Compatable Shunt
fedico94(at)mchsi.com
PostPosted: Sun Sep 30, 2012 7:17 pm    Post subject: Compatable Shunt Reply with quote
My RV9-A uses the Z-12 drawing. I installed a G3X unit (two Garmin GDU's 37x). The ammeter does not read but the voltmeter does. Reviewing the schematic provided by Garmin for connecting the two instumentation wires to the Shunt and comparing this to the Z-12 schematic I see both are essentially the same. The shunt sent to me by the Avionics shop for use with the Garmin is 100 amp/50mv and the one B & C supplied and installed in the plane is 60 amp at 50mv. My confusion and question concerns the schematic from Garmin that says the shunt is rated at 0.0005 Ohm. The B & C supplied system with its shunt is 50mv/60 amp gives me 0.00083 Ohm.
First are my calculations correct and second does this have any bearing on the inability to display the ammeter reading ? If the above is not contributing to the problem should I look elsewhere in the system for the problem ? (Prior to turning on the field of the 60 amp alternator I get the main volts waring light flashing and goes off after the field is activated. Remainder of G3X works fine)
PostPosted: Mon Oct 01, 2012 5:57 am    Post subject: Compatable Shunt Reply with quote
me 0.00083 Ohm.
The size of the shunt is relative only to calibration
of the display. If you have no display, then the problem
is not with the shunt. If the display is present but
inaccurate, THEN you probably have a shunt problem.
A shut is just a high power resistor . . . abeit a special
resistor manufactured from amazium alloy with a near
zero temperature coefficient of resistance. The material
is actually Manganin.
http://tinyurl.com/3f79fgy
When your current display is a LOADMETER calibrated
in 0-100%, then the shunt is sized to what ever that
100% value is . . . in case of the 60A alternator,
you would use a 60A shunt. If it were a 100A alternator,
then a 100A shunt. Interestingly enough, using a 100A
shunt in ALL installations converts the 0-100% display
to a 0-100A display.
I suspect that the 100A shunt recommended by the
avionics shop is based on some knowledge that the
EFIS calls 50mv drop 100Amps and that size shunt
will read ANY practical current up to 100A accurately.
Substitution of a 60A shunt would simply mean that
your 100A display was really a 100% display.
Looking past calibration issues, if your display is
non-reading, the difficulty lies elsewhere.
PostPosted: Mon Oct 01, 2012 7:27 am    Post subject: Re: Compatable Shunt Reply with quote
Your calculations look correct to me.
What is the aircraft electrical load? It might be too small to show up on the ammeter. Turn on the landing light or other heavy load.
The engine needs to be running for the following test.
Measure the voltage drop across the shunt with a milli-voltmeter. With a 60amp shunt and a 10amp load, the voltage drop will be about 8mv.
Then measure the voltage drop across the ammeter input. It should be the same as at the shunt.
If there is a millivolt input signal to the ammeter but it still does not display, perhaps the ammeter needs to be calibrated. See Page 12-20 G3X Installation Manual - Engine Sensor Configuration
Joe
Joe Gores
PostPosted: Mon Oct 01, 2012 6:45 pm    Post subject: Compatable Shunt Reply with quote
The G3X manual you refer to lists the calibration procedure for Hall effect sensor on page 12020. Cn this be used with the Shunt ? I suspect there is no calibration for the shunt.
Thanks for the reference, I have to keep up on the manual revisions as they add new devices all the time. After initial test flights I will have to update the software as well.
again thanks for the pointers so I can proceed with some confidence.
PostPosted: Mon Oct 01, 2012 7:53 pm    Post subject: Compatable Shunt Reply with quote
I downloaded the g3x manual. A search of the book
cites 82 instances of the word "shunt" where the
expected device is a 50mv/100A device. There
are also 8 instances of Hall Effect where it appears
you can use AmpLoc KEY100 style sensors.
Paragraph 8.3 speaks to the use of either. I was
unable to find any schematic references to hall
devices. They have 3 wire connections and need a
source of clean power. Also, hall effect sensors
are noted for their variability in both offset
and scale factor . . . they require individual
calibration for accuracy. Shunts are precision,
two wire devices that are very predictable. Suggest
you stay with the 100A shunt.
