schmoboy
Posted: Thu Mar 14, 2013 3:43 pm Post subject: Trimming Push-Pull Cables To Length |
Looking for help on the best way to go about trimming the length of the
CT A-740 push-pull cables. That spiral material is a bugger to cut.
Maybe using a tube cutter?
-Sean #40303 (fab)
rene(at)felker.com Guest
Posted: Thu Mar 14, 2013 3:56 pm Post subject: Trimming Push-Pull Cables To Length |
Dremel cutoff wheel..
Rene' Felker
N423CF
801-721-6080
schmoboy
Posted: Fri Mar 15, 2013 6:05 am Post subject: Trimming Push-Pull Cables To Length |
Ok, I was informed of something that wasn't obvious to me. Pull the
cable wire back, then just cut through it at the desired location. I was
trying to figure out how to cut the spiral without damaging the internal
cable wire. Sometimes I miss the obvious. Thanks Joe...
-Sean #40303
n223rv(at)wolflakeairport Guest
Posted: Fri Mar 15, 2013 6:18 am Post subject: Trimming Push-Pull Cables To Length |
Just be careful, some cables have a small ball and maybe a spring in them for the detents. Just make sure you don't lose it.
-Mike Kraus
RV-4 sold
RV-10 flying
KitFox SS7 Radial building
On Mar 15, 2013, at 10:04 AM, Sean Stephens <sean(at)stephensville.com> wrote:
Ok, I was informed of something that wasn't obvious to me. Pull the cable wire back, then just cut through it at the desired location. I was trying to figure out how to cut the spiral without damaging the internal cable wire. Sometimes I miss the obvious. Thanks Joe...
-Sean #40303
