nick(at)flylightning.net Guest
Posted: Wed Oct 03, 2012 7:16 am Post subject: Elevator trim tab travel. |
The travel as measured on several aircraft Here is 1.25” down tab, or up trim. Measured from the elevator TE to the TAB TE.
The travel in degrees is between 25-28 on our aircraft, built as shown in the manual.
Will revise the manual to reflect what works in flight.
thanks
Nick Otterback
Arion Aircraft LLC
R&D Technical Support
931-680-1781
nick(at)flylightning.net (nick(at)flylightning.net)
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
stephenbehn(at)bigpond.co Guest
Posted: Thu Oct 04, 2012 2:18 am Post subject: Elevator trim tab travel. |
Nick
Thanks for this info. hope you all enjoy the home coming.Id love to come, maybe one day!
regards
Steve Behn
Lightning 69
mozart1(at)ctemail.net.au Guest
Posted: Fri Oct 05, 2012 2:10 pm Post subject: Elevator trim tab travel. |
Hi Nick,
Thanks for following up on this but I'm still confused about your measurements, I attached a drawing I made of two control horn setups one modified and the other as per manual. You can see from this that it will be not possible to achieve anything close to 25 deg without big modification. I guess there must be something different in what you have and I have. Hope this drawing can help to find out what it is as the trim tab is in scale 1:1 what I have and how it is in the manual.
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of Nick Otterback
Sent: Thursday, 4 October 2012 1:16 AM
To: Lightning-list(at)matronics.com
Subject: Elevator trim tab travel.
thanks
Nick Otterback
Arion Aircraft LLC
931-680-1781
| Quote: | | http://www.matronics.com/Navigator?Lightning-List | 0123456789
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
