I shouldn't fly there!
Kidding aside, it was a very nice-looking airport, and I'm hoping to
fly there this year for the October race.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with 1323 hrs... (since 3-27-2006)
might be
it is
least) will
example is
either side of
Kirk Hull
Classic 4
Editor
SportFlight.Net
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
jose_m_toro(at)yahoo.com Guest
Posted: Mon Aug 06, 2012 11:25 am Post subject: Everybody ground loops? |
Paul:
Probably most taildraggers pilot have done at least one ground loop, but that does not means that every taildragger pilot will do a ground loop from time to time. Once you know the technique, it is unlikely that you will have a ground loop under normal conditions. Exceptions are broken chains or broken springs as mentioned in previous postings.
Once you know the technique, there is nothing particular about performing a wheel landing in a pavement runway.
I strongly recommend a book that I studied when I was learning to fly taildraggers 20 years ago: The Compleat Tailoragger Pilot by Harvey S. Plourde. http://www.amazon.com/Compleat-Taildragger-Pilot-Harvey-Plourde/dp/0963913700
Flying taildraggers bring an additional challenge and fun that you won't find on a tricycle.
Best wishes!
Jose
Kirk Hull
Classic 4
Editor
SportFlight.Net
Posted: Mon Aug 06, 2012 11:43 am Post subject: Everybody ground loops? |
It was most likely mine as is the only one on the field but a picture is
worth a thousand words. The link below has some pics of my fox. As for the
cliff ( known as mount Stuber) it is well to the east of the runway center
line. The 20 ft wide is kind of misleading as it is 20 ft of pavement and
another 15 ft of smooth grass on each side. Hopefully you can make the trip
some time. I would love to see another fox in the rooster pin. If you do I
will make room in the hanger for you. Just send me an email on the
SportFlight.Net email address.
PS. If you have any good pics of your fox I would love to have more kitfox
pics added to sportflight.
http://www.sportflight.net/display_pictures.php?nnum=n205ak&searchnnum=yes&p
ic_only=yes
Kirk Hull
Classic 4
Editor
SportFlight.Net
Posted: Mon Aug 06, 2012 12:40 pm Post subject: Everybody ground loops? |
Kirt:
Very beautiful your Model 4. Very"interesting" your runway.
Jose
Sent: Monday, August 6, 2012 3:45 PM
ic_only=yes
Kirk Hull
Classic 4
Editor
SportFlight.Net
