Eric_Kallio
Joined: 29 Jan 2006 Posts: 149 Location: Baton Rouge, LA
Posted: Sun Mar 10, 2013 8:47 am Post subject: fuel float parts |
Anyone know of a place that might sell just the float wire for the resistive fuel sender? Seem to have broken the wire on my right fuel float? Forgot on install to put that last little bend in the arm wire and when I pulled the whole sender on the annual... I broke it. Just looking for the wire for the float arm but if I have to order the whole thing because I did not pay attention to the instructions so be it. Thanks
Eric
seipel(at)seznam.cz Guest
Posted: Sun Mar 10, 2013 10:38 am Post subject: fuel float parts |
I believe you can order just the wire from Van's. I'd give them a call
first to make sure, but I believe this is what you want:
REPLACEMNT FLOAT WIRE IE F-385 FLOAT ARM
PJ
On 3/10/2013 09:47, Eric_Kallio wrote:
| Quote: | Anyone know of a place that might sell just the float wire for the resistive fuel sender? Seem to have broken the wire on my right fuel float? Forgot on install to put that last little bend in the arm wire and when I pulled the whole sender on the annual... I broke it. Just looking for the wire for the float arm but if I have to order the whole thing because I did not pay attention to the instructions so be it. Thanks
Eric_Kallio
Posted: Sun Mar 10, 2013 11:42 am Post subject: Re: fuel float parts |
That looks like it. Thanks. I will call them tomorrow. I could not get it to come up on a search in the parts store. I kept spelling replacement correctly, but that us apparently not how they spell it.
Eric
Kelly McMullen
Posted: Sun Mar 10, 2013 12:43 pm Post subject: fuel float parts |
I expect they sell a fair number, as probably a lot are not bent correctly on the first try.
On Sun, Mar 10, 2013 at 11:37 AM, PJ Seipel <seipel(at)seznam.cz (seipel(at)seznam.cz)> wrote:
[quote]--> RV10-List message posted by: PJ Seipel <seipel(at)seznam.cz (seipel(at)seznam.cz)>
I believe you can order just the wire from Van's. I'd give them a call first to make sure, but I believe this is what you want:
PJ
http://forums.matronics.com
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