PostPosted: Tue Oct 02, 2012 2:52 am    Post subject: Re: Compatable Shunt Reply with quote
I do not know if the calibration procedure is for only Hall Effect sensors or for both Hall Effect and Shunts. The manual is not clear on this point. You could ask Garmin support. If there is no calibration procedure for shunts, then only a +/-50mV, 100amp shunt can be used, if you want the display to be accurate.
Easier than calling Garmin would be to try calibrating per page 12-20. What do you have to lose except a little time? If it doesn't work, you can reset the parameters back to default.
Joe
Joe Gores
PostPosted: Tue Oct 02, 2012 8:20 am    Post subject: Compatable Shunt Reply with quote
In a customer's airplane, cutting wires and splicing
back requires different levels of inspection than simply
Pushing the pin out of a connector to route a wire
through the hall device.
The AMPLOC hall sensors are really handy. I've used
them many times especially when I needed to measure
current in a wire for which I was discouraged from
doing damage.
Over the years, I developed some tools that offered
a quick-n-dirty access to current-in-the-wire . . .
http://tinyurl.com/8n6fo2n
http://tinyurl.com/8zqqetc
The KEY series AMPLOC devices
http://tinyurl.com/8gtrsru
Are more user friendly for getting electrons-per-second
counted in fat wires.
They do have the disadvantage of needing power to
operate . . . and it must be well regulated since
the output is ratiometric to the supply voltage.
They are bi-directional devices . . . meaning that
zero amps is some value close to 1/2 that of the
applied power. Hence the need for a wide range
of offset programming to move from shunts (zero volts
at zero amps) to hall effect sensors (some volts
at zero amps).
http://tinyurl.com/8suspug
I suspect that the Garmin display value for AMPS is
derived from analog data which is then massaged
for offset and scale factor. Given the extensive references
for 50mv/100A shunts for both wiring and discussion
of AMPS sensing, I'd bet that the default programming
assumes a 50mv/100A shunt. The resolution of their
a/d system would allow the 100A shunt to be used
virtually anywhere . . . even in series with an
SD-8, without adjustment to default offset and
scale factors.
I don't recall if the subject problem was "no reading"
or inaccurate reading. Of course, no reading could be
either wiring error . . . or there's no actual current
flowing to be measured and displayed. Inaccurate reading
could be due to 60A shunt being used without re-calibration
for the higher scale-factor value.
A more detailed study of symptoms and conditions is
called for. I suspect that either of the shunts in
hand will do the job . . . just need to learn the
correct incantation and wave of the wand to get the
hardware's attention.
cwjazun(at)aol.com
PostPosted: Tue Oct 02, 2012 11:37 am    Post subject: Compatable Shunt Reply with quote
Hello Bob,
Got the book, good job, I'm really enjoying it.
Quick question, how do I un-suscribe from the forum??? I get about 30 emails an hour! hard to keep up with it.
Walter
PostPosted: Tue Oct 02, 2012 12:02 pm    Post subject: Re: Compatable Shunt Reply with quote
It is too bad that we are so far from the aircraft. It would be fun to do some troubleshooting in person.
The original posting said that there was zero amperage displayed. And he said that the 60amp shunt was installed. If anything, the 60 amp shunt should read higher current than a 100amp shunt.
It would be helpful to know the millivolts across the shunt compared to the millivolts at the input to the G3X. If those voltages are equal and above zero and there is no amperage displayed, then the problem is the G3X, perhaps a software setup problem.
