Posted: Tue Jan 08, 2013 10:02 am Post subject: Lithium batteries redux |
This morning's news included a bit concerning
a battery fire in a B787 on the ramp at Boston
airport.
http://tinyurl.com/bx3ww23
According to Skip Koss (and unlike the
Cessna ramp fire in the Citation) this fire appears
to have been controlled by individuals both trained
and equipped for dealing with a lithium fire.
A123 (manufacturer of the cells in the Cessna
battery) is shut down in bankruptcy although
I understand they've been purchased by a Chinese
interest.
Folks. I think it's pretty clear that the large
energy storage lithium products are not ready for
prime time on airplanes. There's a lot of ground
based history being made and new product development
being conducted which may ultimately evolve into
products with aviation-grade failure modes and risks . . .
let us wait and see.
Sometimes, the best way to drive a nail is with
a hammer and the best way to carry a reserve of
electrons is with lead-acid.
http://tinyurl.com/3atma44
rlborger(at)mac.com Guest
Posted: Tue Jan 08, 2013 2:21 pm Post subject: Lithium batteries redux |
You may very well be correct, but I've gone out on a limb that I trust will support me and the aircraft.
I have purchased and installed an Aerovoltz 12 Cell EV02 LiFePo battery in my Europa. The LiFePo battery is not supposed to be the fire hazard that the LiFe battery is. It is amazingly small and light. About 12 lbs lighter than the Odyssey it replaces.
I would not have done this had my Rotax 914 still been electric dependent with two electric fuel pumps. about 2 years ago I replaced one of the electric pumps with an engine driven, mechanical pump so the engine will continue to operate should the electrics go totally dead.
So far, in 2 hours of testing on the ground and 1 hour in the air, all seems well. It spins the Rotax on startup just like the Odyessy. I purchased the special charger that will do fast, 5A, charge; slow. 2A, charge; maintenance, .1A, charge/float and cell balancing. I have not done any time/power testing. I need to see how long it will run the radio, transponder and GRT EIS 4000 and then test with only the radio and EIS. When this is done, I will report the results.
The seller of the battery did warn not to discharge below 9v as that would probably permanently damage the battery. And if discharged to below 11 volts, it must be recharged in the cell balance mode.
Isn't this one reason why we call it Experimental?
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop.
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 8, 2013, at 12:00 PM, "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com> wrote:
airport.
interest.
jan_de_jong(at)casema.nl Guest
Posted: Tue Jan 08, 2013 3:43 pm Post subject: Lithium batteries redux |
My assessment sofar (FWIW).
The problem with LiFePO4 batteries is that they do not self-balance
well. And the 4 cells are not reliably identical. The result is as follows.
You can either keep the cells balanced in the charged state, meaning
that none of the four will ever go over 4 volts when the battery is
charged at 14.4 V or so.
Or you can keep them balanced in the discharged state, meaning that none
of the four will ever be driven below 2 volts when the battery is
discharged to below 12 volts.
You cannot have both without sophisticated power electronics.
In our type of use we keep the battery balanced in the charged state.
The danger then lies in deep discharging.
I will only use LiFePO4 if I can have a battery alarm that goes off when
any one of the 4 cells goes below 2 volts (when discharging) or above 4
volts (when charging). And an alternative source of backup energy if
either occurs.
I would like to know in the meantime what level of battery monitoring is
done on the accident Cessnas and Dreamliners...
Jan de Jong
On 1/8/2013 11:20 PM, Robert Borger wrote:
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
airport.
interest.
Posted: Wed Jan 09, 2013 5:59 am Post subject: Lithium batteries redux |
Quote from PPRuNe forum:
"The APU and main batteries are quoted as a Lithium Manganese in my 787
gen fam course notes. "
May not be LiFePO4 at all...
Jan de Jong
Posted: Sun Jan 13, 2013 7:10 am Post subject: Lithium batteries redux |
monitoring is done on the accident Cessnas and Dreamliners...
I cannot speak to specifics of the battery controls
and monitoring systems in either airplane. However,
I can speak to the qualification process for getting
these batteries approved for installation.
A number of AIRPLANE companies, not battery companies,
have launched into breathtakingly expensive programs
to gain some form of approval for use of lithium batteries
on their products. These include Cessna, Boeing, Grumman
and others.
All players in the lithium game are intently aware
of the unique risks offered by lithium batteries.
They are also aware of the widely publicized litany
of events involving lithium battery catastrophic
failures.
The testing of batteries is a legacy skill finely
honed by over a century of field experience and
lessons learned.
See: http://tinyurl.com/akvhxv6 also
http://tinyurl.com/b4f89jh
The two airplanes you asked about enjoy a very
high degrees of electronic systems management
not the least of which are the batteries. Given
the intense scrutiny and qualification expense
associated with getting Li-Ion products onto
both airplanes, it's a pretty sure bet that
everyone believed that they'd touched all the
bases.
Posted: Sun Jan 13, 2013 9:01 am Post subject: Lithium batteries redux |
Thank you Bob, very interesting.
