marenyi(at)gmail.com Guest
Posted: Tue Nov 06, 2012 12:02 pm Post subject: Stereo to mono headphone jacks |
I bought some of the Stereo headphone plugs from B and C and tried
calling to ask a question but was unable to get an answer. I have a
Flightline FL-760 radio and this only has a mono headphone output so
should I just run a jumper wire from the sleeve post to the ring post
and ground them both, and the tip wire would be the wire fed from the
radio?
I am struggling through making a harness for the radio and this was
ONE of the looming questions.
I have another regarding grounds from other components, but I will
wait until I get home to attach a photo of the wiring schematic.
Eric M.
Posted: Tue Nov 06, 2012 2:55 pm Post subject: Stereo to mono headphone jacks |
At 02:00 PM 11/6/2012, you wrote:
radio?
I'm presuming that your headphones are fitted with 1/4",
stereo plugs. To convert to monophonic operation put
headphone audio to both tip and ring connections. The
tip-ring connection becomes the HI or signal connector
to your FL-760
The headset ground still goes to the sleeve.
| Quote: | I am struggling through making a harness for the radio and this was
I hope you're planning on some form of common ground local
to the radios. You can build from scratch or purchase
http://tinyurl.com/7hvmat6 as your needs/motivations dictate.