Joe
Joe Gores
PostPosted: Tue Oct 02, 2012 6:07 pm    Post subject: Compatable Shunt Reply with quote
With the 80 pin (read delicate) connector I am reluctant to pull it. The information I have from Garmin implies that the G3X will not read unless it has 5 milliohm resister (rather than 8.3)
Job one is to test fly with voltmeter. andswap out the shunt in the next few weeks. will recheck wiring tomorrow
PostPosted: Tue Oct 02, 2012 6:09 pm    Post subject: Compatable Shunt Reply with quote
The readout has a red "X" through it meaning inoperable, no scale is displayed
PostPosted: Tue Oct 02, 2012 6:11 pm    Post subject: Compatable Shunt Reply with quote
At 02:36 PM 10/2/2012, you wrote:
Hello Bob,
Walter
30 an hour? I don't think I get 30 a day. In
any case, they're very easy to delete if the topic is
uninteresting to you. I have submitted an
un-subscription request. When it arrives in
your email, click on the link within the e-mail
to confirm your request.
Bob . . . [quote][b]
eschlanser
PostPosted: Wed Oct 03, 2012 5:12 am    Post subject: Re: Compatable Shunt Reply with quote
Walter,
If you are really enjoying it, then don't unsubscribe. Rather, change your setting to receive a daily digest rather than individual e-mail messages. That way you will receive only one message per day.
Eric
cwjazun(at)aol.com wrote:
Hello Bob,
Walter
PostPosted: Wed Oct 03, 2012 6:49 am    Post subject: Compatable Shunt Reply with quote
Aha! Then the difficulty is not with the size of
the shunt. Shunt size has only to do with scale
factor . . . calibration.
Substitution of a 60A vs. 100A shunt without
re-calibrating the instrument means only that
readings displayed will be 1.66 times higher
than true.
The fact that your display does not show a
numerical value suggests that something in
the software has detected an error in wiring
or in setup. The instrument has no way to
deduce shunt size, only that a shunt appears
to be present. This strongly suggests a
wiring problem.
You can leave the 60A shunt in place and
re-calibrate per instructions . . . or swap
out for the 100A shunt where the instrument
will probably read correctly . . . AFTER
the big red X goes away.
PostPosted: Wed Oct 03, 2012 2:36 pm    Post subject: Compatable Shunt Reply with quote
SUPRISE Bob
A fellow EAA'r came out and we easily swapped out the 50mc 60amp shunt for the Garmin provided 50mv/100amp shunt and connected the wires back up as they were previously. Turned on master switch and the Garmin screens came up. Went to engine page on MFD screen and would you believe that the red "X" was gone and it was reading amp draw. Later I will do same for EBus shunt.
It appears with Garmin its their way or the highway. You would think it would read with just any old shunt in there, but as I was advised by Tim Larberg at Garmin, that is not the case.
PostPosted: Wed Oct 03, 2012 3:36 pm    Post subject: Compatable Shunt Reply with quote
At 05:35 PM 10/3/2012, you wrote:
SUPRISE Bob
That's more than a surprise, it's a mind bender . . .
I would REALLY like to understand the intelligence
built into the system for making that determination.
Low resistance measurements are not easy to do
even when you can attach 4-wires directly to the
shunt . . .
http://tinyurl.com/4l3tuj6
. . . looking at a .0005 ohm resistor on the
end of lead wires several feet long having a
resistance of 0.010 to 0.015 ohms PER foot
is magic.
I may have occasion to enjoy some face-time with
a Garmin techno-wienie next summer. I'll put this
on my list of questions to ask.
In any case, I'm delighted that your problem has
been resolved . . . even if we don't understand
just how it all came to pass. Must be pixie dust.
PostPosted: Wed Oct 03, 2012 5:28 pm    Post subject: Compatable Shunt Reply with quote
Do you have a phone number for Mr. Larberg. I'd
like to talk to him.
PostPosted: Wed Oct 03, 2012 7:06 pm    Post subject: Compatable Shunt Reply with quote
Hope this is not a serious discussion. Garmin has their own way of setting up the software and when I install the next shunt for the auxillary alternator, if the red "X" is gone then I will be two for two. Tim Larberg 1-888- 606-5482 press 3 for the first phone prompt and then press 3 for the second phone prompt (G series glass panels)
PostPosted: Wed Oct 03, 2012 7:56 pm    Post subject: Compatable Shunt Reply with quote
Nothing tense. Just one techno wienie talking to another
one. It behooves suppliers of any product to spread the
knowledge around. Cuts down on calls to field service.
An amazed and inquiring mind just wants to know . . .
