vettin74(at)yahoo.com Guest
Posted: Fri Jan 04, 2013 12:09 pm Post subject: Elevator trim tab hinge |
The aluminum hinge needs to be bonded in with either 24hr aeropoxy/flox mix or we used Plexus MA310. Plexus is the structural adhesive used through out the plane for construction at custom fiberglass.
Once the hinge is cured the gap between it and the lower skin must be filled. Use scrap baggage floor material to fabricate a 1/2" wide part that is the length of the hinge. The material is already the correct thickness at 3/16" thick. Bomd this part in, leave is slightly recessed in ablut 1/16" or slight more for flox filler later.
Nick
Sent from my pocket
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