As a follow-on I found this:
http://www.gsyuasa-lp.com/aviation-lithium-ion-markets
with this:
http://www.s399157097.onlinehome.us/SpecSheets/LVP10-65.pdf
So - not LiFePO4, not LMO either but LCO - the cathode type for the high
energy density but with the bad reputation:
http://www.mpoweruk.com/lithium_failures.htm
(sorry about the graph without numbers or provenance).
I am still not sure whether in operation they do monitor each individual
cell (volts, temperature?) before aggregating the result into a status
for a whole series chain. The 787 APU starter battery uses 8 cells in
series for 32 V no-load (nominal cell voltage 3.7 V vs. about 3.2 V for
LiFePO4).
Jan de Jong
Posted: Wed Jan 16, 2013 4:36 pm Post subject: Lithium batteries redux |
Gents,
With the Boeing 787 Dreamliner being grounded till their Li batteries can be checked, I figure it's a good time to report on my new AeroVoltz LiFePo battery.
I said that I'd report on any testing I did on the AeroVoltz battery. Today I turned on the master which powered up the, Turbo Control Unit (Rotax 914), the GRT EIS4000 Engine Information System and the Airmaster AC200 prop controller. I then turned on the MicroAir 760 Comm radio and MicroAir T2000 transponder. With the comm radio tuned between ASOS, Ground Control & Tower (I swapped between them) and the transponder set on ALT DISPLAY (so the encoder was fired up as well), the voltage started at 12.4 Volts. It took almost exactly 20 minutes for the voltage to sag down to 11 Volts. When the voltage went to 10.9 Volts, I terminated the test and put the battery on cell balance charge.
So there you have it. 20 minutes on what I would consider the minimum load. If for any reason I needed to be in the air longer than that to make it to the closest airport and that airport had a tower, I would probably shut down the radio and, maybe, the transponder till they were needed. Maybe even pull the breaker on the prop controller till needed. That would leave the only load as the EIS and TCU which should extend the battery life further.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 8, 2013, at 4:20 PM, Robert Borger <rlborger(at)mac.com> wrote:
Posted: Thu Jan 17, 2013 3:09 am Post subject: Lithium batteries redux |
Robert,
This is a disappointing endurance..
The battery is advertised as 20 PbEq Ah - a meaningless number
introduced by Shorai for marketing reasons.
The actual maximum energy content should be about 6.5 Ah (Shorai applied
a factor 3, Aerovoltz/Ballistic probably do the same).
At a 1 to 2C discharge rate from 12.4 (under load) to 11 V you should
get about 90% of that out of a fully charged battery.
That is 60 minutes at 6 A, 40 minutes at 9 A, 30 minutes at 12 A.
I would have expected at least twice as long as 20 minutes...
Jan de Jong
On 1/17/2013 1:35 AM, Robert Borger wrote:
Gents,
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
Posted: Thu Jan 17, 2013 5:37 am Post subject: Lithium batteries redux |
Jan,
I agree. It is disappointing. I had hoped for at least 30 minutes on the tested load.
The battery works fine for cranking the engine but does not have the endurance I would have liked under a small load. I don't think there is any way this battery would work for an electrically dependent aircraft.
Bob Borger
3705 Lynchburg Dr.
Cel: 817-992-1117
rlborger(at)mac.com
On Jan 17, 2013, at 5:06 AM, Jan de Jong <jan_de_jong(at)casema.nl> wrote:
Robert,
The battery is advertised as 20 PbEq Ah - a meaningless number introduced by Shorai for marketing reasons.
The actual maximum energy content should be about 6.5 Ah (Shorai applied a factor 3, Aerovoltz/Ballistic probably do the same).
At a 1 to 2C discharge rate from 12.4 (under load) to 11 V you should get about 90% of that out of a fully charged battery.
Jan de Jong
Gents,
Bob Borger
Posted: Thu Jan 17, 2013 7:50 am Post subject: Lithium batteries redux |
At 07:35 AM 1/17/2013, you wrote:
Jan,
on the tested load.
dependent aircraft.
Are there any data packages available for these
batteries? Discharge curves, engineering data?
Posted: Thu Jan 17, 2013 9:05 am Post subject: Lithium batteries redux |
Not that I know.
But, FWIW, I believe the Ballistic and Aerovoltz batteries (among other)
are constituted from A123 ANR26650 cells:
http://www.a123systems.com/Collateral/Documents/English-US/A123%20Systems%20ANR26650%20Data%20Sheet.pdf
The 12 cell item (4 x 3) should then have capacity of at least 7.2 Ah
and internal resistance of 8 mOhm.
Discharge voltage degradation at low temperatures to be noted.
Jan de Jong
On 1/17/2013 4:48 PM, Robert L. Nuckolls, III wrote:
> Jan,
> on the tested load.
> aircraft.
mmayfield
Joined: 09 Oct 2009 Posts: 40 Location: NSW Central Coast, Australia
Posted: Sun Jan 20, 2013 12:20 am Post subject: Re: Lithium batteries redux |
I have to sympathise with Bob's views here.
Lithium-chemistry based batteries hold a lot of promise for aircraft power sources, but there are clearly issues to be resolved, not least of which is the possibility of a battery fire. I know the problems will eventually be solved, but until that time, I have to question whether the risk is worth taking.
There's a limit to how far I'm willing to push the "experimental" aspect!
_________________ Mike |
