EdKranz
Joined: 29 Dec 2010 Posts: 132 Location: Hastings, MN
Posted: Tue Sep 25, 2012 3:26 pm Post subject: AOA in which wing? |
I'm just getting ready to drill the holes to install the AFS AOA kit, and I'm wondering... are there any pros or cons to installing it in one wing vs the other?
_________________ Ed Kranz
RV10
Finishing
www.edandcolleen.com |
rnewman(at)tcwtech.com Guest
Posted: Tue Sep 25, 2012 4:33 pm Post subject: AOA in which wing? |
Don't know of any pros or cons, I mounted mine in the left wing using the
measured distances as prescribed in the AFS manual, I used Rob's
calibration settings from his RV-10 and it works perfectly.
Bob Newman
N541RV
90 hrs
robertbrunk(at)mac.com Guest
Posted: Tue Sep 25, 2012 7:05 pm Post subject: AOA in which wing? |
Mine is in the left wing. Works great! Robert 661G KCRP
Sent from my iPad
On Sep 25, 2012, at 6:25 PM, Ed Kranz <ed.kranz(at)gmail.com> wrote:
AirMike
Posted: Thu Sep 27, 2012 6:14 am Post subject: AOA in which wing? |
Conservatives generally put it in the right wing and liberals put it in the left wing.
Being closer to the pilot side connections and with the pitot line running out to the left wing, it just seems more logical to put it there as i did, between the stall waring and the wing tip per AFS instructions.
_________________ See you OSH '18
Q/B - sold. |
Kelly McMullen
Posted: Thu Sep 27, 2012 8:32 am Post subject: AOA in which wing? |
You could debate the definition of "it", or you could be a moderate
and put ports on both wings.
What does that make those that use the Dynon combined pitot/AOA?
On Thu, Sep 27, 2012 at 7:14 AM, AirMike <Mikeabel(at)pacbell.net> wrote:
Conservatives generally put *it* in the right wing and liberals put *it* in the left wing.
See you OSH '12
Q/B - flying 2 yrs.
http://forums.matronics.com/viewtopic.php?p=384080#384080
A&P/IA, EAA Tech Counselor
KCHD |
speckter(at)comcast.net Guest
Posted: Thu Sep 27, 2012 10:05 am Post subject: AOA in which wing? |
All this discussion on such a small item reminds me of a saying my friend has. "Pole vaulting over mouse turds."
LOL
Gary
Sent: Thursday, September 27, 2012 12:31:55 PM
Subject: Re: Re: AOA in which wing?
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com>
| Quote: | --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
See you OSH '12
Q/B - flying 2 yrs.
; -Mat===============
Gordon Anderson
Posted: Thu Sep 27, 2012 10:48 am Post subject: AOA in which wing? |
Conventional wisdom (or urban myth) says that pitot tubes and stall warning vanes are installed in the left wing because that wing goes slower in the left turns associated with a "standard" circuit, so it will stall first.
Feel free to do the maths on the speed difference between the wings and report back .
Cheers,
Gordon
41015 Doors fitting (nearly)
Sent from my iPad
On 27.09.2012, at 20:04, speckter(at)comcast.net (speckter(at)comcast.net) wrote:
LOL
Gary
From: "Kelly McMullen" <apilot2(at)gmail.com (apilot2(at)gmail.com)>
--> RV10-List message posted by: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
On Thu, Sep 27, 2012 at 7:14 AM, AirMike <Mikeabel(at)pacbell.net (Mikeabel(at)pacbell.net)> wrote:
| Quote: | --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
See you OSH '12
Q/B - flying 2 yrs.
://www.matronics.com/Navigator?RV10-List
cs.com
matronics.com/contribution
