Posted: Fri Jan 04, 2013 9:33 am Post subject: Advisability of using anti-corrosion lubricant on conta |
At 10:06 AM 1/4/2013, you wrote:
| Quote: | Greetings Bob,
May I suggest that you try "3M Marine Adhesive Sealant 5200" instead of RTV for your tests. I have used it under many fittings above and below the waterline on boats with excellent results. They also make a 4200 that is easier to remove which might be more appropriate for antenna installations. |
Good info. Actually, there are a host of
suitable sealants. In this case, cured sealant
exposed to the environment is a very thin
'gasket edge' that is quite protected. I
rather suspect that any quality caulking
compound would suffice. I thought of EGRTV
only because it's stuff I have around and
I KNOW it to be non-corrosive . . . unlike
similar products with the smell of acetic
acid.
What ever we test should be something that
a builder can readily acquire at low cost.
Hardware store acrylic caulk seems an attractive
alternative.
Bob . . . [quote][b]
