rickofudall
Posted: Mon Dec 31, 2012 7:39 pm Post subject: Light reading |
A neighbor of mine suggested a NACA report about simplified propeller design written by Fred Weick (designer of the Ercoupe, among other work) and while I was searching the database I found the attached report. Given the thick wing and the testing of both tractor and pusher configurations I thought some of you might enjoy it, too.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
 Download |
| Filename: |
TR_196_Wind_Tunnel_Tests_of_Several_Tractor_and_Pusher_Propeller_Wing_Extension_Shaft_Arrangements.pdf |
1.69 MB |
| Downloaded: |
972 Time(s) |
Thom Riddle
Posted: Tue Jan 01, 2013 8:28 am Post subject: Re: Light reading |
Rick,
I finally got through it. Interesting reading. Thanks for posting.
I don't recall ever seeing an airplane with wing mounted engine and extension shaft, either pusher or tractor, but there probably are some. The BD-5 comes to mind for fuselage mounted pusher with extension shaft.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
