Ed Godfrey
Posted: Mon Mar 11, 2013 5:49 pm Post subject: Firewall insulation |
All,
I am trying to make a decision as to a decent method of firewall
insulation. I have looked through the arhives and have seen where some
have used a Fiberfrax type of material and some have used a foam
material. Is there anything that might not be a good idea to use bot the
Fiberfrax as a thermal insulation and a foam insulation for acoustic?Any
thoughts would be greatly appreciated.
Ed Godfrey
40717
rleffler
Posted: Tue Mar 12, 2013 1:51 am Post subject: Firewall insulation |
Ed,
You need to read the thread in the VAF archives about Dan horton's testing of all the materials.
Unfortunately, as Ted found out, that black foam insulation turns into caustic black smoke pretty quickly. I wouldn't use it on the firewall or tunnel. I did use the black foam in areas that most likely would be exposed to flames in flight, like the side walls.
I used fiberfrax in the tunnel. On the firewall I used a product from acs that is a ceramic blanket with stainless foil on the firewall side and aluminum foil on the aft side.
There is no 100% answer here. You need to determine the best way to mitigate the risk of heat/fire, since many of the solutions introduce other risks if implemented.
Bob
Sent from my iPad
On Mar 11, 2013, at 9:48 PM, Ed Godfrey <egodfrey(at)ameritech.net> wrote:
All,
I am trying to make a decision as to a decent method of firewall insulation. I have looked through the arhives and have seen where some have used a Fiberfrax type of material and some have used a foam material. Is there anything that might not be a good idea to use bot the Fiberfrax as a thermal insulation and a foam insulation for acoustic?Any thoughts would be greatly appreciated.
Ed Godfrey
40717
_________________ Bob Leffler
N410BL - Phase I
Posted: Tue Mar 12, 2013 5:55 am Post subject: Firewall insulation |
I used the this and like it:
http://www.aircraftspruce.com/catalog/appages/insulator3.php
The double sided, one layer thick is fine.
Get the aluminum foil tape to install:
http://www.aircraftspruce.com/catalog/appages/insultape.php
I used this insulation on the inside of the firewall, all floors and
sidewalls (with an interior fabric covering the cabin side of the insulation
for areas not enclosed). I did not use it for the cabin top (I found a nice
marine grade upholstery product for that). I have this on the bottom of the
tunnel but not the sides. I have not experienced any issues with tunnel
heat. I have some KoolMat
http://www.aircraftspruce.com/pages/ap/insulation/koolmat.php on the
firewall. It is between the cabin heat control valves and the firewall,
then extents up and over the top of the valves. The idea is to not blast
the engine and fuel pump with hot heat muff air that bounces off the valves
back toward the engine when the valves are shut (on hot days when you least
want hot air banging on the fuel pump). So the KoolMat insulates some
thermal heat transfer to the firewall, and looping the KoolMat over the top
and then down in front of the valves directs the dumped heat muff air down
and away from the engine.
I know one RV-10 builder who used the black foam in the floor area that had
to pull it out - it started to smell up the airplane when it got warm.
Carl
