BobbyPaulk(at)comcast.net Guest
Posted: Mon Nov 12, 2012 6:06 am Post subject: OAT etc. |
p { margin: 0; }p { margin: 0; }John
I installed my OAT probe on the inspection panel at the left side fuel tank outlet.
I also installed my Transponder Ant. on the floor in front of the right side rudder pedal. i sometimes fly in controlled air space and use the Transponder a lot.
Both of these items have worked fine for 5 yrs.
I did have trouble with the remote compass. It was mounted on the floor behind the belly access door. My rudder cables were magnetized and we could not degauss them.
The compass would turn 200 degrees or more sitting still and just moving the rudder.
We bought an inexpensive auto compass and moved it around in the aft section until we found a magnetically quiet space. We mounted it on the rear of the baggage compartment on the passenger side to get it away from the flap motor. It is by far the most accurate compass I have flown behind.
Hope this helps.
Bobby ( age 74 )
Zodiac 601 XL "B"
Jabiru 3300 S/N 1141
Sensenich 64" x 51" Prop
Bing Carb 260 Main & 285 Needle Jet
Status - Flying 165 hrs.
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
