This is for you Ned -CNG in a Grumman
n76lima(at)mindspring.com
PostPosted: Thu Nov 22, 2012 7:31 am    Post subject: This is for you Ned -CNG in a Grumman Reply with quote
Hey Ned,
We should play around with putting a bottle in your 9. Don't know how we could fill it though.
Brock
Yes Norman even has gas for $1.40 per gallon. It's natural gas and has an octane of around 120. It work very well in my >pickup. Wish my Tiger could use it.
Perhaps you could work on pressurizing the spar tube? <G>
With the size and weight of the 12 and 15 GGE tanks that I've seen, you MIGHT be able to install one in the baggage compartment area. But who wants a "bomb" with 3600 PSI explosive gas right behind you?
And given the fuel consumption of a Tiger, we are talking 1 hour and 1:15 endurance with the 12 and 15 GGE tanks, before being wheels-on-the-pavement!
I've looked at CNG for my pickup, too. It is $1.25/GGE at the local bus terminal, but that is a 15 mile round trip from my home, and the tank takes up a goodly portion of the 8' bed of the truck, so it just isn't all that practical for me, even if the CNG conversion was free (and its NOT).
I understand that Ned had one of those "Phill" compressors at home and could re-charge the tank overnight off the gas service at his house. That would help with the inconvenience of travel to fill the tank. But adds a whole 'nother level of cost to the cost/benefit calculation. http://www.cngcivic.com/www.cngcivic.html
--Bob Steward
BARRY CHECK 6
PostPosted: Thu Nov 22, 2012 7:59 am    Post subject: This is for you Ned -CNG in a Grumman Reply with quote
CNG... How compressed is that? Is that the 3600 PSI?WOW That is as much and more than a SCUBA tank.
So, why not LCNG... Is there such a thing? LiquefiedCompressed Natural Gas? That should be at a much lower pressure. Be very close in weight to AvGas. And theexpansionwould be way over 50:1
That could be possible. ?
Think of the 312 pounds of LCNG with a 50:1expansionAND the fueldistributionwould be equal in all cylinders. How much would the tanks weigh?
Barry
On Thu, Nov 22, 2012 at 10:31 AM, <n76lima(at)mindspring.com (n76lima(at)mindspring.com)> wrote:
[quote] --> TeamGrumman-List message posted by: n76lima(at)mindspring.com (n76lima(at)mindspring.com)
>Hey Ned,
>Brock
--Bob Steward
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
List" target="_blank">http://www.matronics.com/Navigator?TeamGrumman-List
http://forums.matronics.com
PostPosted: Thu Nov 22, 2012 8:25 am    Post subject: This is for you Ned -CNG in a Grumman Reply with quote
It is called LNG, and it is stored in insulated tanks at cryogenic temps. (-260F)
The energy density is ~70% that of gasoline on a per gallon basis.
As Ned mentioned, NG has an "octane" of well over 100.
In addition, a liquid introduced into the induction air would boil to vapor and suck the heat out of the air, lowering the density altitude of the combustion air enough to give a significant performance boost.
Talk about latent heat of vaporization...
--Bob Steward
So, why not LCNG... Is there such a thing? Liquefied Compressed Natural
AvGas. And the expansion would be way over 50:1
Think of the 312 pounds of LCNG with a 50:1 expansion AND the
fuel distribution would be equal in all cylinders. How much would the
tanks weigh?
Barry
On Thu, Nov 22, 2012 at 10:31 AM, <n76lima(at)mindspring.com> wrote:
> >Hey Ned,
> >Brock
> use it.
> --Bob Steward
Discover
PostPosted: Thu Nov 22, 2012 10:06 am    Post subject: This is for you Ned -CNG in a Grumman Reply with quote
You can get LPG for $1.68 nearby our airport. Older proven technology and heavier than air but its doable......No need for evacuated double walled tanks
http://mobile.altfuelprices.com/address_mobile.php?id=3005&lat=35.1411790&lng=-97.4769773&fuel_type=16&address=Goldsby,%20ok&start=0
On Nov 22, 2012, at 10:48 AM, "n2_narcosis(at)yahoo.com (n2_narcosis(at)yahoo.com)" <n2_narcosis(at)yahoo.com (n2_narcosis(at)yahoo.com)> wrote:
Well, its just LNG. The problem is its cryogenic. You have to have an evacuated dewar to hold the liquid since room temp is above the critical temp of methane. It's expansion is closer to 400 :1 I believe. That could be for nitrogen I can't remember. Anyway it requires a fairy large double walled tank with a vacuum between the walls.
From my HTC Sensation 4G on T-Mobile. The first nationwide 4G network
----- Reply message -----
From: "FLYaDIVE" <flyadive(at)gmail.com (flyadive(at)gmail.com)>
To: <teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)>
Subject: Re: This is for you Ned -CNG in a Grumman
Date: Thu, Nov 22, 2012 9:58 am
So, why not LCNG... Is there such a thing? LiquefiedCompressed Natural Gas? That should be at a much lower pressure. Be very close in weight to AvGas. And the expansion would be way over 50:1
Think of the 312 pounds of LCNG with a 50:1 expansion AND the fuel distribution would be equal in all cylinders. How much would the tanks weigh?
Barry
>Hey Ned,
>Brock
--Bob Steward
le, List Admin.
ctric.com
uilthelp.com
matronics.com/contribution
t">http://www.matronics.com/Navigator?TeamGrumman-List
cs.com
ky���"�휢Z+�M4�G�q�(����w�r����ϕ�y+����b��.+-�8b��'�'tg�J��a8�DA��l6�ޙ����ax 繩K��E�wQj+�)brJ'���{k������yzZ0����.�j+y���a�̞j�z��~'�爝ǧ�+�'��'^u��z���-�'�����i��0����^r��q�&� z���-�'�o�N��)]z���,���j�~m�����W^���K�l0���׫��(��(��g��)mB�j�~m����h���[azZ\�l0�&y����^��(���B�{k������y���桭���� 0��k�x���&��'����ب�m���� ���'���oܢ{k������i8Z�L���+ʋ���ޮ����i��Lj�C��ex���f�t�y7��j�f�.+-f��Z+�e,z�^1�k�x�����W���ް֯����hn�0��azf�ȸ���b�+bz�.r�.+-Rҹ��*m����b��j�!�'����6��0��j�(at)(at)�h��!j���ٮr�r��桭���� 0��k�x���&�֯�����ja��i�����m���� ���'���o�j�j�+M�����ˊ�h�D�H %�S�PĒjg���r��z{Z�����i�^�&���lZ+�k�����i���鬙�k�x���&��i���鬙�k�x���&����'��k{��w/�i
