kheindl(at)msn.com Guest
Posted: Fri Dec 14, 2012 3:45 pm Post subject: Europa-List Kick=back |
If you don't correct this you will damage the sprag clutch, and that is expensive.You need to do two things:
Get the friction torque adjusted by a Rotax man to be the maximum allowable. For this you need to remove the gearbox.
Second , you need to change the flywheel, should also be done by your Rotax specialist. If you have a Classic this may mean having to loosen the engine to get access to the back.
Karl
| Quote: | Subject: Re: Ethanol Testing Kits
Date: Fri, 14 Dec 2012 13:24:48 -0800
--> Europa-List message posted by: "Alan Carter" <alancarteresq(at)onetel.net>
Hi Roland.
i am having a lot of kick back on starting, due you have a new engine later than 2000 , the later engines have 6 pins on the ignition system and incorporate dual soft starts modules and the timing below 800 rpms is 3% after TDC as opposed to the older engines of 4% Before TDC.
Alan
http://forums.matronics.com/viewtopic.php?p=390462#390462
